Old 04-15-2019, 01:57 PM   #99
humfrz
Originally Posted by imprezive View Post
I'm open to suggestions, ……..
OK, since you like the platform and you're comfortable sitting in the car, I will wager that if you buy the car and after you drive it for a few months, the lack of throw-you-back-in-the- seat torque won't bother you any more. Likewise with the "torque dip", you will learn how to work around it so as you won't even notice it anymore.
Think of it as a lightweight, quick, economical sports car - in the spirit of the MGs, Triumphs and Miatas, that came before it. They weren't powerhouses, but they were sure fun to drive -
humfrz
Old 04-15-2019, 02:44 PM   #100
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Yoshoobaroo View Post
Real tires have sidewalls!
18s look too dubtastic on this car IMO. And correct, the larger diameter will increase the inertia of the wheel even with the weight drop.
Old 04-15-2019, 03:10 PM   #101
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I came from a 911 twin turbo and in many situations I enjoy the 86 more. You need to look at a car as a sum if it’s parts rather than one single element IMO
Old 04-15-2019, 04:53 PM   #102
86TOYO2k17
Drives: 2017 toyota 86
I'm open to suggestions, but I greatly prefer the sound of UEL, and I can't rationalize spending over $1000 on headers. Obviously the ACE product is an excellent piece of hardware, but the cost is double most other headers!
JDL makes a solid UEL.
Because NA has a limit and that limit is highly dependent on the header. The premium for the ace header is worth it. Also HP to cost ratio actually isn’t that much worse. It might cost 2-3times more then other headers but it will make close to double the power. Especially if looking at the accumulated gains across the entire powerband and not just the peak to peak numbers.
A lot of people try to save money on the most important peice of gaining power (the header) and then spend 800$+ on a catback for like 1HP and 2-300$ on frontpipe for maybe 2hp if it’s catless. 2-400$ on intake for 2-3hp And then spend 1,000$ on rims to save a few pounds. All of those combine for less of a difference as the same difference between an ACE vs competitor would make.
Old 04-15-2019, 06:47 PM   #103
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
First test drive. Feeling disappointed.
I'd argue that a Tomei header+flex fuel is a better way to get to the same power as Ace on pump gas.
1700 for header+600 for ecutek and tune =2300
700 for header+600 for flexfuel kit+600 for ecutek and tune =1900
I'll bet you those setups make damn close to the same power, and the Tomei header works with stock engine mounts. The Ace header doesn't pick up as much power with E85 as others.
Old 04-15-2019, 08:02 PM   #104
86TOYO2k17
Yes, like I said other people may argue bang for buck other headers/setups might be better. But the ACE isn’t that far off bang for buck because of how much gains it makes especially across the entire powerband. And when staying NA power is hard to come by.
And the dynos I’ve seen the ace picks up a good amount off E85.
If I only had 3k to put into this car I would probably do OFH+OFT tune, suspension and new tires. Probably net you the biggest gain on the track. But if your staying NA and have 5k+ to spend, I feel like the ace is the way to go. You need the power to make other mods become more important, like brakes, wider rims/tires, and aero.
Old 04-15-2019, 09:10 PM   #105
imprezive
Drives: 2017 BRZ - WRB - PP
Interesting comments, guys. Thanks. I'll have to look at some of the dyno charts again more closely.
imprezive is offline   Reply With Quote
Old 04-15-2019, 09:29 PM   #106
86TOYO2k17
Good idea. Just make sure to look at the percentage increase from baseline and not just the actual final number. As well as gains through the powerband not just peak.
Example 155whp base to 180whp after
Vs 170whp base to 195whp.
Both gained 30whp, 2nd has higher number, but first one gained a higher percentage. Some dynos can be deceiving at first glance.
Old 04-15-2019, 10:14 PM   #107
GrantedTaken
No, you actually need to go look at some Mustangs and Camaros.
You still do not understand this car. Come back when you are older.
Or learn to drive stick. This car is quite fast for those who know proper gear selection.
0-60 in 6 seconds is faster than most production cars.
GrantedTaken is offline   Reply With Quote
Old 04-15-2019, 10:15 PM   #108
jflogerzi
jflogerzi's Avatar
Those kinds of comments are not constructive...
2013 Series 10 FRS #553
Old 04-15-2019, 10:27 PM   #109
86TOYO2k17
What’s cheaper, making a 2019 mustang gt fastback, look, handle, and feel like an 86, or make an 86 as fast as a gt fastback?
Old 04-15-2019, 10:28 PM   #110
ermax
ermax's Avatar
Seems like someone else needs to grow up.
Old 04-15-2019, 10:34 PM   #111
jflogerzi
jflogerzi's Avatar
I like this line of thinking. This is exactly what I hope to do in a week
Old 04-15-2019, 10:34 PM   #112
falcon_wizard
Drives: BRZ 2013
I know you mentioned the desire to leave it NA, however in terms of value for money, you will get much more bang for the buck going FI vice a header+tune. If you are still looking at investing up to 10k in mods, then I would advise considering FI from a reliable shop that can offer you a reliable and tried turn key option.
After owning mine for 4 years and really enjoying it, I went with a turbo kit from a reputable shop in my area, and never looked back. You basically get a car like pretty much no other, with a unique combination of practicality, affordable ownership, power, handling, light/nimble and looks. I’ve owned it for 6 years now, and still always looking forward to drive it day in and day out.
Also, the trick to enjoying the brz it to regularly drive it above 4000rpm consistently, so the chassis is alive.
Cheers
falcon_wizard is offline   Reply With Quote
BRZ Test Drive Captain Snooze AUSTRALIA 3 09-28-2012 03:42 AM
The FR-S Test Drive Blackfly Scion FR-S / Toyota 86 GT86 General Forum 29 09-19-2012 09:17 PM
BRZ Test Drive davesrave New England 5 06-04-2012 12:00 AM
Test Drive brzmass12 BRZ First-Gen (2012+) — General Topics 8 04-12-2012 11:16 AM
FT-86 Test Drive knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 11-30-2011 01:43 AM
