Old 05-05-2015, 01:08 AM   #99
enivid
enivid's Avatar
Drives: WRB JR BRZED
Originally Posted by regandr View Post
Please let a former Skip Barber school instructor and 30 year SCCA racer (including a regional championship) make a few suggestions :
1. do absolutely nothing to your car before your first NASA or SCCA track day. that's right, nothing.
2. the reason for this advice is you need to experience what your car and YOU can do, right out of the box, before you make any changes
These are fabulous track cars - STOCK !!
Let me give you a real-world example:
I have run 44 track days in my STOCK BRZ. the ONLY mod. to this car is a set of BFG G-Force Rival tires. I regularly run at Miller M.S. Park in SLC with guys who have spent $10000 + on their cars for superchargers, coil-overs, wings, aero skirts, wheels, yadda, yadda. They are all SLOWER than, or only very slightly (in the dry) faster than my STOCK car !! and I am old enough to be all of their fathers !
All of them should have spent their hard earned $$ on a pro drivers school : Skip Barber, Bondurant, etc. and learned how to drive first. Any a__hole can hammer the throttle on the straight. You become smooth, fast and a much better driver in the corners.
I'm not an asshole.....I don't think....
enivid is offline   Reply With Quote
The Following User Says Thank You to enivid For This Useful Post:
JouMaSeHoes (05-05-2015)
Old 05-05-2015, 01:12 AM   #100
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
I would say that's the exact definition of "doing whatever you do". Tire guys use 32nds... ergo. keep doing whatever you do.
Took your original comment a different way.
Apex_BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Apex_BRZ For This Useful Post:
CSG Mike (05-05-2015), Special_K (05-05-2015)
Old 05-05-2015, 01:36 AM   #101
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
I hear you, the internet is full of enough angry douchebags, I try not to be one when I can help it. Cheers mate!
Special_K is offline   Reply With Quote
The Following 2 Users Say Thank You to Special_K For This Useful Post:
CSG Mike (05-05-2015), johhnc479 (02-07-2021)
Old 05-05-2015, 03:56 AM   #102
Originally Posted by zdr93523 View Post
@CSG Mike What's the typical time separation between the NA Stock class and FI Super Mod cars in 86 Cup? 8 seconds is about the average from what I can surmise. So, we're not exactly throttle hammering a___holes (like GTR & 911 Turbo drivers) like it has been insinuated.
If you're comparing the fastest unlimited class car, vs the fastest stock car (driven by a GT Academy winner), it's about 8 seconds on a 2 minute track. It's not a lot, considering the unlimited class cars all have 30k+ in them in just modifications...
The current (soon to be fastest) "most points" car is not quite dialed in, yet.
zdr93523 (05-06-2015)
Old 05-05-2015, 03:58 AM   #103
Originally Posted by stockysnail View Post
He must not be braking hard enough since my first couple times out I used the stock pads and had lots of fade as they got too hot.
On a side note Mike I have AX6 pads for the rear, but my fronts are shot along with my rotors (new stock rotors already installed). I'd rather just buy new front pads for track days for now until I save up enough for the AP racing endurance kit. I'm assuming XP10 is what you'd recommend for the front on RE-11a tires with 250whp? My rear AX6 pads have lots of life left.
Well, here's the dilemma. A more aggressive front pad means the front will be doing even MORE work, which means the rear pad will last even longer, because it's barely being used. Meanwhile, the front pad doing more work will soon be doing all the work (well like 95% of it) if you do a XP10/AX6 stagger, which results in faster wearing front pads.
How long did your front AX6 last you? I wouldn't recommend going more than a XP8/AX6 stagger, because the front bias will be massive if you go more than that.
