05-22-2022, 08:03 AM | #99 | |
Drives: 17 Asphalt 86
May not seem obvious if wrenching years later but it's vital to keeping the strut happy when the top hat is secured and under load. You can see the tab missing from the strut |
The Following User Says Thank You to RToyo86 For This Useful Post: | norcalpb (05-23-2022) |
05-23-2022, 09:01 PM | #100 |
Drives: 17 BRZ
Question as I'm considering ordering B8s for my Spec R Swift springs. If down the road I decided to sell my twin... and I wanted to install my stock springs (STI Ts) would they fit? Would the added compression (I would assume) be a bad thing?
05-25-2022, 08:46 AM | #101 |
Go with B6 in that case. The extra droop travel with the B6 vs B8 shouldn't be an issue. Swift springs are designed to work with OEM dampers.
05-30-2022, 07:32 PM | #102 |
Drives: BRZ (in near future)
Any experience with the next gen BRZ and GR86? I remember they still use the same parts.
05-31-2022, 09:45 AM | #103 | ||
Almost better and will find time next week hopefully. Quote:
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | RToyo86 (05-31-2022) |
05-31-2022, 02:10 PM | #104 |
Drives: 2013 FR-S Series 10
Feel better Andrew, it hit me like a truck a few weeks ago. For a day i had an awful fever etc, but the back pain has not gone away. Hope you don't have any lingering effects.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
The Following User Says Thank You to Decep For This Useful Post: | Racecomp Engineering (05-31-2022) |
07-03-2022, 02:08 PM | #105 |
Replaced my old b6 struts with new ones, here is a picture of those “burn” marks.
I love how well new struts cancel out bumps that weak struts do not lol. |
The Following 3 Users Say Thank You to norcalpb For This Useful Post: |
08-18-2022, 05:45 PM | #106 |
Drives: Civic Type R
If I'm trying to make a simple FR-S/BRZ to take to the track, would the RCE Yellow + B6 suffice? I'm just trying to get into the sport and learn the ins/outs of HPDE/track days, not set any lap records or be competitive.
Disclosure: I don't have a BRZ/FRS yet. My plan is to eventually pickup an early FRS/BRZ, refresh the suspension, and leave the powertrain stock. It would only be to drive to track days and have fun. Most reviews seem to say people really enjoy the improvement, and it's how the BRZ should've come from stock. |
08-18-2022, 09:31 PM | #107 |
Drives: '23 BRZ
Absolutely. Will be a good setup but could be further improved with camber bolts to get a bit more front camber, and possibly Pedders top mounts to get a bit more, or camber plates to get more still. On a budget, IMO Bilstiens and RCE Yellows (or Swift Sport springs if you want to go a bit lower) and crash bolts and Pedders offset top mounts is gonna give a LOT of handling bang/$.
The Following 2 Users Say Thank You to ZDan For This Useful Post: | NorthernDriver (08-18-2022), Racecomp Engineering (08-19-2022) |
08-18-2022, 11:54 PM | #108 | |
I originally bought my daily (2020 FK8 Type R) to track it as well....but like it too much to risk any incidents at the track. So, I'm going to fallback to my second option at the time (FR-S/86) to satisfy the track itch...eventually. |
08-19-2022, 09:12 AM | #109 |
Agreed, Bilstein B6 with Yellows is a great easy solution for fun track time. Add the Pedders front top mounts and some camber/crash bolts and enjoy.
For wider tires or extra sticky tires then coilovers do make more sense, but if you want to keep it simple then you'll enjoy the Bilstein combo. Spend the rest of your budget on brake pads and mainetence stuff. - Andrew |
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
08-19-2022, 09:35 AM | #110 |
Thanks for the reply
09-14-2022, 07:06 PM | #111 |
Human
Drives: 2015 BRZ Black
Got some fun stuff in the works. Wish the RCE Rally X springs went through, but got the next best option.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
09-15-2022, 03:24 AM | #112 |
Drives: 2020 BRZ tS
People have commented that the B6's will raise a car lowered on springs.
I found even the B8's raised the right height coming from OEM shocks on Eibach Pro Kits. |
Similar Threads | ||||
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-04-2017 11:22 AM |
AVCS Explained | Rennmeister | Engine, Exhaust, Transmission | 3 | 03-15-2016 03:12 AM |
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts | FRSport.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-25-2016 12:50 PM |
Ok, who has stories that can't be explained? | husker741 | Off-Topic Lounge [WARNING: NO POLITICS] | 143 | 11-26-2014 05:25 AM |
Part of the problem explained. | Suberman | CANADA | 95 | 01-28-2014 01:26 PM |
