Old 03-27-2012, 11:26 PM   #99
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
i imagine sometime later in my cars life i'll track it, but few and far between track days will be for me. springs and camber plates seem like a good way to go for everyday driving and keeping things economical, especially if camber plates will help to even out tread wear better than stock, no?
poormans_LFA is offline   Reply With Quote
Old 03-28-2012, 12:32 AM   #100
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by serialk11r View Post
If you read the other thread, I asked the same question basically, and the reply from the people who seem to know their stuff was a slight drop shouldn't affect the geometry appreciably and there's no need to swap everything out because you dropped it only 0.8" (as the RCE springs do).
Idk, not the impression I got from that thread. I mean 0.8" won't royally screw up handling during mild-mannered street driving, but I'd guess in this car it's gonna be noticeable during spirited driving.
dsgerbc is offline   Reply With Quote
Old 03-28-2012, 01:02 AM   #101
serialk11r
Drives: '06 AM V8V Coupe
Well, camber correction might be a good idea, but correcting roll center might not be necessary. You're moving the center of gravity down too, so I'm guessing the roll moment will at least not increase in this case, but not sure. I'll shut up and let someone else chime in, but people were telling me that for a mild drop, springs and dampers are enough.
Old 03-28-2012, 01:27 AM   #102
dsgerbc
It most certainly will increase. With LCAs already horizontal, depending on how much kingpin angle this car has, roll center could end-up underground with a moderate lowering. Springs/dampers are enough for the car that is only driven on the street and the main objective is aesthetics.
Old 03-28-2012, 01:57 AM   #103
old greg
Rocket Surgeon
Drives: PSM GGA OMG
With MacPherson Struts the roll center will always move more than the CG. A well designed multilink/SLA suspension can completely eliminate roll center migration, and anything halfway decent will at least be a lot better than struts in this regard. The concern that I would have is that any sort of drop will increase the front roll moment but not really affect the rear, which will lead to a change in lateral load transfer distribution. With a mild drop this should have about the same effect as installing a slightly wimpier front sway bar which may or may not be a good thing depending on how you feel about the stock setup. Either way, a slightly stiffer front sway bar would probably suffice and may be a better option than extended lower ball joints (which might cause a tendency to lift the inside rear tire mid-corner if used on a car with nearly stock ride height). You'd also probably want a bit more total roll stiffness and/or a bit more static negative camber up front, to counteract the slight compromise you'd be making to your front camber gradient.
old greg is offline   Reply With Quote
Old 03-28-2012, 02:46 AM   #104
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
How are the stock dampers handling the new springs?
Are you going to offer dampers too?
I am thinking
- 20mm drop springs
- camber plates
- RCA of some sort
- High quality damper
I am not looking to slam the car, just take away some of the wheel-fender gap, maintain good suspension travel, while improving the handling over stock.
uspspro is offline   Reply With Quote
Old 03-28-2012, 04:09 AM   #105
toxicdrift
toxicdrift's Avatar
Drives: Suzuki Carry
I am thinking
- 20mm drop springs
- camber plates
- RCA of some sort
will this option be considerbly cheaper then getting coilovers? cant wait for the RCE pricing, we have some really bad potholes where i live so good suspenstion travel is a must.
toxicdrift is offline   Reply With Quote
Old 03-28-2012, 10:09 AM   #106
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Originally Posted by Turbowned View Post
If it's not draggin' frame, it's not low enough bro d00d!
But seriously, that looks just about right! Too bad I'll be going with coilovers...
Anyone else notice this? If that's a Limited, that's about 60-70lbs below target! - EDIT: This is apparently without jack & tools, but usually manufacturer's listed weight is dry weight, so 2762 for a Premium and ~ 2780 for a Limited (before fluids?), and this is showing 2714 with full fluids and no jack/tools (13 gals of fuel weighs about 65lbs, for reference). That is AWESOME!
So the FR-S should be below 2700 pounds for sure!
tripjammer is offline   Reply With Quote
Old 03-28-2012, 10:12 AM   #107
Subaruwrxfan
Subaruwrxfan's Avatar
Drives: 2015 Mustang EcoBoost
Ugh, and here I was hoping I could just install the springs and be done with it. In my opinion all these parts just for a 20 mm drop isn't worth it. Unless Racecomp comes on here and says there won't be any issues with the springs, I'll just leave mine stock.
Check out my BRZ videos on my YouTube page: youtube.com/subaruwrxfan
Subaruwrxfan is offline   Reply With Quote
Old 03-28-2012, 10:17 AM   #108
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if you don't track your car and care about winning top spots, then you don't have to worry about this whole geometry thing
the lower sitting position and stiffer springs will MAKE YOU FEEL like its faster, even though skid pad numbers will tell otherwise
so if you enver hit the 10/10 and only care about FEELING, then just ignore all of this technical supplement.
This is generally the problem with such forumes for every 1 true gear head you get 20-30 people who are kinda like "wait wha?" and get all confused and intimidated.
don't
do what you want to the car
but if you plan on competing, then you need to start cramming.
Old 03-28-2012, 10:35 AM   #109
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
don't
^This.
The discussions about roll centers and camber correction and roll moments are firmly in the Theory vs Reality department. The car's behavior is not going to change dramatically from just a 20mm drop. Don't worry at all.
What we're doing is called "Chasing Tenths", as in 10ths of a second. For 99.9% of the drivers out there, it's a completely moot point.
Old 03-28-2012, 11:48 AM   #110
Longhorn248
Hook 'em
Longhorn248's Avatar
Originally Posted by Draco-REX View Post
^This.
If you're chasing tenths in this car you're going to be replacing and upgrading a lot more parts on it than just the suspension.
Longhorn248 is offline   Reply With Quote
Old 03-28-2012, 11:56 AM   #111
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
chasing tenths as in within a predetermined frame work.
by your definition a Formula 1 car is technically "never finished"
Old 03-28-2012, 11:58 AM   #112
Longhorn248
Hook 'em
I would completely agree with that statement, show me a team who isn't continuously developing their car throughout the season
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 03:35 AM
Any thoughts on my "mini" engineering and business plan.? KidWonder Off-Topic Lounge [WARNING: NO POLITICS] 24 12-29-2011 01:16 PM
BRZ engineering video shown at Tokyo Motor Show. Japanese translation needed please. tranzformer BRZ First-Gen (2012+) — General Topics 16 12-16-2011 05:50 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
$95 Track Day@Willow Springs March 11 Louie Southern California 0 01-23-2011 01:38 AM
