Old 09-26-2013, 06:51 PM   #99
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Squishy View Post
The only +38 I ever saw in RPF1's were a limited run of 17x8.5's and they list them but have none on the market I know of except that limited run.
I have 17x9 +35 and it will rub up front unless you get some negative camber (I am running coilovers with camber plates so it fits just right). In rear the 17x9 +35 fit flush already on 245/40/17 all around.
How much negative camber up front are we talking about to avoid rub on the 35 offset 17x9 say running a 245/40 0r 255/40? and lowering say only an inch.... any ideas?
Old 09-26-2013, 06:54 PM   #100
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
About -1.5* possibly even less.
255/40/17 below.
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-26-2013, 08:51 PM   #101
Squishy
Drives: 2013 WRB BRZ
255/40/17 below.
I would have to agree to the camber for the front clearance. 1.2 degrees and above are enough to clear the fenders when the suspension compresses (clarification assuming a 17x9 wheel in most cases - bigger will require confirmation as wheels vary alot). I am running Eibach Multipro R2 with about 1-1.25" lowered from stock and about 1.6-1.7 degrees camber up front and rear. Here is how it looks when loaded up in a corner and I do not rub at full steering lock either.
Squishy is offline   Reply With Quote
Old 09-26-2013, 09:41 PM   #102
OICU812
Just a dude
OICU812's Avatar
Squishy that's great info! Heck that makes me believe that a 18x9.5 40 offset may not need -2 either that's excellent!
Old 09-27-2013, 11:41 AM   #103
Squishy
Well with 18x9.5, -2 might be needed. You have to think of the inner strut clearance. Usually with that wide you need to look at the coilover clearance just as much as fenders.
At that size I believe it best to check with different wheels by experience as not all have the same layout with the rim placement despite the same offset.
Old 12-22-2013, 12:52 AM   #104
rickyb80
rickyb80's Avatar
Drives: 13' FRS-10 #0652
Wheel/tire fitment
Hi all. I just had a question and was hoping I could get an answer from someone regarding this.
I would potentially like to buy a set of Enkei RPF1's w/ some pretty sticky rubber. I am also looking at buying a set of coilovers and I realize that's going to change things up with camber settings and whatnot.
So, I'm looking at buying 17x9 RPF1's and I just wanted to know what size tire would fit and look nice and flush? Let's assume I go with wheels that have an offset of +45 (stock).
Sorry if I'm wasting time or duplicating another post but it's really late and I'm super tired, just wanted to throw this out there before it slipped my mind.
Thanks everyone!
2013 SC10N FRS - Takeda CAI, J2 FP, EVO3 CB, Front lip, side skirts, spats, Hotchkis FST brace, Grimmspeed MC brace/hood struts, Smoked Valenti Tail/Reverse lights, 30% tint, Perrin Antenna/drift knob/pulley, short shifter, AP knob, 86 armrest/doorsills/grips, and much more.......
rickyb80 is offline   Reply With Quote
Old 12-22-2013, 12:53 AM   #105
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
225 would be best IMO.
Chen is offline   Reply With Quote
Old 12-22-2013, 01:07 AM   #106
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Check out the rpf1 wheel thread. You can see what people have done. Personally I'd go with 245/40. I'd post the link but I'm super tired too.
eSOLOR is offline   Reply With Quote
Old 12-22-2013, 01:30 AM   #107
whataboutbob
AutoX-10/10ths every run
This.
http://www.ft86club.com/forums/showthread.php?t=7535
I'm on 17x9et35 RPF1s with 245/40R17 Dunlop Z2s with RCE yellows and Whiteline camber bolts and COMCs and everything fits perfectly. Check my build thread for pics.
Build thread:Here
Old 01-13-2014, 01:25 AM   #108
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
i have now noticed this wheel does rub and it actually hurt my wheel when pulling into my driveway because of the angle i have to pull in check out the pic i posted above if you look close to the edge of the inside of the rim you will see the silver line all the way around the rim
sorry if my info about fitment a few months back has caused anyone to buy these wheels and have the same issue
Lee358 is offline   Reply With Quote
Old 01-13-2014, 12:53 PM   #109
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
So it looks a little mixed, or maybe I'm missing something. I've been doing some research to see if some other Enkei wheels fit as 17x9 +45. I was told with coils there should be no issues with rubbing, so I'm thinking the ST coils because I only want that .8" drop. I'm hoping it works.
Nevermore is offline   Reply With Quote
Old 02-15-2014, 04:56 PM   #110
Cards2323
Drives: 2014 BRZ Limited-SWP
I'm about to purchase these but I'm a little confused....Do they rub or dont they? I plan on getting coils, just not sure which ones so should I be ok or what?
Cards2323 is offline   Reply With Quote
Old 02-15-2014, 04:58 PM   #111
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
They generally rub. It can be cured.
86•BRZ is offline   Reply With Quote
Old 02-16-2014, 10:05 PM   #112
Cards2323
I dont plan on emptying the bank on a coil set up. If I make sure the coils had a smaller body I should be good to go right?
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 04:18 PM
