11-20-2013, 02:19 PM | #99 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
So that would have caused a coolant leak?
11-20-2013, 03:00 PM | #100 |
Drives: 2013 Black FR-S
No, the nipple seals coolant and also seals the chamber the laminova core sits in.
11-20-2013, 08:37 PM | #101 |
Drives: frs
I also got code P0171. Hopefully the shop figures out what is loose.
11-20-2013, 08:48 PM | #102 |
Road Warrior
From what I have heard the 3 areas to check
Little black rubber the clear pipe which fits on the actuator, check if pin hole The 2 grey L connectors must be supr tight, even then could still leak. Advised to just to take then out and put Teflon tape to be sure. |
11-21-2013, 06:59 AM | #103 |
Road Warrior
After going back and forth trying to resolve issues with this kit and being told on many occasion by Sprintex that my SW is the issue. It takes finding the fault and raising it to get a response like this
We have found that the plastic elbows loosened from heat cycling. Currently we are tightening them in with the casting hot (after ultrasonic cleaning) which helps. After the system has heat cycled, We can tighten them a turn or two more. Why not put out a notice to advise what has been established, so if we come across a possible boost problem we know what to look for. |
11-21-2013, 08:57 AM | #104 | |
That Guy
Drives: 2013 asphalt FRS MT
I'm guessing those connections are pipe threads. If so, any pipe thread will leak without something to seal it. While they are an interference fit, there is still a path for a leak. Of course, having dissimilar materials that expand at different rates isn't helping either. With the aluminum case that the fittings are being threaded into I would try to find aluminum fittings to replace the sprintex ones, but that would probably be difficult. Brass, IIRC wouldn't cause as much corrosion between the metals, but steel would be stronger. Either way teflon tape should be used, which should eliminate most of corrosion issues. |
11-21-2013, 12:39 PM | #105 |
Drives: 2013 SWP BRZ
I haven't had any issues with my kit at all. The one grey fitting closest to the driver side has slight play in it (plus a tiny bit of oil buildup on it) but I haven't gotten any codes or anything. I am able to tighten it by pushing it.
Honestly, I know some people have had bigger issues (like the maf pin), but complaining about two fittings is not a big deal at all lol. I've been so happy with my Innovate kit. I was a bit worried in the beginning about it being "enough" but its such a perfect amount of power, and I can't wait to get some injectors in and try e85 out (and also get my hands on an IC kit). |
The Following User Says Thank You to xxscaxx For This Useful Post: | whataboutbob (11-21-2013) |
11-21-2013, 01:12 PM | #106 | |
Road Warrior
11-21-2013, 01:13 PM | #107 |
11-21-2013, 01:18 PM | #108 |
Road Warrior
I believe due to the intercololer, there is more pressure causing air to leak through the grey L piece screw thread.
11-21-2013, 02:07 PM | #109 | |
A lot of innovate owners have loose grey plastic fitings back there. They are minor leaks if any. I tightened mine down just for insurance.
The Following User Says Thank You to sw20kosh For This Useful Post: | whataboutbob (11-21-2013) |
11-21-2013, 08:59 PM | #110 |
I might take off the charger and tighten it and throw some teflon on there, since you guys got me all worried n crap now.. lol.
11-21-2013, 10:06 PM | #111 |
Road Warrior
Mine coming off today, will let you know if there is any difference.
11-21-2013, 10:38 PM | #112 |
Almost as good as a vortech.....almost. @Brian@Vortech
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Similar Threads | ||||
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! | Innovate Motorsports | Forced Induction | 577 | 10-15-2014 12:49 AM |
Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! | Xero-Limit | Forced Induction | 12 | 03-10-2014 08:56 PM |
Innovate Motorsports FR-S/BRZ traction control state modifier module... | mines13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-13-2013 01:06 PM |
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ | Innovate Motorsports | Forced Induction | 1987 | 03-13-2013 09:14 PM |
FS: Innovate Motorsports OT-2 | pixel67 | Engine, Exhaust, Bolt-Ons | 0 | 01-05-2013 10:13 AM |
