Old 02-01-2014, 03:37 PM   #99
wootwoot
Drives: FRS
^lol^ really?
wootwoot is offline
Old 02-01-2014, 06:51 PM   #100
jflogerzi
jflogerzi's Avatar
Originally Posted by BRZPDX View Post
I hope my car will be ready for the track soon. Rear axles, brake pads, SS line/brake fluid swap, install my oil cooler, lighter wheels/better tires, hood vents, gah so much more shit to have my car track ready!
In the winter the only thing you need are brake pads and fluid. Otherwise its already track ready.
jflogerzi is offline
Old 02-02-2014, 12:43 AM   #101
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by 8686 View Post
[ATTACH]65754[/ATTACHl
The mechanic took a picture of the rears but forgot the fronts.
I will write my review after few days of testing the cars but I can say the small bumbs feel much smother and the car driving feel more firm
The Blistein rear shaft looks to be a tad thicker than the stock rear, did it come with bumpstops or does it require retrofitting of the factory bumpstops?
solidONE is offline
Old 02-02-2014, 03:00 AM   #102
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Nice....are you using the swift springs? What's the ride height with the Bilstein/swift combo compared to stock?
@solidONE I'm pretty sure you're meant to re-use factory bumpstops just like the B14/B16.
Fizz is offline
Old 02-02-2014, 09:28 AM   #103
8686
8686's Avatar
Drives: 86
You are right. Both front and rears are thicker than the stock. The car now feel more solid and firm than before. The blistein didnt come with bumpstops so we reused the originals.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline
Old 02-02-2014, 09:29 AM   #104
8686
8686's Avatar
Drives: 86
I have to compare with a stock car. but I will give it a day or two for the shocks to settle.
8686 is offline
The Following User Says Thank You to 8686 For This Useful Post:
charged86 (02-02-2014)
Old 02-02-2014, 01:21 PM   #105
hail2thetheif
Drives: 15 CBS WRX STi
I believe the Monotube design has built in bump stops. There is a post on this page or the previous with a diagram explaining the Monotube design.
I'm not 100% positive that's how it actually is but according to the diagram these should have bump stops built in?
Can anyone clarify for any future installs?
hail2thetheif is offline
Old 02-02-2014, 01:45 PM   #106
troek
troek's Avatar
Drives: 2012 Toyota 86
i think thats only the fronts that are inverted and have built in bumpstops. they probably expect you to use the bump stops that are matched with your springs for the rear. (shorter spring usually has shorter bump stop)
troek is offline
Old 02-02-2014, 06:34 PM   #107
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
For the B14 where is has shorter body and spring, they still wanted you to use the factory bumpstops. I can only assue that the damping/rebound would have been tuned to account for this otherwise they would have (easily) included shorter bumpstops in the kit...
Fizz is offline
Old 02-04-2014, 03:39 AM   #108
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
8====D ~ ~~ ~ ~ ~
fooddude is offline
Old 02-07-2014, 02:04 AM   #109
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@8686 any further updates on how you're finding these Bilstein dampers?
Also, anyone know if these are also available from other vendors apart from FT86SP? (I don't mean to say you shouldn't shop from FT86SP....as their customer service is nothing but excellent)
Fizz is offline
Old 02-07-2014, 08:41 AM   #110
8686
8686's Avatar
Drives: 86
I can confirm that the car became more comfortabpe than stock. I even start thinking to add front and rear strut bars while I was hesitating before because the bad road conditions in my area.
On the other hand, Icouldnt test the improvement in handeling yet even though it is difinitly their.
8686 is offline
Old 02-07-2014, 10:02 AM   #111
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks. Can u tell me what's the ride height measurement (wheel centre to top of wheel arch)?
Fizz is offline
Old 02-07-2014, 03:53 PM   #112
fooddude
Looking forward to RCE getting these and running some dyno tests. Would love to hear the max spring rates these can handle for a "no fuss, single valve setting, drop in, set up" for track/autox use. (via GC sleeves with custom spring rates).
fooddude is offline
Bilstein shocks & struts Fizz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-31-2013 02:56 AM
GB: Koni Sport Yellow Shocks/Struts - CRAZY PRICING - FREE S&H - IN STOCK! AJ@ECSMotorsports Groupbuys 13 09-15-2013 08:21 AM
FS: Koni Yellow Struts/Shocks front-rear set never used Kinzo Brakes, Suspension, Chassis 5 06-10-2013 08:36 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
Tein Street Basis coilover, Koni struts and shocks JoeBoxer Brakes, Suspension, Chassis 6 12-25-2012 09:43 AM
