#99 | |
Not a troll
#100 | |
#101 | |
The RE760's have a TW of 340, while the S Drives are 300 and fall under the UHP Summer category. Here is a comparison between a few UHP tires. http://www.tirerack.com/tires/tests/...y.jsp?ttid=192 The RT615 have a 200TW and AD08R's are 180 and fall under the Extreme Perf. Summer and will probably wear quickly. http://www.tirerack.com/tires/CompareTires.jsp It all depends on what you want out of the tire. FWIW I haven't noticed any change in steering response with the wider tires.
#102 |
Drives: FR-S White - Smexy.
#103 |
I picked up a laser temp gun (sorry don't know what its actually called) for relatively cheap the other day becuase well, it was cheap. Any way, I decided to see if having ceramic coated headers made any difference.
I compared my car vs a friends car who has the same Borla UEL header except his wasn't coated (also has a sprintex sc) What I found out was, the ceramic coated headers were about 25c hotter than uncoated. However, the cam position sensors, oil dipstick, rad fan wiring was about 10-15c cooler than the uncoated header. There is also a noticeable difference when you open the hood. Uncoated ![]() ![]() Coated ![]() ![]() Both cars were run for the same amount of time (approx 5 minutes) and with the hoods closed. Sent from my Nexus 6P using Tapatalk
#104 |
![]() ![]() ![]() ![]() ![]() Sent from my Nexus 6P using Tapatalk
#105 |
Not a troll
Thanks for that temp comparison Dan. Didn't realize you also tested against another car. Far less worried about my non coated header now.
#106 |
No worries man. I'm sure the differences would be greater after some spirited driving or some time in the track.
#107 |
![]() [IMG]https://uploads.tapatalk-cdn.com/20160826/b6a2325f78f8fc710e243732***77637.jpg[/IMG]![]() Sent from my Nexus 6P using Tapatalk
#108 |
Drives: 2013 Scion Frs
Dude hoping my frs looks this good once i save up enough to get the build going! Amazing
#109 | |
#110 |
Drives: '13 LAVA - lightly modded
Awesome build thread. Love this simple, functional, clean theme you got going on.
Was eyeing the Whiteline camber adjustment too. Did you notice accelerated front tire wear at -1 deg camber all the time vs the nearly 0 deg camber from stock?
You are going to be condemned to live out the consequences of your taste - TM
#111 | |
No negative side effects from the added negative camber either
#112 |
| FS: 2013 Argento FRS | aSaki | Canada Classifieds | 3 | 10-28-2013 11:16 PM |
| FS: FL, 2013 Argento FR-s 6 spd manual ONLY 260 miles | KAB-FRS | Cars for Sale/Trade | 3 | 04-12-2013 11:43 PM |
| TSI's Argento FR-S Pic thread | Jon@TrueStreetIndustries | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 01-01-2013 04:48 PM |
| 2013 Scion FR-S Argento | sirhc | Cars for Sale/Trade | 0 | 12-29-2012 05:48 PM |
