Old 04-16-2014, 03:33 PM   #99
M3_Dust
ok yeah it was the handbrake being on...so I guess I'd have to modify wires to keep them on with the headlamps
M3_Dust is offline   Reply With Quote
Old 04-16-2014, 03:45 PM   #100
Chattanooga FR-S
Chattanooga FR-S's Avatar
Drives: Monogram Firestorm
This is the way I will eventually make this mod, by buying projek_01's kit, assuming he is still making them. No need to cut any wires, and it is reversible if needed.
http://www.ft86club.com/forums/showthread.php?t=44066
Chattanooga FR-S is offline   Reply With Quote
Old 04-16-2014, 06:45 PM   #101
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by 2pt5RS View Post
What's the difference between this and holding the traction control button until the trac off light is lit mixed with hitting sport mode?
It basically disables all safety functions except for ABS and makes the car easier to slide and rotate mid-corners:
http://www.ft86club.com/forums/showthread.php?t=25494
Old 04-29-2014, 04:34 PM   #102
Haeb
Haeb's Avatar
Drives: 2014 Scion FR-S Monogram Series
Originally Posted by Floggin Tires View Post
I believe some Scions will apply to this.
At least the ones with door handle lock unlock sensors.
On Limited BRZ's
Factory settings:
When you touch the inside of the handle to unlock the door,
it unlocks the drivers side only. If you want both driver and passenger
side to unlock with a single touch of the handle, do as follows.
Open The driver door,
Leave the car off,
On the key fob Hold down both Panic and Lock buttons for ~5secs.
When you let off you should hear a beep.
Used this little trick on my wifes 2014 Rav4 too
Haeb is offline   Reply With Quote
Old 05-08-2014, 02:31 PM   #103
travisb
travisb's Avatar
Drives: N/A
Any more hidden features? Thanks for the tips.
travisb is offline   Reply With Quote
Old 05-08-2014, 02:41 PM   #104
fang_gt86
FR Noob
fang_gt86's Avatar
I'm not sure if this is the intended design but it's my tool tray!
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 05-08-2014, 03:35 PM   #105
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Your picture is broken.
JohnJuan is offline   Reply With Quote
Old 05-08-2014, 03:36 PM   #106
Razz
Razz's Avatar
Drives: Fast
Originally Posted by Mikem53 View Post
- Turn on the car. The car must be FULLY warmed up. You must do the entire sequence within 30 seconds of starting the car.
- Pull the e-brake 3 times. Hold/lock the e-brake on the 3rd pull.
- Press the brake pedal 3 times. Hold it down the third time.
- Pull the hand brake 3 more times. Hold/lock the hand brake on the 3rd pull
- Press the brake pedal 2 more times.
- On the last press of the brake pedal, two yellow lights should have come on.
Best used ONLY for track use!
Pulling the fuse is the best option. At least it is on most cars.
That way when you spin out or go off track or get fuel starvation... upon restart your good to go and no dancing is needed.
Razz is offline   Reply With Quote
Old 05-08-2014, 05:39 PM   #107
djmm
djmm's Avatar
Drives: toyota
Originally Posted by AtlasMick View Post
I just tried this.
I work occasionally on the second floor of an industrial building with steel panels for exterior walls, which blocks essentially all cell services etc, except for walkies. I've tried my remote start from inside the building many times and it never worked, I tried even getting steadily closer to the exit doors but it never worked until you were physically standing outside the exterior walls.
Today I was deep in the building where it never worked before, put the remote to my chin, opened my mouth (not sure why because you didn't provide those instructions), and viola, chirped on and when I got to my car nice and toasty. AMAZING!!!!
I'm going to keep trying it obviously now, but if this was a one time fluke I'd be very disappointed.
Best way is actually:
With one hand, point remote under your chin
Open your mouth wide
Other hand on top of your head with index finger up mimicking antenna
Press button.
Another secret:
Press:
Up up down down left right left right B A start- gives you 30 lives.
djmm is offline   Reply With Quote
Old 05-08-2014, 05:41 PM   #108
gramicci101
Off Topic
Press button.
Then you do the hokey-pokey and you turn yourself around?
Old 05-08-2014, 05:51 PM   #109
extrashaky
Drives: 2014 BRZ Limited
This is less of a hidden feature and more of a silly joke, but I just discovered that there are actually floor mats under the seats, as if anybody sitting on that ridiculous back seat will actually be able to put their feet on the floor.
Old 05-08-2014, 05:58 PM   #110
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
It's is pretty patronizing for those to even be in the car.
My 5'0'' fiance fits ok with someone who is 5'10'' or below in the passenger seat who isn't stretching out. At all.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 05-08-2014, 06:03 PM   #111
extrashaky
I honestly didn't even know they were there until I had to move my seat all the way forward to pick up a truck exhaust that wouldn't fit in through the trunk. I pulled the seat forward and said, "What the hell is that?"
Old 05-08-2014, 06:05 PM   #112
PollosHermanos
It's like a napkin. Not too much floor protection there.
scion brz hidden features
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Bespoke A/V Hidden Option UbSaMrC Electronics | Audio | NAV | Infotainment 58 12-13-2015 11:14 PM
FS: Custom Stainless Lightweight Hidden Hitch that_guy Canada Classifieds 3 06-11-2014 07:13 PM
Hidden Rusting issue FRSHunter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-07-2014 05:02 PM
DIY: access hidden menus on BRZ head unit robot DIY (Do-It-Yourself) Guides 0 10-22-2013 11:59 PM
