Old 02-17-2012, 01:32 AM   #99
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by Scion FR-S View Post
I doubt you tried deflating his tires anyway, since you're so convinced inflating them is the answer.
Explain the mechanics of how a tire that's rolling on its shoulder during cornering will provide more grip if you make it roll on the shoulder more. Thanks.
dsgerbc is offline   Reply With Quote
Old 02-17-2012, 03:12 AM   #100
frusciantrix
Drives: Mini R56 JCW
You can find out correct tire pressure by looking at the tire temperature (outer, middle, inner sector). There is no other way doing it right.
frusciantrix is offline   Reply With Quote
Old 02-17-2012, 03:51 AM   #101
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by Enemies View Post
That was actually my least favourite comment. I don't want to have to wear ear plugs to drive it. :P
I expect the noise was at WOT and even the MT with a 4.1DR has a reasonably tall 6th gear (for a small displacement sports car):
70 MPH ~ 3000 RPM
It ought to be plenty livable, though if your priority is quiet high speed cruising, a lightweight car like the FT86 isn't the best choice anyway.
Deslock is offline   Reply With Quote
Old 02-17-2012, 03:53 AM   #102
Allch Chcar
Drives: N/A
Originally Posted by SUB-FT86 View Post
This car will get over 30 mpg people so calm down. My RSX gets 33 hwy without direct injection and it doesn't have a better CoD than the FR-S.
It's best not to expect FWD MPG out of this but the MPG est(which is ) is roughly the same as the Miata. Those get good real world MPG from what I hear. Expect if the EPA MPG that (hopefully) it gets good real world MPG instead.
Originally Posted by mike2100 View Post
How about $22,250 + delivery so $23,125
$22,205 for a Civic Si Coupe
$23,450 for a base Miata
If the FR-S base price, before delivery, is above 24k I will eat my hair.
The 6spd is only available on the Touring, which is $25k. There isn't a base model for the twins so it's better to compare midrange.
$25k just means I need to wait longer before I buy one. As much as I don't like waiting, I'm still young enough to afford to wait.
Originally Posted by dsgerbc View Post
Autox-ing buddy's Prius when his regular car won't start, lol.
Look, there is a point when pumping further reduces tire grip, but it's not anywhere near stock psi levels.
Lol, do your research dude. They might not be as crappy as regular Prius, but they are nowhere near what people run on most Evos.
Heh. Autocrossing Prius.
Thanking for reminding them that the tires are not stock prius tires.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 02-17-2012, 09:18 AM   #103
tachi1247
tachi1247's Avatar
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
Originally Posted by nrclptcnsmniak View Post
Ummm am I misreading something. Space for a turbo and intercooler in the next few years? Do they mean aftermarket support or factory?
Both. Its no coincidence that this exact same motor will have a turbo added and used for the wrx. This has been discussed in numerous other threads. I believe that there is no way that turbo won't make it into a brz since it will be emission approved for the US. Adding that engine means this car can compete both with a miata and a 370z at similar price points to each.
Others on here believe that it won't be possible to fit the turbo or that it would compete with the wrx sti for sales so subaru won't make it. A few others believe that the car will somehow be ruined with the addition of more power because it will somehow make the car less fun or make it impure. I don't believe any of those statements.
tachi1247 is offline   Reply With Quote
Old 02-17-2012, 11:29 AM   #104
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
+1
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 02-17-2012, 02:02 PM   #105
Enemies
Drives: '13 SWP Sport-Tech (Limited)
70 MPH ~ 3000 RPM
Just didn't want to be driving down the highway to an appointment talking on the phone and it sounds like I'm in a Verizon commercial for the hard of hearing.
Enemies is offline   Reply With Quote
Old 02-17-2012, 04:21 PM   #106
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Originally Posted by delongedoug View Post
Yep. Evos generally run a few psi higher in the rear to help rotate.
Nope.
