Old 12-19-2011, 10:09 PM   #99
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Old Greg, I like you...you saved me from typing responses
Homemade WRX is offline   Reply With Quote
Old 12-19-2011, 11:47 PM   #100
ryude
Drives: Volkswagen GTI
Originally Posted by old greg View Post
That really depends on your goals and what you're working with. If you just want an extra 20hp from a 2L four, n/a will be cheaper and more reliable. If you want an extra 150 hp from that same engine, n/a will be jaw droppingly expensive and require daily rebuilds.
Ok, so here's why that makes no sense.
Throttle position %age is irrelevant, if you have enough excess traction to support, say, 40 ft*lbs of torque your tires don't know or care whether that's you at WOT or just 5% TPS. 40 ft*lbs is 40 ft*lbs. So in your example you have two otherwise identical cars in identical situations, both applying identical amounts of torque to the tires. Neither has an advantage.
At the corner exit, though, when traction is less limited, between two engines of equal displacement and equal peak power the turbo engine will have much more midrange torque. That means that (since both cars have identical gearing and corner exit speed) the turbo car will have much better drive out of those not quite 3rd gear corners you mention.
Um... Have you ever driven a turbocharged car? Even my car, which with its idiotic pre-turbo cat is actually fairly laggy, lag at ~4500 rpm is less than half a second.
And here's where you jump the tracks completely.
Lets say this N/A 2L has a few mods and is making ~220 horsepower. A turbo sized to make 220 hp on a 2L engine would be a absolute spool-monster with peak boost at 2500 rpm at most. The kind of turbo that needs 5000 rpm to hit peak boost on a 2L is capable of making ~600+ hp. No one in their right mind would use such a huge turbo to make 220 hp.
And it amuses me how you keep referring to 2005 as if it were some sort of automotive dark age where turbos were made from rocks or something. I mean, hell, the GT30 has been around since 2002/2003. It's not as if we're talking about the 1970's here.
My EP hatch Turbo didn't spool until 5000 and it was a 2L. It put down 320whp on a dynojet. The car was an 04, put the Turbo kit on in 2006.
ryude is offline   Reply With Quote
Old 12-20-2011, 12:51 AM   #101
old greg
Rocket Surgeon
Drives: PSM GGA OMG
You did it wrong.
K20 + PTE6262
EJ207 + GT3076R
old greg is offline   Reply With Quote
Old 12-20-2011, 10:43 AM   #102
Homemade WRX
B20?
What turbo and A/R?
You were doing it wrong or running a 'big' turbo at low boost...or had a crappy tuner.
My buddies 4094R on a K20 spooled that....slow it only made 780whp at 25 psi.
Old 12-20-2011, 03:00 PM   #103
Midnight Run
Action Thriller
Midnight Run's Avatar
Drives: E46M3
You did it wrong.
K20 + PTE6262
EJ207 + GT3076R
Midnight Run is offline   Reply With Quote
Old 12-26-2011, 01:16 PM   #104
Max Schnell
Drives: Lexus GS350 F-sport
The intake side of this car looks pretty efficient already. The air box looks like it is a vertical panel facing the front with a large intake pipe from the bumper area, K&N panel filter probably would be it. The elbow may be replaceable with a smooth elbow but does not pinch anywhere that I can see. Plastic composit manifold already has better resistance to temperature change.
DI may be able to open up some tuning possibilities though with leaner air fuel ratios without detonation. I don't know if the motor can rev any higher, that would be a easy tunable mod if the valve springs and rotating mass can handle it to push another 500-800 rpms out of the motor.
If the headers are already equal length I doubt there is much aftermarket headers will do.
High flow cat will be on my list because it will be usable either NA or turbo. Exhaust may help with the high flow cat combo but if the main restriction pre-exhaust is not removed it probably won't do much.
Max Schnell is offline   Reply With Quote
Old 12-26-2011, 01:56 PM   #105
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Homemade WRX View Post
B20?
What turbo and A/R?
K20A3.
I agree with the rest.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-26-2011, 07:20 PM   #106
NikostC
JDM Enthusiast
NikostC's Avatar
Drives: Scion tC
GT5 gives you about 11hp for a ECU upgrade... and im thinking thats about how much it would give IRL
NikostC is offline   Reply With Quote
Old 12-27-2011, 07:59 AM   #107
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
GT5 is a very credible source.
glorydays is offline   Reply With Quote
Old 12-27-2011, 09:07 AM   #108
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
LOL I like that post (at least I'm assuming that was sarcasm)
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-27-2011, 12:07 PM   #109
Levi
Drives: Toyota
Today ALL NA can get at least 10 PS/10 Nm just from ECU.
Levi is offline   Reply With Quote
Old 12-27-2011, 12:17 PM   #110
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
did tou read that on the internet?
Syldrin is offline   Reply With Quote
Old 12-27-2011, 01:29 PM   #111
fatoni
well he did say ALL you can get is at LEAST so i think he covered his bases in every single direction
Old 12-27-2011, 06:32 PM   #112
NA_T
NA_T's Avatar
Drives: E36
Am I the only one thinking about ITB's with a carbon airbox redirecting air from right behind the front bumper? Just dreaming.. sound would be epic and redline would definitly be alot higher! Woop!
NA_T is offline   Reply With Quote
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
Mods? Bruninho8 Scion FR-S / Toyota 86 GT86 General Forum 3 12-06-2011 06:11 PM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 11:58 AM
