#99 |
Softparker
Drives: 2002 Mazda Miata
I'm content with NA, especially now that Yamaha is on board somewhere. Turbo would be nice to have the coolant and oil capabilities built in, but overall I think the NA will be safer for a brand new launch model. Works for the S2000 and Miata.
I'm not about to buy a brand new car and immediately start drilling into it while under warranty to toss a turbo in or swap engines. If everything with the car is in order, I'll drive it until the warranty is up, then maybe slap a Rotrex on it, give it a nice set of coilvers and sticky tires and call it good. Or trade it in on the next hottest thing out there. |
#100 | |
Kuruma Otaku
Because titanium. |
#101 |
4G63 & Rotary
It's stopped me. lol. Generally, the extra money needed to safely add boost to an NA motor is a deterrent. From a pure dollar-to-horsepower stance you get a better return on your investment starting FI and upgrading, than you do slapping on an afterthought turbo kit from random tuner. The motor wasn't meant to handle boost, usually yields bad results over an extended period of time.
Granted at a certain point every engine needs to be rebuilt to withstand more power, but a motor designed to handle boost will typically put that off longer. Just my $.02 |
#102 | |
Kuruma Otaku
And revs are harder on a motor than boost. I'm predicting neither in the final motor.
Because titanium. |
#103 |
Drives: '06 AM V8V Coupe
What he meant was, he isn't expecting 90mm stroke, since you can't really get much horsepower out of it if it doesn't rev.
With regards to your servicing stuff, how often do you even change spark plugs? A few more dollars * 4 cylinders every like 75k miles is not a big deal... Since you're clamoring for a turbo, have you considered that the fuel economy penalty, even with a fancy valvetrain such as Valvematic, would likely cost more than the cost of all these so called extra costs? And if you're complaining about needing to use Toyota brand fluids and parts, how does that not apply for your own dream motor? |
#104 |
Drives: Subaru Legacy
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
#105 | |
Site Moderator
Drives: ichi 86 Project
WTF is "Toyota brand Transmission fluid, toyota brand gear oil, toyota brand motor oil"? & you know how many times you actually change tran & lsd fluids in owning the car? RARELY for freaking DD car! Unless you freaking make this car into full track car. Scare of voiding the warranty? Cuz using different fluids and all other bs? Then you should be more worry when this car actually makes turbo ver. What the hell you gonna do? Can't even install turbo timer due to voiding the warranty. You can't do nothing to the car. Turbo model have stricter warranty than NA (there are certain exceptions GT3 vs GT2). As for "Asymmetrical rods =/= boost", where in the hell you get that bs? Yes, asymmetrical rods are bitch when it comes to boost more than some other engine design, but that doesn't mean they can't boost. Ppl do over 1000hp w H4 & H6. Even old EG33 can boost up to 450 w swapping pistons & rods to STi's. What, want stock? Porsche 911 GT2, Carrera Turbo, 911 Turbo, STI S series, they sure have enough hp along w good tq line. Don't bring false info |
#106 |
Site Moderator
Drives: Stuff
It depends.
If I buy an FR-S/whatever it'll be for a mix of daily driving and autocross. It will rarely (if ever) see track use as I have an ITR I enjoy driving on track, and a race car, so even the ITR rarely sees track time. For daily driver I like both NA and turbo cars. For autocross and track (not drag strip) I prefer NA just because in my experience they have more linear powerbands and are more predictable. I also like high revving engines and don't mind the lack of low end torque. With higher redlines you just make up for that in gearing, so the end result of wheel torque (actual, including the gearing, not what shows up on a dyno) is just fine.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#107 | |||||||
Site Moderator
Drives: Stuff
Very few people, and practically zero enthusiasts, will go to the dealer to buy most of those fluids, with the possible exception of trans fluid, if it works well. Otherwise, stick with fluids that meet the standards Toyota/Subaru lists. I change fluids in my cars more often than most, but even with 6-12k trans/diff flushes, it's not overly expensive. I flush trans fluid mostly because it breaks down and shifts get too notchy. Engine oil can be extended also, just do so intelligently and get oil analysis performed on old oil until you get to a good OCI. Quote:
Also, none of that will void the warranty. To void a warranty claim Toyota would have to prove (not say, be able to prove) that the non-Toyota SUGGESTED oil caused the problem. Now that's possible, if for example it required a GL-5 fluid and you used a GL-4 fluid. And of course it's possible if the condition of the oil, tested, shows that the oil was used for say, 50,000 miles in the engine and was never changed, etc.. Quote:
-Dave
#108 | |
Softparker
Now, the FT-86 might have some more difficult spark plugs to replace compared to the Miata, but I don't expect the prices to be all that different. And if it's worth it to me to do on my $8000 car, I'd sure as hell do it on a brand new one. |
#109 | |
Hot Dog
Drives: quicker than arghx7
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#110 |
Registered you sir
Drives: 99 impreza coupe
Well said Dave ROR, most of this stuff is pretty typical procedure for cars like this.
#111 | |||||||||||||
Site Moderator
Drives: Stuff
Christ, long post.
[quote[I'm well aware of control labs capable of analyzing oils at intervals..but the bottom line comes down to, it's a NEW car..and unless you don't give a rats ass about the warranty on a car that has a brand new engine format which for all discussion purposes has been unproven in long term usage....[/quote] Yeah, boxer motors from subaru (recast or not) are brand new. Quote:
I tend to change oil around 5-6k. I'm sure you know more than me, and more than people who make their living in the oil industry though. Quote:
Denying a hole in the lens because of oil? LOL good shit. I give you credit on coming up with this stuff.
-Dave
#112 |
Hot Dog
In Summary for Driftster:
#1: Cannot afford to maintain an N/A car, but turbo is no problem since it doesn't require premium fuel #1b: Cannot afford to maintain any car with "expensive" fluids, but buying a plethora of aftermarket products is not only easy, it's required #2: Is sick of being bent over at the dealership for "voiding" his warranty #3: Was involved in the Ford Raptor off-road excursion where he bent all the frames of the trucks involved #4: KNOWS how it works. Thanks for the laugh. Since you don't want an N/A engine anyway, don't let the thread hit you in the arse on the way out.
| Happy Thanksgiving!!! | S2KtoFT86 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 11-27-2010 07:01 AM |
| Happy Holidays, all | White Comet | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 02-12-2010 08:45 AM |
