Old 08-22-2014, 10:17 PM   #99
Assunta
Assunta's Avatar
Drives: 2013 SWP BRZ
Show time
Assunta is offline
Old 11-12-2014, 08:53 AM   #100
wsites
Drives: 08 STI|15 BRZ|95 L Coupe
I'm curious, would the 18x8.5 +42 fit the stock suspension in the front? If so you could run a staggered set up with the 18x9.5 in the rear without having to go RB! That would be a great option for guys like me who don't need ridiculously wide rims because we don't plan to push over 275 whp...
Originally Posted by cantholdanymore View Post
People wants moar pawar
Kit provides moar pawar
Kit needs engine build to support moar pawar.
People call it fault
wsites is offline
Old 11-15-2014, 06:15 PM   #101
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
The issues up front for the 18x9.5 is the strut on the inside. Just need coils to make them work. Fender clearance is fine.
FT-86 SpeedFactory is offline
Old 11-20-2014, 12:17 AM   #102
wsites
Oh ok, but do the 18x 8.5 +42 have the same issue? or is it just the 9.5?
wsites is offline
Old 11-22-2014, 11:08 PM   #103
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Is there any clearance with stock suspensions or do I have to upgrade to coilovers? What if I get 8.5 front and 9.5 back width... will this cause issues with stock suspension?
Mikeez is offline
Old 12-08-2014, 04:40 PM   #104
SavEvoIX
Drives: Evolution IX, 13' FR-S White Out
Wheel Directory: Enkei RS05RR 18x9.5 +43
Just purchased these wheels for my wife. She has TRD lowering springs. Do I need a camber kit and what's the MAX width tire I can run without hitting the perch?
SavEvoIX is offline
Old 01-06-2015, 08:58 PM   #105
protpibe
protpibe's Avatar
Does anyone have these wheels with an STI Brembo brake swap, and if so, do they clear with no issues?
protpibe is offline
Old 01-16-2015, 01:45 PM   #106
OAKOS Automotive
OAKOS Automotive's Avatar
Drives: '13 Limited BRZ, Satin White Pearl
Send a message via AIM to OAKOS Automotive
Front will need a spacer...
Ive had a set of 18x9.5 +43 sparkle silver n order for a month for my personal car! Super stoked for them to get here in the next two weeks!
Although mine will be going on my WRX these wheels look great on BRZ/FRS.
And agreed to everyone saying that 9.5 should have more concave! if only!
-Anthony
Oakos Automotive
OAKOS Automotive is offline
Old 01-16-2015, 01:47 PM   #107
protpibe
protpibe's Avatar
-Anthony
Oakos Automotive
Thanks for the info
5mm would be sufficient in your opinion?
protpibe is offline
Old 01-21-2015, 12:21 PM   #108
OAKOS Automotive
Thanks for the info
Contact at ENKEI says 10mm spacer.
Which stinks cause Im coming off of Rays 57dr in 17x9 and they have no issues clearing my brembos lol..
-Anthony
Old 01-22-2015, 10:49 AM   #109
protpibe
protpibe's Avatar
-Anthony
lol that's funny. I'm coming from 57DR's too
I guess I'll get some 10mm's and extended studs
protpibe is offline
Old 01-22-2015, 12:12 PM   #110
SavEvoIX
Just tested fitted with 5mm spacer with 245/40/18 v12 Evo tires up front. These work with stock suspension. It's close with the perch but does not hit. I may end up with 10mm in the rear to even it all out
SavEvoIX is offline
Old 07-12-2015, 11:57 PM   #111
MikesFRS
MikesFRS's Avatar
Drives: it like he stole it!!
so with aftermarket coils, spacers are not necessary?
MikesFRS is offline
Old 07-13-2015, 04:56 PM   #112
Assunta
Assunta's Avatar
Stock brakes? correct.
265 tires? correct.
Assunta is offline
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei RS05RR 18x8.5 +42 dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 206 03-02-2018 05:23 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 THMotorsports.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-19-2013 04:33 PM
