Old 02-07-2023, 07:12 AM   #99
Ace23_BRZ
Ace23_BRZ's Avatar
Drives: 2013 Subaru BRZ
Made My Own SRS Delete Kit
After seeing the SRS delete kits out there, I decided to make my own.
I didn't feel too confident in the DIY kits I've seen, especially the ones that just shove the resistor in and tape it down.
I went with OEM connectors and the actual pin terminals for a TRUE plug-and-play type kit.
As shown in the image, I even used the sealing plug that was used in the previous connector as well...well, not that one, but the OEM sealing plug.
Ace23_BRZ is offline   Reply With Quote
Old 02-11-2023, 04:39 AM   #100
austin_ellas
Drives: Asphalt 2014 FRS
Do you have any documentation of the wiring you'd be willing to share? I'm doing something similar with my LS swap and any help would be appreciated.
austin_ellas is offline   Reply With Quote
Old 02-12-2023, 02:46 PM   #101
Ace23_BRZ
Ace23_BRZ's Avatar
Oh yeah, that's not a problem...
I am basically just using the OEM connectors as well as the appropriate pin terminal connectors as well.
OEM P/N - 90980-12697
Terminal P/N - .64mm / Sumitomo TS 025 Series male terminals. I went true OEM fashion and ordered the Gold plated terminals through Corsa-technic.
The best thing you can do if you have this chassis...study the wiring manual and the Toyota connectors manual.
Old 02-25-2023, 06:20 PM   #102
Ace23_BRZ
Ace23_BRZ's Avatar
Courtesy Light OEM Install
Got around to the doors this time around so I decided to install courtesy lights, however, the correct/OEM way.
While I was at it, of course I ditched the ugly ass OEM harness and made my own.
Using tefzel wire, brand new connectors, and pin terminals, I went ahead and wrapped it up in some contrasting tech flex loom...add a little bit of color lol.
I've seen some tap into the dome light, however the correct way is to follow the wiring diagram, which depicts the models with that light installed
Basically, all I did was purchase that 2 pin connector, the led lights, and wire it into the pre existing wire harness. Of course my model is missing those wires in the connector spot, so all I did was wire it in to those missing slots.
Old 02-25-2023, 06:35 PM   #103
Jdmjunkie
Drives: Scion FR-S 10 Series
I have wanted to do the courtesy lights for my car. You did a very good job.
Jdmjunkie is offline   Reply With Quote
Old 02-25-2023, 07:51 PM   #104
Ace23_BRZ
Ace23_BRZ's Avatar
LoL, yeah, it's also helpful having my car stripped down to the frame 😅.
But yeah, it's not that difficult...just plan it out and you should be fine.
Old 02-27-2023, 10:56 PM   #105
Ace23_BRZ
Ace23_BRZ's Avatar
Just know that when I am completely done with this bad boy, I will build another, however, it will be a full YouTube series, from beginning to end type build �� ��.
Also, if I find time, I'll try to incorporate more instructions on how I did the courtesy lights.
Apparently that install caught several member's attention, and they were interested.
In the meantime, I recommend downloading the wiring diagram manual and familiarize yourself with the circuitry.
Old 03-03-2023, 05:59 PM   #106
Ace23_BRZ
Ace23_BRZ's Avatar
3rd Times a Charm LoL
A Thing Of Beauty!
Trust in the process, and it will come together.
Done wiring my driver side harness in absolute stealth mode 🥷
Yes, the second or third time was a charm.
This time around, I am using tefzel wire and went with all brand new connectors.
Old 03-07-2023, 05:07 AM   #107
Ace23_BRZ
Ace23_BRZ's Avatar
Driver Door Harness Completed Today
So I finished my driver door harness today
Again, all new tefzel wire, connectors, pin terminals, and loom.
Up next, I still need to install my Focal door speakers, dynamat the door, then seal it with weather proof plastic.
One body panel at a time, but I'm chugging along.
https://www.instagram.com/reel/Cpegl...d=YmMyMTA2M2Y=
Old 03-09-2023, 05:38 PM   #108
Ace23_BRZ
Ace23_BRZ's Avatar
Trying to mess around with some trunk configurations...
Old 03-09-2023, 05:43 PM   #109
Ace23_BRZ
Ace23_BRZ's Avatar
Haha, then I gotta make room for these guys....
System schematics down below
Old 03-09-2023, 06:52 PM   #110
Ace23_BRZ
Ace23_BRZ's Avatar
Front Grill Delete / Carbon Fiber Stache Install
Working on this front grill delete...
Fitting my new carbon fiber bumper guard to match the rest of my CF 😍
Old 03-25-2023, 05:17 PM   #111
Ace23_BRZ
Ace23_BRZ's Avatar
Oil Cooler Kit
Working on my oil cooler kit install.
Customizing my vents to produce maximum air flow directly into my oil cooler kit 😎.
Old 03-25-2023, 05:30 PM   #112
Ace23_BRZ
Ace23_BRZ's Avatar
Relocation of Fusebox & VDC (ABS) Control Unit
Feeling out where I want to relocate these guys.
Still up in the air, but here are some possible spots ��
Ace23_BRZ Upholstered Interior...Upper 1/2 only Ace23_BRZ BRZ First-Gen (2012+) — General Topics 8 08-23-2022 01:54 AM
#LOLTraction: Maverick's More Organized Boosted FR-S Build #maverick# Member's Car Journals 43 09-20-2016 03:42 PM
My Build. Built, Boosted, Tucked and more Titanium than you can lift! Jesse@JDLAutodesign Member's Car Journals 38 05-09-2015 10:19 PM
My boosted build...on a budget PineappleFriedRice Member's Car Journals 95 08-17-2014 09:29 PM
mines13's living in the 90's boosted street DA build. My soon to be FRS driveway pal mines13 Other Vehicles & General Automotive Discussions 16 03-30-2012 03:30 PM
