Old 06-19-2014, 06:01 PM   #99
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by RBbugBITme View Post
...our shocks allowed the driver to get the power down sooner.
The gold standard.
...my daily driven S60R
Good taste - I say that because I used to own an R. lol They're great sleepers, and can surprise other drivers at the track, too.
dradernh is offline   Reply With Quote
Old 06-19-2014, 08:59 PM   #100
RBbugBITme
Drives: S60R/Corvette
Thanks. The R isn't bad but there isn't any good tuning solution yet.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
Old 06-19-2014, 09:09 PM   #101
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Hurray, suspension nerds!
The Following 2 Users Say Thank You to solidONE For This Useful Post:
cdrazic93 (06-19-2014), Shankenstein (06-20-2014)
Old 06-19-2014, 09:12 PM   #102
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'm curious though, high end suspension companies use different Monotube fluids. Bilstein uses nitrogen, Penske uses oil like OEM. Why? I always thought gas would be able to move more freely than oil would. But since Penske uses the bypass valves er whatever those thingys are, it allows the oil to move as quick as a gas fluid does?
Old 06-19-2014, 10:10 PM   #103
RBbugBITme
All modern twin tube and monotube shocks use N2 gas and shock oil. The oil is what generates the forces by moving through valves/shim stacks/orifices in a controlled manor. When the oil is forced through these valves there is always a pressure differential across the valve and without gas pressurization the low pressure side can drop in pressure enough to reach its vapor pressure. That is the point where the liquid will start to turn into a gas and this is bad and this is called cavitation. You want your gas pressure to be as low as possible while keeping the shock oil above its vapor pressure at all times.
You can see what cavitation looks like in videos like this one. Its not a great quality video but you can see "clouds" rapidly forming and collapsing on the low pressure side of the piston. The shock has lost control at this point and the oil will rapidly degrade if you don't raise the gas pressure. Also, at the very top of the video you can see a version of a head valve with some oil above it and then a floating piston that moves slightly when the shaft moves. The nitrogen gas is above that. Practically speaking, for that demonstration video the shock probably has the gas pressure between 0-50 psi. All of our shocks are built with something between 75 and 300psi. I have no idea what something like Bilstein or KW's use because they're twin tubes and we don't deal with that junk.
While typing this I realized this was a typical engineers answer to a simple question so sorry for the rambling but hopefully it paints a complete picture for everyone.
Ryan M.
Strange Engineering
The Following 5 Users Say Thank You to RBbugBITme For This Useful Post:
cdrazic93 (06-19-2014), DarkSunrise (06-20-2014), fooddude (06-19-2014), Kostamojen (06-20-2014), solidONE (06-19-2014)
Old 06-19-2014, 11:06 PM   #104
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
quite alright, I understood some of it, since Im attempting to be an engineer as well. And Bilsteins are monotubes.
Old 06-19-2014, 11:21 PM   #105
dradernh
True. I went with IPD: OEM RWHP + 10% - and then went race car.
<End OT>
Old 06-20-2014, 12:23 AM   #106
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Bilstein make both monotube and twin tube.
Old 06-20-2014, 02:26 AM   #107
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Do F1 racecars really use Penske shocks? lol
How much are those? 4 or 6 way adjustable?
fooddude is offline   Reply With Quote
Old 06-20-2014, 03:00 AM   #108
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
You have no idea how much most of us appreciate these replies!
This is probably the best shock absorber forum info I've seen in all my years on the interwebs
Kostamojen is offline   Reply With Quote
Old 06-20-2014, 04:33 AM   #109
All modern twin tube and monotube shocks use N2 gas and shock oil. The oil is what generates the forces by moving them through valves/shim stacks/orifices in a controlled manor. When the oil is forced through these valves there is always a pressure differential across the valve and without gas pressurization the low pressure side can drop in pressure enough to reach its vapor pressure. That is the point where the liquid will start to turn into a gas and this is bad and this is called cavitation. You want your gas pressure to be as low as possible while keeping the shock oil above its vapor pressure at all times.
We need to bring you on here full time.
gramicci101 (06-20-2014), Kostamojen (06-20-2014)
Old 06-20-2014, 04:43 AM   #110
Kostamojen
I don't think we could afford him
The Following User Says Thank You to Kostamojen For This Useful Post:
Captain Snooze (06-20-2014)
Old 06-20-2014, 04:57 AM   #111
RBbugBITme
Thanks errbody, glad I can help.
We have more than half the field. They're all non-adjustable for weight and packaging.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Ryan M.
Strange Engineering
The Following User Says Thank You to RBbugBITme For This Useful Post:
fooddude (06-20-2014)
Old 06-20-2014, 05:46 AM   #112
Captain Snooze
Drives: Red Herring
@RBbugBITme
I noticed on the Penske webpage for the FRS/BRZ dampers that there was the option for 3 and 4-way dampers. Does dual-bleed have a different outcome to the low speed adjustment from the low speed adjustment of a 3-way damper that has seperate low and high speed compression adjustment? That is, is dual-bleed just the low speed adjustment from a 3 or 4-way damper?
Penske Coilovers. miwialex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 12-20-2013 08:17 PM
Penske 8300 vs Ohlins TTX36 CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 09-12-2013 07:08 PM
MSRP FR-S available at Penske Scion in Socal. Moto-P Dealer Cars 2 07-25-2012 09:29 PM
Penske Scion has a Silver/AT FRS in stock, MSRP. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 1 07-13-2012 02:00 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
