Old 11-02-2011, 02:39 PM   #99
Aki
Drives: '96 beater Corolla
But seriously, good job!
Thanks =) used to translate and write car specs for my previous gig, now I don't use my Japanese at all. (すごい残念) This allows me to keep my Japanese up. =P
Aki is offline   Reply With Quote
Old 11-02-2011, 02:41 PM   #100
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by tranzformer View Post
Mazda uses 12:1 in the new Mazda3 Skyactiv engine on regular gas (87 octane). Since this car is tuned for performance, it only makes sense that it will use premium and not regular grade gas. But it could be done as Mazda has shown.
There are many things about fuel matching that relate to performance. Octane is only one, and unfortunately manufacturers have to design around the fuels readily available in the countries of sale(and this is Japanese info, not NA info). But if Mazda can do high compression with regular then Toyota may be able too as well! It does make sense that dual FI with direct injection will allow much more finely controlled injection relative to combustion cycle which may minimize some of the more traditional causes of knock. Obviously if there is more power to be had in a BRZ it has to be extracted somehow? Besides the numbers may only be quoted based on premium which does not preclude the ability to run on regular with different performance numbers.
We will have to wait and see how this plays out?
smbrm is offline   Reply With Quote
Old 11-02-2011, 02:41 PM   #101
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
^christ! $400 intake? $1000 exhaust? BBK $3500
where do you shop?
WingsofWar is offline   Reply With Quote
Old 11-02-2011, 02:43 PM   #102
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by fred_boosted View Post
Sure, I know.
How much I willing to spend? Seats for $1600, wheels +tires for $2000. Coilovers: $1500, sway bars $300, brakes $3500, exhaust $1000, intake $400. Total is $ 8500
If turbo build. Intercooler + piping $1000, turbo $1500 (GT25), BOV (HKS SQV at home), Tial 38mm wastgate $200, oil lines & mounting & other shit. $ 500. Piston + Rod $1000. Total is $ 4200
Spec 3+ Clutch $500.
Labor : about 60 hours? $70 per hour means $ 4200
Total is : $ 16900
Do I have those much? No. 10K is my limit.
I doubt you'll ever do more than 1/4 of that list. Learn to do everything yourself and you'll save your $4,200. Skip a lot of the parts that aren't needed and you'll save more. Buy more reasonable parts in some cases and you'll save even more.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 02:43 PM   #103
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
12.5:1 is retarded. You don't need that much for direct injection on a gasoline motor. And with that much compression they should be getting more power... something seems amiss.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-02-2011, 02:45 PM   #104
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
where do you shop?
That all sounds about right to me but the intake should be $100 less and the BBK is actually more than that for all sides.
SUB-FT86 is offline   Reply With Quote
Old 11-02-2011, 02:46 PM   #105
Giccin
Giccin's Avatar
Dang. You really had to shove a lot of Kanji into your head for that. I need to start learning some important ones.. or at least the 800ish they ask you to learn minimum. :x
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 11-02-2011, 02:46 PM   #106
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by cyde01 View Post
skyactiv is actually 13:1. 14:1 in japan. that motor is frickin insane.
just noticed something:
床下フルアンダーカバー *グレードにより異なります
based on the grade, a full underbody diffuser is available!!????? that would explain the drag coefficient!!!!!!
Thanks for the info. Didn't realize that. I read a insideline article and they said it was 12:1 http://www.insideline.com/mazda/3/20...rst-drive.html
tranzformer is offline   Reply With Quote
Old 11-02-2011, 02:48 PM   #107
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
If he's going turbo he should be running a custom exhaust, not a bling setup. So that's about 200-250 in pipes and another 100 or so in a straight through muffler design. A lot less than 1k.
Most exhausts for this car that will be off the shelf type systems will be setup for the N/A motor until boosting it becomes popular.
He also didn't address the elephant in the room.. the ECU and finding a standalone to deal with DI.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 02:48 PM   #108
tranzformer
Drives: Zoom Zoom
Or wait for group buys.
Old 11-02-2011, 02:49 PM   #109
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Sure, for some stuff... I tend to buy the parts I know (through my own or others testing) will work instead of what's available in group buys though sometimes you get lucky though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 02:50 PM   #110
skinsfn36
skinsfn36's Avatar
Drives: 2006 Honda Civic Si
Also didn't address the turbo manifold, unless for some awesome reason an OEM EJ20 will somehow mate up.
If that works, budget turbo builds are easily doable.
skinsfn36 is offline   Reply With Quote
Old 11-02-2011, 02:51 PM   #111
SUB-FT86
86 Member
I know!!! He is in for a world of shit if he doesn't.
Old 11-02-2011, 02:51 PM   #112
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
where do you shop?
Those are based on my EVO X parts. HKS intake always $400. $ 1000 is the price of HKS cat-back, nice quality down pipe and High flow cat.
I could get Maserati Quattroporte or BMW M3/M6.
But I gived up.
Why? Because thats just not my style.
fred_boosted is offline   Reply With Quote
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 02:18 PM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 01:36 AM
86 Drag car?!?! MtnDrvr86 Other Vehicles & General Automotive Discussions 5 01-14-2010 06:35 PM
