Old 04-10-2019, 03:57 PM   #99
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Tristor View Post
You can check my build thread in post #64 where I installed the Shorai LFX36L3-BS12 + the PTuning Battery Tray. It looks a little janky, but basically there was a terminal offset bracket that came with the battery. You can install it in two different ways, I did it so that my negative terminal would be mounted horizontally instead of vertically since this made it easier to keep the harnesses out of the way. The positive terminal fit normally without issues.
Thanks, how did you get the positive pole connector to go deep enough to grab? They have to bottom out on the battery pole to grab.
Old 04-10-2019, 09:09 PM   #100
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
depending on how this necroed thread turns out i might do this since i left my trunk open for a week, killed my battery, and its never been the same since
Breadman is offline   Reply With Quote
Old 04-11-2019, 12:24 AM   #101
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
If I remember to do it tomorrow evening at the shop, I'll dismantle my battery setup and take pictures showing how it goes together. It was pretty straightforward.
I purchased this battery: https://www.amazon.com/gp/product/B005FIUMOG/
And these terminals: https://www.amazon.com/gp/product/B0002ZR4UC/
I don't remember which came with the L adapter which I used on the negative side, but everything was very straightforward.
Tristor is offline   Reply With Quote
Old 04-11-2019, 08:55 AM   #102
86TOYO2k17
Drives: 2017 toyota 86
https://www.ft86club.com/forums/show...128600&page=14
Give you ideas to making a mount, you can use factory tie down no problem.
you do not need the shorai tender go buy the harbor freight tender for like 6$ with a coupon it charges at a low trickle does the same thing for fraction of the price.
https://www.harborfreight.com/automa...ger-69955.html
I have had the battery for about a year now, used it all winter. if i know i am going more then 3 days with out driving ill unplug the battery, if i go a few days without driving and then find out i am going a few more like when it snowed all of a sudden, then i unplug put it on the trickle charger for a bit then hook back up once i am ready to use it.
I have also started my car 5 times in a row without driving or hardly idling with out any hesitation. The main issue is when your car has a slight draw of power even when turned off it will slowly drain it like an alarm system or maybe some remote start systems, the shorai doesn't hold a lot of reserve power. i try not to do short trips, but really if you did 3 - 5 minute trips in 1 or 2 days and then 1 - 15+ minute trip to recharge it should be fine, or if i know im not driving for a few days ill make sure to drive 15+ minutes before parking my car. A few minor things to consider but nothing that is really too much of a nuisance. The longer you have it and the more you "test its limits" the more you start to trust it and not worry so much.
Old 04-11-2019, 03:05 PM   #103
Mr_Eyo
Drives: 2017 Toyota 86
Thanks man
Imgur album:
Toyota 86 5lb Shorai battery https://imgur.com/a/gQvw9Fh
You can see the z bracket adapters in the battery, then I mounted the Oddesey terminals on top.
Mr_Eyo is offline   Reply With Quote
Old 04-11-2019, 05:20 PM   #104
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Mr_Eyo View Post
Imgur album:
Thanks, I appreciate the pic. I'd like to be able to go direct with battery poles. I'm looking for taller wider ones ATM.I haven't had much time yet but will.
Old 04-11-2019, 10:46 PM   #105
Mr_Eyo
Post your setup when it's done!
Old 04-11-2019, 10:59 PM   #106
new2subaru
Weight Weenie
Drives: 15 FR-S
Will do! I have to make so time to finish it up. I want to get driving it again!
Old 04-20-2019, 05:20 PM   #107
Breadman
Breadman's Avatar
my battery started to get weird again today so i pulled the trigger. Ill post updates when i get it installed
Old 04-24-2019, 10:41 AM   #108
toast
Drives: 14 BSP Edelbrock BRZ
Ran the shorai for the last 2 summers, take it out in the winter and replace with an AGM. So basically it has been used for about a year and it is already starting to fail - cranking in 60 degree weather is much slower than it used to be. Just FYI.
toast is offline   Reply With Quote
Old 04-24-2019, 11:27 AM   #109
RFB
RFB's Avatar
Drives: FRS
My experience is different, 5 years of street and track use, removing it when Canadian freeze arrives, and it still cranks the same.
Possibly because I keep it on the Shorai charger over winter.
RFB is offline   Reply With Quote
Old 04-25-2019, 05:17 PM   #110
Breadman
Breadman's Avatar
i just tried to install with those terminals and its 2 negative terminals... time for a refund
Old 04-25-2019, 05:26 PM   #111
Tristor
Tristor's Avatar
What do you mean 2 negative terminals? I can probably go take some photos right now of how it all goes together... but a bit of a description of your issue would be helpful. I order those exact items I linked off Amazon + the PTuning battery tray and got everything working fine.
Old 04-25-2019, 05:35 PM   #112
Breadman
Breadman's Avatar
positive terminals are a little bigger than the negative terminal. these are the same size. i thought "fuck it, ill try it anyway" but with the positive terminal clamp screwed all the way down it didnt even remotely clamp. looks like vendor is pulling a bait and switch. i got out my calipers and they are the exact same size unlike the oem battery
Bad battery 5hairpins Issues | Warranty | Recalls / TSB 3 02-25-2013 10:01 AM
Help with Car Battery Synack Off-Topic Lounge [WARNING: NO POLITICS] 0 01-13-2013 10:05 PM
Winter: Electric car & battery warmer install JSUB BRZ First-Gen (2012+) — General Topics 2 12-26-2012 10:55 AM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
