Old 07-10-2013, 09:17 PM   #99
jamesm
Originally Posted by SloS14 View Post
That's a beast! I have a few of their esc's, some are great others not so much. I wasn't aware they made a 300a model. That's crazy. What's it for?
Old 07-10-2013, 09:22 PM   #100
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
What else would you use them for? A manned multi-rotor of course...with 60lbs of Lipos
http://www.reddit.com/r/radiocontrol...atboy_v2_300a/
SloS14 is offline   Reply With Quote
Old 07-10-2013, 09:31 PM   #101
jamesm
That is bat shit crazy, and I love it. 18kW motor? That's what, like 24hp? And there's 6 of them?!?! I'm inspired lol.
Old 07-10-2013, 09:48 PM   #102
Frs300
Frs300's Avatar
Drives: Pile of junk
@jamesm 11hp brushless motor? lol about the size i have for a rc boat a 4082 and a 5682. twin screw and two esc that can handle over 200amps each or 2 5000watt motors lol
when did turnigy aka re branded hobbyking start selling a 300amp esc. i have fried to many turnigy esc
Frs300 is offline   Reply With Quote
Old 07-10-2013, 09:52 PM   #103
jamesm
You gotta be careful which of the turnigy ones you buy, most are crap. They do make a few gems though. Their CC clones are nice and reliable in my experience.
Old 07-10-2013, 09:57 PM   #104
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
You can find all kinds of MAP sensors on eBay for as little as $10. The other option is to just tap into the existing MAP sensor.
Digikey. There are multitudes of various styles under 10. Megasquirt uses a freescale semiconductor one as I recall.
Toma is offline   Reply With Quote
Old 07-10-2013, 09:58 PM   #105
Frs300
Frs300's Avatar
ive only used the marine stuff which is always rebranded hobbyking. stick to fightercat but they are expensive
Old 07-11-2013, 01:54 AM   #106
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
MS uses Freescale MPX4250AP, 14$ from Digikey.
On a side note, if you are shooting for low boost levels, 3 psi of boost at 7500 rpm only needs 5 hp compressor work at 70% comp. efficiency. So if you upgrade to a 320 amp alternator, you maybe don't need a capacitor bank...
Combustion engg here, my EE knowledge is sketchy at best.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 07-11-2013, 08:59 AM   #107
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Are you talking about driving the system directly off the alternator? Isn't that sort of missing the point? The idea, at least to me is to act more like a hybrid slowly charging the battery during normal driving and then draining the battery for a quick burst of power.
Old 07-11-2013, 09:02 AM   #108
neutron256
neutron256's Avatar
I'm curious what sources for motors everyone has found. Like many of us I've been looking at motors on HobbyKing.com, but haven't found much else.
I'm also curious if anyone else is activly working on the hardware at this point.
Old 07-11-2013, 09:14 AM   #109
SloS14
SloS14's Avatar
I'm intrigued with the idea of running a bigger alternator in conjunction with a battery bank.
Old 07-11-2013, 09:30 AM   #110
Toma
At what mass flow? But it's probably close for 25# per minute.
An old friend of mine measured drive power required for a Vortech supercharger at about 500hp, and like 10 or 12 psi. It was something 40 hp! It's a very steep curve as you start to move some air.
Old 07-11-2013, 09:37 AM   #111
ML
ML's Avatar
Drives: 13 White MT FR-S
What about the turbo? what size? find one on CL and disassemble?
Old 07-11-2013, 09:51 AM   #112
neutron256
neutron256's Avatar
Nope you can get brand new just the compressor wheel and housing on ebay or Kinugawaturbo.com http://shopping.kinugawaturbo.com/. They run about $150-$200 for what we want. I've got a TD06 Housing with 20G Wheel on order right now. After doing further research I think a 25G is going to be better suited and I might try and change my order.
Edit: Link added to OP
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
