69gtojeff, CT86, gravitylover
Old 03-18-2019, 11:07 PM   #99
kohner86
Vehicle Mileage: 67k
Vehicle Make: Subaru
Mileage After Recall Performed: ~20
Symptom(s): very loud clicking/rattling/knocking
Failure:
State: va
Is Dealership Offering Repair: hope so
kohner86 is offline   Reply With Quote
Old 03-19-2019, 01:00 AM   #100
BlackOptics
Originally Posted by msaikhan View Post
Pretty sure Toyota knows about this. I have 2 engineers coming from toyota to oversee my engine getting torn apart. And i heard from someone else that Toyota is coming to check his car. But this is after me complaining to corp.
They did the same thing for mine, but only checked how the valve springs were put in, and left it at that. Saying nothing was done wrong.
BlackOptics is offline   Reply With Quote
Old 03-19-2019, 07:50 AM   #101
ermax
ermax's Avatar
What a joke.
Old 03-19-2019, 09:09 AM   #102
msaikhan
Drives: frs
was your oil pickup screen clogged with sealant?
msaikhan is offline   Reply With Quote
Old 03-19-2019, 09:54 AM   #103
maslin
Benz Tech
Drives: 2017 BRZ Premium
Honestly, that’s probably the only part Toyota is worried about. If the updated springs are failing, they’re in trouble.
If the techs are butchering the work, that’s on the dealer. Toyota wrote a several hundred page picture book on performing this repair. If the techs can’t read, there isn’t much Toyota can do.
They just want to check the springs and walk away. Now it’s between you and the dealership.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Tcoat (03-19-2019)
Old 03-19-2019, 10:25 AM   #104
trave9161991
Drives: 2013 Scion FRS Asphalt
J02 Recall Registry
Hey guys, had the car in for the recall and had a CEL not more than 200miles after for camshaft positioning. Took it to dealer (ann arbor MI) and they said it was nothing they did. Bought new timing components (still on order) and tore the timing cover off in the car. Found sealant everywhere and the cam gear that was throwing the code (p0016) was set off one tooth on timing. I consider this a failure to complete the recall correctly. There was a lot of sealant in the pickup tube as well.
Vehicle Mileage: 157,250
Vehicle Make: Scion FR-S
Mileage After Recall Performed: <200
Symptom(s): CEL P0016/0011
Failure: No Failure
State: MI
Is Dealership Offering Repair: TBD
trave9161991 is offline   Reply With Quote
Old 03-19-2019, 10:31 AM   #105
ermax
ermax's Avatar
Failure: No Failure
State: MI
I hope you took lots of pictures. Or maybe even video where you pan from the VIN number and then over to the pickup so they can't claim you took photos of someone else's engine. I think for anyone looking to take this job in their own hands should get video of the whole process so they can't claim you opened the engine and threw shit in the pickup before taking a picture. I hope you got yours soon enough to avoid damage from starvation. They didn't set the chains right and packing in the pickup is all on them. They should be held responsible.
Old 03-19-2019, 10:51 AM   #106
maslin
Benz Tech
“Hey, you just had my camshafts out of my engine and now I have a check engine light for camshaft adjustment” didn’t work?
Drop the car off. Pick it up when it’s fixed. Raise hell in between.
The Following 5 Users Say Thank You to maslin For This Useful Post:
ermax (03-19-2019), HlfpriceWngs (03-19-2019), scottryan (03-19-2019), Tcoat (03-19-2019), why? (03-19-2019)
Old 03-19-2019, 10:52 AM   #107
HlfpriceWngs
HlfpriceWngs's Avatar
Drives: 2013 FR-S SWP
Originally Posted by HlfpriceWngs View Post
Looks like it's my turn to join the thread.
Vehicle Mileage: 162000~km
Vehicle Make: 2013 Scion FRS
Mileage After Recall Performed: Less the 300km
Symptom(s): Engine started knocking while decelerating, then shut off.
