Old 12-07-2018, 01:51 AM   #99
Originally Posted by Lantanafrs2 View Post
E85 gives 20 on it's own.
Not necessarily
Old 12-07-2018, 01:52 AM   #100
Interesting will need to be creative if no maf or map sensor used. What are they going to use for metering Air into engine with no pressure or flow data.
http://greddy.com/products/Special+V...rtnum=11910200
The info here suggests its compatable with stock intake so appears you could use maf, then second option was ecutek speed density which wouod use map pressure and temp.
So whats the advantage of using neither maf or map. ?
This would be for open trumpets, not with the provided manifold! With the provided manifold, you can use the stock MAF and MAP.
Currently, some fresh components are being swapped onto the motor of the NA test mule.
PulsarBeeerz (12-07-2018)
Old 12-07-2018, 08:20 AM   #101
StraightOuttaCanadaEh
Wes
60whp gains? Dyno before n after?
It's on his IG somewhere
Instagram: @gt86ws
Old 12-07-2018, 04:05 PM   #102
kch
Senior Misanthrope
kch's Avatar
Nah. More like 10-15. Same dyno, same car, same day. E12 vs E68.
The Following 2 Users Say Thank You to kch For This Useful Post:
DocWalt (12-07-2018), Trueweltall (12-07-2018)
Old 12-07-2018, 05:31 PM   #103
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
20whp is reasonable considering 91 shows up as 6-8% for me and e85 usually is around 78%. Plus others have different mods and different tuners.
Old 12-07-2018, 05:32 PM   #104
Irace86.2.0
I didn’t see it.
Old 12-08-2018, 11:16 AM   #105
Wes
I didn’t see it.
Message him. I'm sure he has dyno sheets. I'd just feel rude doubting him like that personally. No reason not to believe the dude imo
Instagram: @gt86ws
Old 12-08-2018, 12:50 PM   #106
Irace86.2.0
60 whp is possible. I’m curious if it was gained troughout the rpms or just in the dip. I’m curious if he was verbalizing the change from a peak low to a peak high, but those changes weren’t coinciding at the same rpm so not really a delta change.
Old 12-08-2018, 12:58 PM   #107
Lantanafrs2
Drives: 2013 frs red
60 whp? Doubt it.
Old 12-08-2018, 02:12 PM   #108
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
30ish whp with 91 and 35 to 45ish whp on e85
Dr. BRZ is offline   Reply With Quote
Old 12-08-2018, 03:01 PM   #109
Lantanafrs2
And that's with a header
Old 12-22-2018, 04:51 PM   #110
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
ANY CHRISMAS PRESENT?...
Old 12-22-2018, 05:03 PM   #111
Dr. BRZ
Dr. BRZ's Avatar
Give up on this and go with the revolution dual ram intake. Much cheaper and similar results.
The Following User Says Thank You to Dr. BRZ For This Useful Post:
Teseo (12-22-2018)
Old 01-22-2019, 06:52 PM   #112
Snake
Drives: ADM Toyota 86 GT
Whatever happened to this testing? Stopped, paused or didn't get any results?
Snake is offline   Reply With Quote
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
Delicious Tuning RallySTI User/Vendor/Sponsor Reviews, Feedback, Comments 2 12-02-2017 05:19 PM
Delicious Tuning needs your help! DeliciousTuning Off-Topic Lounge [WARNING: NO POLITICS] 0 08-14-2017 09:33 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
