Old 07-30-2013, 08:44 AM   #99
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Where did you guys find this wheel in this size?
Wise is offline   Reply With Quote
Old 07-30-2013, 06:26 PM   #100
RavSpec
Drives: Rx7
We have them on sales here
http://www.ft86club.com/forums/showthread.php?t=23596
RavSpec is offline   Reply With Quote
The Following User Says Thank You to RavSpec For This Useful Post:
Wise (07-30-2013)
Old 07-30-2013, 10:24 PM   #101
Wise
Circle Work Clerk
Originally Posted by RavSpec View Post
You will be hearing from me very soon my good sir
Old 10-02-2013, 01:53 PM   #102
fosterspecial
17x9 rubbing question
So I searched and looked at others with this set up but I can't tell if this will be an issue. I have Gram Lights 57DR 17x9 + 38 with 245/40/17 tires. Car is stock height. It looks like the tire pokes out too much and I plan on putting Eibach Sportline springs on. My question is do the tires tuck in more when lowered? I see a lot of cars on here with this wheel set up and it looks like their tires are tucked in more. I don't want to lower this and then hit a bump and have it smash the fender. Any suggestions? Here is a pic.
fosterspecial is offline   Reply With Quote
Old 10-02-2013, 01:57 PM   #103
2pt5RS
Berz
The tires will tuck in more if you add camber bolts and add negative camber...but you'll most likely end up rubbing a little with that.
2pt5RS is offline   Reply With Quote
Old 10-02-2013, 02:09 PM   #104
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Not true at all.
I run a 17x9 +35 with 245/40s with -2degrees of camber up front when stock and no rubbing. with springs and konis Im running -2.5 up front no rubbing.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-02-2013, 02:11 PM   #105
B L U E S L A T E
Drives: BMW E84
I have 17x9.5 +40 and 255 tires with no problem... Only rubbing slightly under certain hard cornering situations. Though I do have -3 degrees of camber.
B L U E S L A T E is offline   Reply With Quote
Old 10-02-2013, 02:14 PM   #106
fosterspecial
How are you getting that much negative camber? Did you buy camber bolts or does lowering the car create negative camber.
Any idea how much bump travel these cars have?
Old 10-02-2013, 02:17 PM   #107
feldy
feldy's Avatar
I'm using whiteline camber bolts. Lowering the car also creates neg camber. I also run my wheel a lot closer then some would I have about two creditcards worth of clearance from the wheel to the upper strut perch.
Old 10-02-2013, 02:19 PM   #108
feldy
feldy's Avatar
some shots of the car. http://www.ft86club.com/forums/showp...&postcount=434
as you can see im not nice with it and I have no issues.
Old 10-02-2013, 02:33 PM   #109
nicamic
Drives: 2013 Subaru BRZ
rub
Did you remove the factory spacers?
nicamic is offline   Reply With Quote
Old 10-02-2013, 02:55 PM   #110
fosterspecial
I had these put on at Discount Tire? Are there factory wheel spacers?
Old 10-03-2013, 10:07 PM   #111
rainmonkey
Drives: BRZ - Dark Grey
I'm curious about this too - I have 57DR 17x9 +35 and am hoping to fit Michelin A/S 3 245/40/17 on em. a bit worried about the potential to rub n what not.
I have coils so I think I can add some camber to the front...
Factory spacers??
rainmonkey is offline   Reply With Quote
Old 10-03-2013, 10:20 PM   #112
B L U E S L A T E
Drives: BMW E84
OH I'm sorry... I forgot to mention that I have coilover with front camber plates and cusco rear LCA.
fit, oem tires, rims
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Gram Lights 57DR - 17x9+38 in Gun Blue 00vsmcoupe Wheels and Tires 17 01-08-2014 08:02 AM
WTB Gram Lights 57DR 17x9 +38 in Gun Blue or Enkei RPF1 18x9.5 +38 in SBC Shiro86 Want-To-Buy Requests 2 11-08-2013 10:18 AM
