Old 08-30-2013, 12:36 PM   #99
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by InYOHface View Post
how much are you rubbing in the rear? =\
i think 255 would have been the better option since the super sports run a bit wide
255 definitely would have been an easier option. I didn't think that upgrading wheels just to run a 255 would be worth it, so I really wanted the 265s even though I knew there would be rubbing. I have clearanced the rear bumper area where it meets the rear fender enough that I don't rub at all in the rear anymore while still running less than 2 degrees of camber in the rear.
Old 09-30-2013, 11:48 AM   #100
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Got the @JPM Coachworks shift boot and ebrake boot in Alcantara with red stiching for my birthday to match my already installed JPM gauge hood. I am going to win that Southeast 86 car show now.
Old 09-30-2013, 11:59 AM   #101
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Damnit Tut... I thought I had it wrapped up with the PU Front Lip...
Old 09-30-2013, 03:06 PM   #102
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Curious what current alignment is? I just had my coils installed I am at currently -2 all way around no toe. Guy that did my alignment did FU on front with way he did plates so its a free redo. I'm thinking of -1.8 in rear and -2.0 to -2.2 in front for abit more balance. I am 1.250" lower then stock on kwv3 and vorshalgg plates up front and want to fit a 40 offset 18x9.5" with 255/35/18 MPSS tires, think that'll all clear without modifications?
Old 09-30-2013, 03:11 PM   #103
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Alignment:
Front Camber: -2 degrees
Front Toe: Zero
Rear Camber: -1.5 degrees
Rear Toe: A little toe in
I think the 255 should clear everywhere except possibly the rear bumper tabs.
Old 09-30-2013, 03:16 PM   #104
OICU812
Just a dude
OICU812's Avatar
Alignment:
Front Toe: Zero
Ok thanks for that, I keep hearing about these bumper tabs, I am "pretty sure" I know which they are but unclear of how much to cut away on those sections? When you say in rear a little toe in, are we talking like 1/16th worth?
Old 09-30-2013, 03:19 PM   #105
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If you look where the rear bumper meets the fender you will see a plastic push pin fitting. I would wait till it rubs first, but most likely you will at least need to trim all the bumper material away inside of that fitting. 1/16th worth is correct.
Old 09-30-2013, 03:23 PM   #106
OICU812
Just a dude
OICU812's Avatar
Awesome thanks you've been very helpfull!!!!
Old 09-30-2013, 03:42 PM   #107
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I don't want to get into lolitics on here, but there is something seriously wrong with a government that is unable to sign a budget in over 4 years and that voted for mandatory cuts because of their inability to sign a budget. They keep spending like crazy, while we take pay cuts.
I hear all of you government workers (I assume you are government workers) I work for a provincial government in Canada and sometimes it is hard to explain or comprehend what is going on when politics are involved.
Old 09-30-2013, 04:05 PM   #108
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Funny you post this on the day before our government shutdown.
Old 09-30-2013, 06:27 PM   #109
OICU812
Just a dude
OICU812's Avatar
Alignment:
Front Toe: Zero
Sorry last Q on tire gig...
So with 265/35/18 you have no issues in rear as low as you are with -1.5 camber and no fender mods aside from that tab, is this correct?
Old 09-30-2013, 11:58 PM   #110
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I had to remove a lot of that tab and modify some of the metal structure on the fender in that area as well, and I still rub the tire sometimes under a lot of compression. The PSS 265s are rather wide.
Old 10-01-2013, 08:20 AM   #111
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
I've tried to find a pic of this tab. I'm abt to slap on 9.5" rims w/ 275 Hoosiers--I believe I'll need to do some trimming... loi
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 10-01-2013, 10:05 AM   #112
King Tut
NASA SpecE30 Racer
King Tut's Avatar
@Jive Turkey is the one that started calling it the bumper tab. It is the area that is 90 degrees from the side of the bumper where normally mud flaps or fender liners would mount. Under compression the side of the tire comes up enough to make contact in that area. Good luck with those 275 A6s, haha.
brz, king, limited, subaru, tut
Alex's 2013 WRB Subaru BRZ Limited Alex Member's Car Journals 51 01-03-2014 03:43 AM
2013 Subaru BRZ Limited Long-Term Test - InsideLine brianc BRZ First-Gen (2012+) — General Topics 0 08-01-2012 07:18 AM
2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review delta86 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-26-2012 03:25 AM
xcelir8brz's - 2013 Subaru BRZ Limited xcelir8brz Member's Car Journals 4 06-03-2012 05:44 PM