Failure: under investigation
State: Ontario, Canada
Is Dealership Offering Repair: Unsure/waiting for reply from service rep
I went in for the recall Monday March 4th. The work was complete on the 11th along my with my clutch, flywheel, throughout bearing, and spark plugs. Just 30 min ago my car died on the side of the road after a lot of clunking. I haven't even used half a tank of gas. The car was serviced at Erin mills Toyota in Mississauga. It being towed there now, I've left a voicemail with the service rep. I was contacted by my service rep this morning, and was told they will try to get the car looked at today. So far the dealership has been very co-operative.
All this before leaving on vacation next Monday.
Update : Was contacted by the Toyota Service rep. They have told me the motor was looked at, taken apart and the sealant isn't an issue. I find that strange because they've only had my car for a day. Currently the dealership is waiting for a response from Toyota before proceeding, but I get this feeling like they are withholding information from me.
The dealership is aware of these engines failing due to this recall, and that I've had 0 engine issue over the last 162000 km until they worked on it.
Before getting the recall work done, I was assured that they do these once a week and haven't had any failures.
HlfpriceWngs is offline   Reply With Quote
Old 03-19-2019, 10:58 AM   #108
msaikhan
Drives: frs
i advise you to go in there and look at it yourself and take pictures of how it was packed. Dealerships are sketchy as f*** from my experience.
The Following 2 Users Say Thank You to msaikhan For This Useful Post:
Old 03-19-2019, 12:54 PM   #109
ermax
ermax's Avatar
This this this!
Old 03-19-2019, 05:35 PM   #110
BikerBrad89
Drives: 2013 Whiteout Scion Frs
Failure After J02 Recall
Vehicle Mileage: 85000 Kms
Vehicle Make: Scion Frs
Mileage After Recall Performed: Around 250 Kms
Symptom(s): Low performance, Knocking then engine died
Failure: #4 Cylinder Rod Bearing Spun
State: Ontario Canada
Is Dealership Offering Repair: No they said it has nothing to do with the recall work and were going to charge me 6000 for a used engine and labor, or they would give me 6000 for the car as is for a trade in.
I took my car in right around the middle of January to have the recall work done, 3 days later I finally got my car back and everything seemed to be alright with it. Right around two weeks later I was merging onto the highway and notice I don't seem to have much power then shortly after I start to hear a slight knocking noise from the engine. At this point I am almost home so I keep going but the Knocking gets worse eventually stalling my engine. I tried to start the car again but it would not turn over so I ended up getting it towed to Toyota where they spent two days tearing the engine apart. They told me I had a broken connecting rod bearing and that it would have nothing to do with the recall work they did because the work was done on the upper part of the engine not the bottom end. After calling Toyota Canada Headquarters and getting a response of well if the dealership said its not from the recall work then there is nothing we can do, I ended up taking the car and the engine as they left it, and have been waiting for nicer weather to start working on the car myself. At this point though I wont be touching it until we hear something from Toyota about this whole mess. In the mean time I have had to start financing another car to have transportation again. What a nightmare I miss my car!
BikerBrad89 is offline   Reply With Quote
Old 03-19-2019, 06:43 PM   #111
ka-t_240
If you have the engine in pieces, can you take some pics? Bearings/Pickup Tube, Front cover, etc
Someone may be able to pick up what happened for help with the claim.
ka-t_240 is offline   Reply With Quote
Old 03-19-2019, 06:46 PM   #112
Open Loop
2013 FR-S Whiteout / SSC
The upper part of the engine work not causing botton end issues is obviouly a stupid excuse. I think they are trying to take advantage of you.
Open Loop is offline   Reply With Quote
The Following User Says Thank You to Open Loop For This Useful Post:
why? (03-20-2019)
fa20, failure, recall, spun bearing, subaru, toyota, valve spring
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 07:21 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-19-2019 12:24 AM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
PA Monogram Registry! kazetaro NY / NJ / CT / PA 0 06-06-2014 07:49 PM
Another Detonation thread. (DI failure related) Input Please. Thorpedo Issues | Warranty | Recalls / TSB 15 08-02-2013 08:23 PM
