Old 06-07-2016, 01:10 PM   #99
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
What if one was to drain the fluid into a container, measure it exactly, and refill with the exact same amount?
Could you skip the whole level checking procedure? I'm looking into doing a 3x drain/refill here in the next few weeks, and I'm leaning towards trying that.
I have 12 qts of D6. I'm thinking using about half of it here soon, and then do it again in another 30k. (currently at 28k miles on the car).
Thanks
xsnapshot is offline   Reply With Quote
Old 06-24-2016, 11:40 AM   #100
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Ive been wanting to do this for a long time now but worried that I may mess up some how. For example going into the settings and putting stuff in an not correctly for like fluid amount. Also the pressure mode. Im just hitting 30k miles on my 2013 now. What my dealership told me is they havent done one before and made it sound like Toyota had to. I talked to a friend works in service at Toyota and said they wouldn't be able to do it because its a BRZ?
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 06-24-2016, 04:01 PM   #101
phrosty
It's part of their recommended service. They'll have to learn eventually, should already have done some by now...
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-06-2016, 12:45 AM   #102
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks
The whole "3x" method is more specifically to flush the torque converter out and make sure the transmission is up to temp so the fluid can easily pick up particulates and be drained, hence why checking the level is important with it.
Old 07-06-2016, 01:20 AM   #103
kaede1337
Drives: Silver '13 FRS
I think it might be ok to put in the exact amount that came out
kaede1337 is offline   Reply With Quote
Old 07-20-2016, 10:37 AM   #104
lupindub
Drives: Scion FR-S
Okay so every Toyota dealership I have called is telling me to change the ATF at 100,000 miles, yet the maintenance guide says to change it at 60,000 miles... which one is correct?
lupindub is offline   Reply With Quote
Old 07-20-2016, 11:08 AM   #105
phrosty
Every 30,000 miles.
Old 07-20-2016, 01:09 PM   #106
lupindub
Drives: Scion FR-S
Originally Posted by phrosty View Post
Every 30,000 miles.
Source?
Old 07-20-2016, 02:19 PM   #107
phrosty
Source?
If you're on this forum you probably drive a bit harder than your average driver the service manual is geared for.
A lot of people here have noticed their ATF is heavily darkened or discolored after 30,000 miles. May not be a bad thing, but it's certainly not a good thing .
Old 07-20-2016, 04:01 PM   #108
FRSBRZGT86FAN
Source?
Every 30,000 miles.
Phrosty is right believing your dealer for any maintenance intervals is a bad idea. A majority of the dealers treat the car like the other ones with "lifetime" fluids, this car doesn't have that sort of fluid or filter, nor does the manual say that.
At 30,000 miles you should get the ATF and differential fluid changed regardless, a lot of people have noticed both fluids wear badly when in a car thats driven like ours.
Old 07-27-2016, 04:30 AM   #109
kaede1337
anyone know of a good hand pump that fits the toyota ws atf bottles?
Old 08-30-2016, 10:19 PM   #110
SmireyFase
Drives: FR-S White - Smexy.
What's the general consensus regarding changing ATF oil, I needa change all my fluids in the next week. I keep hearing how dealerships might not know how to do this change... Also don't they charge extra to do any of this? Wouldn't it be better to take it to someone like evasive motorsports for things like this?
SmireyFase is offline   Reply With Quote
Old 08-30-2016, 10:24 PM   #111
phrosty
My dealership had no trouble doing it.
Old 08-30-2016, 11:45 PM   #112
ysu
Drives: Toyota 86 GTS Auto
From what I was reading (quite a lot of reading) just buy the stock AT fluid, it's prefect.
But if you'd rather save the hassles for yourself, for about $100 labour cost the service should be able to do it - properly.
I've opted for this option after all.
It'd be very-very weird if a Toyoda dealer's service could not do it.
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
