#99 |
Drives: 2013 frs red
Take out the motor and tranny
#100 |
Drives: 2017 toyota 86
#101 |
Drives: 2013 FR-S 10 series [755]
my car is about 100 lbs lighter, I cant say its faster, but I feel the car is little responsive and more predictable when turning.
#102 |
For anyone who cares. It’s 155 euro shipped for oversized coated (black or
Blue) alt/water pulley with belt. 10 euro cheaper for non colored. 206$ after exchange rate fees for 1.65whp. Or 125$/whp not too far off a lot of na bolt ons. Plus .7lb weight reduction! Lol. Still with no other performance/hp mods left to do not too shabby. Last edited by 86TOYO2k17; 07-06-2018 at 06:10 AM. |
#103 | |
Only happy when it rains.
Drives: series.blue
| The Following User Says Thank You to why? For This Useful Post: | new2subaru (07-06-2018) |
#104 |
Drives: 2014 GT86
For tracked car vents in hood are beneficial. And aftermarket hood with those looks much cleaner then modded stock hood (=possible reason to buy one). If not the high price of those though :/
#105 | |
Weight Weenie
Drives: 15 FR-S
Do you have a any links you can share? It would be the last thing on the list but still interesting |
#106 |
Drives: 2016 White Pearl BRZ Premium
Not specifically on a boxer engine, no. The vibration damage I was talking about was on large centrifugal fluid pumps, gas compressors, and their associated piping/equipment. It all takes a nasty beating when something is not configured correctly, or is out of balance. |
| The Following User Says Thank You to Joesurf79 For This Useful Post: | nikitopo (07-06-2018) |
#107 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
Not expecting much but if its 3-5lbs then its worth the +$200 bucks to me along with better cooling and an inch more space up front' Also we found that the Drivers side fan is the extra fan for AC equipped cars. So for someone like me who has removed my AC I could either A. Keep stock fan shroud and remove drivers side motor+fan B. Go Mishimoto but only use the passenger side fan either way it will remove weight from the heaviest part of the car (driver side front) Last edited by SuperTom; 07-06-2018 at 10:36 AM. |
#108 | |
#109 | |
#110 | |
I also saw the CF roof saves about 9lbs, Looks expensive though especially after you factor in this would need professional installation. The trunk is where we can do something as a DIY bolt on. Can't find any confirmed weights of stock trunk with stock boomerang wing. A real CF trunk while staying wingless should save a good chunk of weight, or adding back on a stock style or duckbill in real CF. The problem is most of these parts are sold to ricers who just want the cool appearance aspect. Its proving difficult to get any confirmed weights out there of the aftermarket trunks. |
#111 | ||
Drives: 2017 BRZ
http://www.ft86club.com/forums/showthread.php?t=25383 |
#112 | |
https://www.counterspacegarage.com/c...m-brz-frs-gt86 The Front Cusco ones are smaller at 16mm than 18mm but most sites say they are solid some say hollow can't confirm. Cusco site says hollow http://www.cuscousainc.com/965-311-a16.html Would be nice to find stock 18mm in Hollow. Don't feel the need to go bigger than stock on a 300lb lighter setup with semi-stiffer coilovers and stock width tires. Tanabe also makes hollow ones 22mm front 18 rear which might be the best bet to increase stiffness without adding weight. Eibach also makes some huge ones. They list the stock weight at 6lbs FR, 3.5LBS Rear. So overall wont be much weight to save. Even if the Cusco ones cut the weight in half you would only save about 4.5lbs total. https://eibach.com/us/c-262-product-...roll-kits.html Assuming Eibach's #'s are right on the stock weight I haven't been able to find anywhere else?? That's sucks for the Siebon CF no point in changing except Rice
| Understanding Fuel Trims | ShadowReaper | Software Tuning | 13 | 04-01-2018 01:34 PM |
| Understanding Compressor Maps | arthur93 | Forced Induction | 31 | 05-25-2017 10:49 AM |
| Understanding Oil | tofurun | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 06-10-2016 04:06 PM |
| BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" | GuerillaRacing | Wheels and Tires | 116 | 01-20-2015 07:32 PM |
| Understanding/clarifying vendor qualifications | mav1178 | Site Announcements / Questions / Issues | 21 | 03-18-2014 03:25 PM |