Funny thing...I've done this on my own auto-x cars, Formula SAE, Legends car, and on RPM's Grand Am Porsches. On the Hooters cup Car and for Craftsman Trucks we could simply pre-load the springs (handy)....guess all of us motorsports engineers have been doing it wrong.
It should be used as a fine adjustment, though you'll see some desperate measurements at your local parking lot race.
Homemade WRX is offline   Reply With Quote
Old 02-17-2012, 04:35 PM   #107
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I ran higher in the rear of my S2000, the infamous "wahhhhh it oversteers too much" car to get more rotation out of it. I determined that you had to be a tard to get an S2000 to oversteer uncontrollable..
So yeah, I agree with the higher tire pressures in the rear, all of my cars are setup like that.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-17-2012, 06:32 PM   #108
dsgerbc
Lol, pulling rank?
Didn't know there are people who do those on whimpy street tires with weak sidewalls...otherwise you should be smart enough to know when your knowledge is applicable.
Like I said - on decent tires it won't be true, since they have stiff sidewalls/wide profile etc.
Also, rear tires won't roll as much, so it's less relevant. Pumping front ones from stock psi will give you more corner grip. And again - does not apply to race/semi-race tires.
Old 02-17-2012, 10:11 PM   #109
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
*wakes up from forum slumber*
Did you guys even look at the 0-60? 6.0-6.2? That's freakin awesome for 26k! It's tiresome watching all these whiners wishing for 22-23k, this isn't a mustang; wake up people!
*returns on hiatus*
iff2mastamatt is offline   Reply With Quote
Old 02-17-2012, 10:51 PM   #110
BattleArmor
CarGuy
BattleArmor's Avatar
Drives: Honda Accord Coupe 5mt
Originally Posted by AVOturboworld View Post
Toyota's a little braver, or has better lawyers, or just hasn't had to deal with the last 10 years of kids buying turbo WRX's and crashing them into houses "when the turbo spooled at 12mph".
Regards,
Paul Hansen
www.avoturboworld.com
www.facebook.com/BRZSportsCarClub
Amazing NASIOC thread lol!
BattleArmor is offline   Reply With Quote
Old 02-18-2012, 10:25 AM   #111
Soravia
Drives: Miata Club
Is it me or the Subaru sits lower?
3x 240SX, RX-8 Sport, Sentra Spec V, A4 1.8T Quattro, Miata NB2, Miata NC 2.5
Soravia is offline   Reply With Quote
Old 02-18-2012, 10:42 AM   #112
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
*returns on hiatus*
First off the 0-60 is a estimate and secondly I don't understand how these guys are "whiners" for hoping for a 22k-23k car(I could understand under 22k now). This car isn't a 26k car unless it's coming with a good amount of amenities standard. The 26k is what I expect a BRZ Premium 6spd Automatic to cost.
SUB-FT86 is offline   Reply With Quote
86 forum, 86 forums, brz, brz club, brz forum, brz forums, brz fr-s comparison, brz site, brz versus fr-s, brz vs fr-s, fr-s brz comparison, fr-s forum, fr-s forums, fr-s versus brz, fr-s vs brz, frs forum, frs forums, gt 86 forum, gt86 forum, gt86 forums, scion fr-s forum, scion fr-s forums, scion frs forum, scion frs forums, subaru brz, subaru brz club, subaru brz forum, subaru brz forums, subaru brz site, toyota 86 forum, toyota 86 forums, toyota gt86 forum
2013 SCION FR-S Safety Audi Scion FR-S / Toyota 86 GT86 General Forum 14 01-17-2012 09:29 PM
2013 Scion FR-S: 10 Things You Don't Know (Maybe) - Insideline rmagic Scion FR-S / Toyota 86 GT86 General Forum 56 12-15-2011 06:36 PM
Full 2013 Scion FR-S Reveal Night Presentation Video Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-07-2011 03:49 AM
Motor Trend First Drive Review: 2013 Subaru BRZ Quantum BRZ First-Gen (2012+) — General Topics 41 12-05-2011 10:08 AM
