Old 03-25-2012, 08:05 PM   #99
tachi1247
tachi1247's Avatar
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
FI model won't be out until fall 2013 at the earliest. They won't release any other trim lines during the first MY.
tachi1247 is offline   Reply With Quote
Old 03-25-2012, 08:10 PM   #100
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by tachi1247 View Post
anyone notice that the article has been updated to say that a turbo version of the brz engine will be used in the next wrx. Something tells me someone at Subaru said something they shouldn't have to a reporter...
edit: the old version said something like "a turbo version is coming although a timetable has not yet been set." it was too different from what is written now to have been a misquote. I'm betting that Subaru called the writer to let him know that little tidbit was supposed to be off the record.
Or the author misspoke and incorrectly described something that was not true. That is the other case, which I believe is more likely. No one from Subaru has confirmed anything regarding a turbo in the BRZ, however they have confirmed the FA being the basis of the new engine for the next WRX. So don't assume that the correction on the article means they had the correct information.
tranzformer is offline   Reply With Quote
Old 03-25-2012, 09:08 PM   #101
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Everything else is just deductive reasoning. They have said the chasis was designed to handle more power, they have designed a more powerful engine that will fit, and there is room to add more power and still undercut a similarly equipped 370z which would be the primary competition.
The hooks are in there for a higher output version. It's convertible-ready so chassis reinforcements would be near plug-and-play and I think Racecomp Engineering confirmed a larger WRX STI rear sway bar is a direct fit. In an interview with Top Gear Magazine, Subaru cheif engineer Masuda-san asserted this car would never see factory forced induction but hinted, "We can fit tougher valve springs, and that would allow the BRZ to rev much higher, maybe to 9,000rpm."
Tada-san hinted at a convertible version (now confirmed). Leads me to believe if ever one of the chief engineers hints at something, it'll likely happen pending sales numbers.
Old 03-25-2012, 09:10 PM   #102
tranzformer
Drives: Zoom Zoom
Originally Posted by switchlanez View Post
The hooks are in there for a higher output version. It's convertible-ready so chassis reinforcements would be near plug-and-play. In an interview with Top Gear Magazine, Subaru cheif engineer Masuda-san asserted this car would never see factory forced induction but hinted, "We can fit tougher valve springs, and that would allow the BRZ to rev much higher, maybe to 9,000rpm."
Now that right there would have many of us giddy like little school girls. BRZ STI version anyone?
Old 03-25-2012, 09:16 PM   #103
switchlanez
^That's where I'm hoping for patience to payoff. I'm all for a modest bump in NA power (+20ish hp) rather than FI which could throw price way up in the 30's.
Old 03-25-2012, 09:22 PM   #104
gdi2290
Web Designer/Programmer
gdi2290's Avatar
Drives: WRB BRZ Limited (Lemon)
9,000 RPM
gdi2290 is offline   Reply With Quote
Old 03-25-2012, 09:27 PM   #105
switchlanez
Old 03-25-2012, 09:28 PM   #106
tranzformer
Drives: Zoom Zoom
Originally Posted by gdi2290 View Post
9,000 RPM
Yeah, if there is any truth to that, it would be totally worth that. I know you could probably do that yourself with a engine rebuild, but to have that from factory with a warranty to back it up would be very nice.
Old 03-25-2012, 09:55 PM   #107
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Originally Posted by blu_ View Post
If something breaks which turbo subarus do quite often it is expensive.
Havent had anything break on my wrx. Had to replace a fuel pump once.
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 03-25-2012, 10:06 PM   #108
serialk11r
Drives: '06 AM V8V Coupe
Upgraded injectors/fuel pump/engine management could be tough to sort out, and the intake ports are optimized for the direct injection system, that could be difficult to work out too. Also longer duration cams cost more to replace on a boxer engine too.
9000rpm could be stretching it a bit, a little over 8000 would make me happy.:happy0180:
Old 03-25-2012, 10:08 PM   #109
OrbitalEllipses
Drives: Attitude
I've had a sensor or two go out, but beyond that anything I've broken has been directly related to my doing.
Old 03-25-2012, 10:55 PM   #110
jor8888
Drives: sad
waiting for 2nd year model turbo or bigger engine dont matter just need more juice, 200 aint enough. This car was supposed be out 2 yrs ago and got delayed so now it comes out already out dated, and Toyota knows it so they are working on more powerful version.
jor8888 is offline   Reply With Quote
Old 03-25-2012, 11:01 PM   #111
86fanatic
Drives: auto
The car makes peak HP at 7000 and peak torque at 6400. The red line is already 7400.
Why exactly do you guys want a higher red line?
86fanatic is offline   Reply With Quote
Old 03-25-2012, 11:02 PM   #112
serialk11r
More power, duh :P
The moment all Canadians have been waiting for! Enemies CANADA 22 03-30-2012 03:10 AM
Waiting a year for the 86. What would you recommend for the mean time? Avatar_Ko Other Vehicles & General Automotive Discussions 23 02-05-2012 11:52 PM
Waiting in line in Los Angeles.... RiskyTrousers Scion FR-S / Toyota 86 GT86 General Forum 47 12-01-2011 02:06 PM
waiting for TRD june1986 Other Vehicles & General Automotive Discussions 3 11-30-2011 03:48 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