Old 05-05-2015, 12:33 PM   #104
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I think the AX6 lasted 6 track days. The last track day was a double as I was sharing my car so it had back to back sessions. At the end of the day the front pads were very worn near the top and much less worn at the bottom. The top must have been getting really hot. The front rotors had spider web-ish looking marks all over them too. The last session the brakes felt like they were pulsing on their own, which I figured was the rotors were warped because of the heat. I'm sure the totally uneven pad wear didn't help as well. I guess that's what I get for doing double track duty, which is probably worse that 2 separate track days as the car has more time to cool off.
stockysnail is offline   Reply With Quote
Old 05-05-2015, 04:31 PM   #105
You definitely overheated the pads, based on the tapered wear and pulsing/shuttering. I'd recommend changing both front and rears to a race compound; the AX6 is really meant for AutoX and aggressive street applications only.
If you like the feel of the AX6, try Carbotech XP10 front/rear.
stockysnail (05-05-2015)
Old 05-05-2015, 08:20 PM   #106
regandr
Sorry guys from Miller. I had no intention of offending you. I like you guys and did not mean to imply any of you guys were posteriors. on the contrary.
I think you missed my point. Since lap times are very important to you (that's why you run in TT) and I couldnt care less about lap times (been there and done that), I suggest that everybody who wants to go faster needs a serious school. Not a NASA school, not an SCCA school.
Anybody who wants faster times needs to learn how to drive the corners fast. That's what they teach you. Anybody can hammer it on the straights.
I understand that you want to tinker with the cars. However, Andy(?) has made so many changes that he has messed up an otherwise great car.
A good school will also teach you how to analyse what a car is doing in order to set it up.
regandr is offline   Reply With Quote
The Following 3 Users Say Thank You to regandr For This Useful Post:
kravi (01-16-2016), strat61caster (05-12-2015), zdr93523 (05-06-2015)
Old 05-05-2015, 09:26 PM   #107
churchx
churchx's Avatar
Drives: 2014 GT86
Slight offtopic. Hmm, don't know about industry standards regarding measuring thread .. on this side of pond i am used to doing that in mm (and also have minimum thread depth specified in mm for winter/summer tyres in driving rules too). About only things that still are measured in imperial units in these metric countries are plumbing tubing sizing (including threads for them) and diameters of car wheels
Old 05-11-2015, 10:15 PM   #108
redlined600
redlined600's Avatar
Drives: Fr-s
Is the brake bleeding procedure for the twins standard furthest to closest or something weird?
Old 05-11-2015, 10:17 PM   #109
jvincent
jvincent's Avatar
Standard procedure.
Old 05-11-2015, 11:15 PM   #110
You can do it in any order really, if you're thorough.
Old 05-25-2015, 10:43 PM   #111
ka-t_240
Great advise, I would love additional instruction. I wish I had a resource like yourself locally with lots of track experience in a BRZ. I would love pro driving schools, but there are not any close enough for me to bring my own car to and I can't afford the $2k a day schools. If you have other ideas on schools that one can go to, I would for sure like to know! I like winter "racecations".
ka-t_240 is offline   Reply With Quote
Old 06-12-2015, 10:22 AM   #112
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Hey everyone, just looking to get opinions here.
I'm prepping my car for HPDE, track and autoX events which is the main reason I got the car.
So far here's what I have prepped before hitting out the first time.
Mishimoto oil cooler
Koyo rad - running water + Mocool
5w-40 300V - engine oil
Gear 300 - transmission oil
Gear 300 LS - diff oil
RBF660 - brake fluid
Ferrodo DS2500
Stainless brake lines
Stainless clutch line
Brake stopper
Aim Solo DL
Is there anything else I should have done to the car before hitting the track for the first time?
TRAKRAVN is offline   Reply With Quote
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 06:59 PM
prepping for winter Celica00 Scion FR-S / Toyota 86 GT86 General Forum 24 09-27-2012 09:17 AM
Prepping for rear spoiler install? zooki Cosmetic Modification (Interior/Exterior/Lighting) 2 09-02-2012 04:56 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
Clean & Dirty trueno86power Other Vehicles & General Automotive Discussions 1 02-07-2012 01:54 PM
