#99 |
Drives: 13' Lightning Red Brz
Noob question, but after i had my recall done. Car is rough on cold start ups, and i have a knocking noise when warm after highway speeds but goes away when i start driving again. My friend says it sounds like a timing chain issue. Are the timing chains removed when doing this job? Also had my headgaskets replaced while i was getting the valve springs done. Is it a possibility my timing may be off? I’m also throwing a code p0016
#100 | |
They would for sure be removed for headgasket R&R. Sounds like you need to bring it back to the dealer and let them look it over. |
#101 | |
Is this something I should tell them when I bring the car back in Thursday? or should I let them pull the motor again and wait for what they say? |
#102 | |
Benz Tech
Drives: 2017 BRZ Premium
I wouldn't start off with "someone on the internet said it's the timing chain". |
#103 |
Yes, just relate the symptoms and ask them to "fix" it.
humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | ermax (03-05-2019), Ultramaroon (03-05-2019) |
#104 | |
Why did they replace your head gaskets? That isn’t part of the recall and adds a significant amount of labor. Did you pay them to do this? P0016 could be one of a million things. Bad OCV, contamination in the gears, bad cam angle sensor or bad ECU. There have been a bunch of people having damaged OCVs after the recall. It’s probably that. |
#105 | |
#106 | |
What did they change for the parts? |
| The Following User Says Thank You to ermax For This Useful Post: | why? (03-08-2019) |
#107 |
wannabe S2k owner
Drives: '13 Raven FR-S
*takes a Boxer engine apart for recall*
*car comes back 200 miles later completely fucked* Customer: Why did my car die? Toyota techs:
#108 | |
#109 |
#110 |
Which dealership was this at? I want to make sure I never go there for service.
#111 |
Rust bucket enthusiast
I implore everyone here to please refrain from disparaging specific dealerships or practices performed by your dealership. We're beginning to lose focus, this is a registry thread, not an experience thread. One of those has been created and I really ask for your help to keep this one clean as I suspect a lot of us will be referencing it. Should we expect them to take us seriously, let's present ourselves professionally and also show them respect.
http://www.ft86club.com/forums/showthread.php?t=133087 This seems to be a better place for briefing your concerns / inquiries about what service you were provided with. |
| The Following 4 Users Say Thank You to DarkPira7e For This Useful Post: |
#112 | |
| The Following 3 Users Say Thank You to ermax For This Useful Post: |
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
