#99 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
I don't imagine heat sinks not attached to the coils would do anything, since they are designed to pull heat away from what they are attached to. Aluminum with heat shielding probably is the easiest route.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
| The Following 2 Users Say Thank You to Wonderbar For This Useful Post: | ATL BRZ (03-21-2014), gramicci101 (03-21-2014) |
#100 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Keep us updated, please. I'd really like to see this come to fruition. Everyone can benefit from this since both stock and modded/tracked cars have experienced premature coil failures with both OEM and aftermarket coils, specifically on the passenger's side. |
#101 | |
Off Topic
So the heat sink is not the primary means of reflection/dissipation. The outer, reflective surface of the heat shield is. The heat sink is there as a secondary or tertiary means to absorb and dissipate the heat once it starts soaking through and before it reaches the coils. Considering ATL BRZ's track usage and the fact that he's in Atlanta, I expect that the shield would start to heat soak after a while. Or it might be entirely unnecessary. But that's why I put it where I did. Edit: thought of an easier way to word it. The heat sink would be acting to pull and dissipate heat from the shield once the shield got heat soaked. So for the sink, the shield itself is the heat source. I would probably air gap it on small standoffs, to only absorb heat radiating off the inner surface or the shield. Last edited by gramicci101; 03-21-2014 at 04:00 PM. |
#102 | |
Troll Level: Expert
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
I'm thinking I'm going to order 4 injectors here real soon.
Nick K.
NASA ST5/TT5 #130 Southeast Region |
#103 | |
Drives: BRZ, STI, 535, Tiffin Allegro
I had the popping noise for about a day or two then I swapped coils and never heard it again. After a friends engine blew up while tracking and the carcuss was found to have a burned seal I started working to get my seals pulled. Two dealerships refused to help so I went to a 3rd party mechanic. CEL P0351 was the first code followed by some mis-fire codes when the popping noises were occurring. After the coils were replaced my engine ran for about a month on the track with a bad seal and no codes or no popping noises. Given I've seen my engine run with no codes and bad seals I now pull my injectors once a year and replace the seals just to be sure. Last edited by romin; 03-24-2014 at 09:24 PM. |
| The Following User Says Thank You to romin For This Useful Post: | forwallblakmail (03-24-2014) |
#104 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
What is the 'popping' noise associated with this? Do you hear it from the engine, exhaust? Is it loud?
#105 | |
The dealership was able to reproduce it by rocking the car back and fourth on a slight slope in first gear. |
#106 | |
They are two separate issues and not correlated as far as I know. @romin had these two issues back to back which may correlate them to those reading this thread but I'm not convinced that one caused the other. The detonation that leads to DI seal failure is caused by the older factory ECU tunes that didn't have transient ignition retard tables filled in past 5k rpms which allowed detonation between fast high rpm shifts and when the conditions were right (high cylinder temps, questionable octane pump gas) P0351 and the #1 coil going bad is most likely related to excessive heat breaking it down over time since it's in a spot with lots of radiant exhaust heat and not a lot of air circulation. That's not a proven fact, but there's plenty of supporting evidence in this thread.
#107 |
Dodging cones
I didn't think I had this issue, just wasn't sure what to look out for, should this occur.
I definitely agree about the heat. Most of my misfires were in warm situations (repeated hard pulls). Except one. 65 ambient. 55mph cruise control for miles. Drop to third, nail it, shift to fourth. CEL popped at 98mph. I believe I have a relatively up-to-date ECU flash. Either way, once the #1 was replaced, it hasn't returned. Car has been run HARD many time since. Hoping it stays away
#108 | |
| The Following User Says Thank You to romin For This Useful Post: | ATL BRZ (03-24-2014) |
#109 | |
Excessive heat very well may be a contributing factor to both issues being most commonly centered around cylinder #1, but we just have to be careful asserting that the two issues are correlated until a connection is made and evidence is presented to support it.
#111 |
We also could probably benefit from coils with heat sinks on them like these, but made for the FA20:
![]() Mojo Performance coil packs, sourced from a GM LSx engine, found in a 2JZ BRZ build thread.
#112 |
Drives: Rocket Bunny'd GT86
Been having this issue for over 6 months now, always ignored it since I barely do anything with the car other than casual driving but, anything WOT and over 6k RPM will set off this CEL and P0351 will always pop up. No popping, no strange sounds, no misfires, no leaks, no nothing, even when CEL is on the car is running just fine and not sluggish or anything, took it to the dealer and they were convinced that they have done what they can and CEL shouldn't come up anymore, 5 minutes later it did and I just ignored them since I know they won't do crap. Can I be convinced that this is an ignition coil faulty and just replace it?
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 06:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 06:29 PM |
