#99 | |
Drives: 2013 FRS - Ultramarine
2013 ULTRAMARINE FR-S ![]() |
#100 |
Another question! lol
I have the sportlines. My car has 35,000 miles..should i be worried about the stock shocks? or should i invest in konis.. its just my DD.
#101 | ||
Always Moving Forward
Drives: 2013 Argento Scion FR-S
1. I have attached the pictures of the poke my setup has. The last one kinda shows what the poke looks like from in front of the car. I hope this helps. Front Passenger Front Driver ![]() Rear Driver Rear Passenger ![]() ![]() 2. Your struts should be alright. I put my pro-kit on with stock struts at ~40,000 miles and I am almost to 60,000 now with no issues so far **knocks on wood** -J.B. |
#102 |
I am on RSR Super Downs with over 1 1/2" drop. I have just about 100K on the car and all the stock shocks are still going strong. I would not ever remotely start worrying about it yet.
#103 |
Drives: 2014 GT86
It all depends on where and how you drive. If you rally race on soviet roads, you can wear them down much much faster. It's a bit different for those that drive on Japan roads
. It's a bit hard to actually start feeling when they are too worn, as it's gradual process and one can get used even to shocks that are noticeably underperforming compared to when they were new. But imho 90% chance that on normal "capitalist" roads with 35K miles you should be fine
#104 | |
#105 |
Drives: 2014 GT86
Oh, familiar look. My advise for you would be to never think of getting camberplates with pillowball
#106 | |
#107 | |
im excited now to get these on!
#108 |
got a rear pic? hows the rear camber without the LCA?
#109 |
Drives: 14 Ultramarine FR-S
You'll be fine it will add some extra camber but nothing that will severely accelerate tire wear, toe is more of a factor.
If you drop on sportlines or superdowns you will end up around 2 to 2.5 degs of negative camber in the rear. I'm on stock LCAs, I'll eventually upgrade but not really in a rush.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#110 | |
#111 |
http://www.tirerack.com/tires/tirete...e.jsp?techid=4
Tire rack does a good job explaining. "Additionally the vehicle's toe is one of the most critical alignment settings relative to tire wear. A toe setting that is just a little off its appropriate setting can make a huge difference in their wear. Consider that if the toe setting is just 1/16-inch off of its appropriate setting, each tire on that axle will scrub almost seven feet sideways every mile! Extend it out and you'll discover that rather than running parallel to each other, the front tires will scrub over 1/4-mile sideways during every 100 miles of driving! Incorrect toe will rob you of tire life." - Tire Rack
#112 | |
| Can't post pics with tapatalk | AirborneDeth | Site Announcements / Questions / Issues | 16 | 04-06-2015 01:45 PM |
| Post your winter pics | kidgogeta | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-16-2013 01:52 PM |
| Post your FOGLIGHT pics | project d | CANADA | 7 | 12-13-2013 04:04 PM |
| Raven Only! Post Pics! | imlevinit | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 07-06-2012 07:41 PM |
