Old 11-23-2021, 09:01 PM   #99
trxn
trxn's Avatar
Drives: 2017 Toyota 860
Andrew Yates Automotive 10.15.2021
Went to Subaru to pick up some parts for my friend's STI. Also went to Andrew Yates Automotive to pick up his car after a fresh motor rebuild with an IAG Stage 2 block.
trxn is offline   Reply With Quote
Old 11-23-2021, 09:10 PM   #100
trxn
trxn's Avatar
Clutch Pedal Stopper 10.19.2021
Old clutch pedal stopper got destroyed. I was supposed to change it when I did the manual swap but I forgot to. It was kinda hard to get the rubber back in, had to wet it with some water and pull on it from the other side with pliers.
Old 11-23-2021, 09:23 PM   #101
trxn
trxn's Avatar
Photos 10.20.2021
Old 11-23-2021, 09:43 PM   #102
trxn
trxn's Avatar
Video 10.21.2021
Old 11-23-2021, 09:59 PM   #103
trxn
trxn's Avatar
Photos 10.28.2021
Old 11-23-2021, 10:23 PM   #104
trxn
trxn's Avatar
Volks Racing ZE40 11.07.2021
Old 11-23-2021, 10:26 PM   #105
trxn
trxn's Avatar
Photos 11.12.2021
Old 11-23-2021, 10:49 PM   #106
trxn
trxn's Avatar
Volks Racing ZE40 11.14.2021
Got the tires finally mounted up at NTB Germantown. Would not go there again if you want your wheels to be scratch free. They chipped away the paint at the center of the wheel which is probably due to putting it on and off the tire balance. They also scratched the inner barrel at at a few spots. Also got new preprogramed Huf TPMS sensors off TPMS.com. The front fitment is as flush as it gets but the rear could use less camber.
Old 11-23-2021, 11:07 PM   #107
trxn
trxn's Avatar
Photos 11.16.2021
Old 11-23-2021, 11:09 PM   #108
trxn
trxn's Avatar
Photos 11.17.2021
Old 11-23-2021, 11:16 PM   #109
trxn
trxn's Avatar
Photo 11.17.2021
Old 11-23-2021, 11:21 PM   #110
trxn
trxn's Avatar
Relearning new TPMS ID 11.17.2021
Used a LAUNCH CRT5011E connected to the OBDII to get the ECU to learn the new TMPS ID's.
Old 11-23-2021, 11:22 PM   #111
trxn
trxn's Avatar
Various OEM Parts 11.19.2021
Replaced/Installed various OEM parts. Turns out I was missing a bolt that holds the brake/clutch pedal assembly and it would flex without the bolt so got a replacement bolt. The mud flap thing ripped a long time ago, tried to fix it but didn't work so go new one. New center console mat, misplaced it when doing the manual swap. Finally, new truck mat that says Subaru.
[IMG]https://uploads.tapatalk-cdn.com/20211124/07f1b78639b5f498db31***24df9f614.jpg[/IMG]
Old 11-24-2021, 12:56 PM   #112
trxn
trxn's Avatar
Diode Dynamics Tail as Turn 11.19.2021
Installed the Diode Dynamics Tail as Turn module which turns the brake lights also into the turn signal with a straight forward plug and play. This way I can remove the ugly yellow halogen bulb and replace it with a white LED. This kit can also turn the turn signal bulb into the reverse light but I decided not to since its cleaner with just the bottom reverse LEDs. Also didn't want to tap into the wires. I love the new turn signal look wish I installed it sooner, didn't know it was that easy to install.
S/O to Pranav for this gift
Lakitu's Toyota 86 Journal Lakitu Member's Car Journals 59 07-20-2025 04:39 PM
Koji's journal - 2017 Toyota 86 (Ablaze) Koji_Online Member's Car Journals 1 07-10-2017 07:36 PM
My Journal Weasel Soup Member's Car Journals 27 10-03-2016 04:07 PM
< RYO > Car Journal RYO Member's Car Journals 3 04-16-2015 12:48 PM
maydaydphan's FRS car journal dphan Member's Car Journals 3 03-22-2014 08:56 PM
