#99 |
Drives: 2013 Raven FR-S
I've noticed the same thing about the throttle response. I've clocked 100+ miles on the new tune, but it still doesn't feel as responsive as v2.076. Thought it was my imagination at first, but almost stalled backing into my driveway last night.
#100 | |
Drives: 2016 Steel AT FRS
#101 | |
Drives: 2014 Dark Grey Metallic GT86
Do I take it from this that I can alter the CALID and run on a car currently using an A02G map? Excepting fuelling matters (obviously have to use the '91' not '93' maps) That's how it reads to me, but I don't really wanna risk a bricking. RR2ECUFlash worked a treat. I may run the defs all through it today and upload them here for everyone's benefit
#102 | |
Am I correct in this assumption? I mean, I've read so many times on this forum that you should check all the tables to make sure things don't look all wacky before flashing. Sounds like the advice should be, make sure the tables don't look all wacky if you plan to edit the table. Not trying to create any confusion around here. Just looking for a better understanding of how this all fits together. Any time I flash a rom I'm a bit stressed. A better understanding would certainly reduce my stress level a little. Hahaha |
#103 | |
Drives: 2013 GBS BRZ Limited
Some of us have used datalogs as a basis to make changes to our ROMs to fine tune them, in this case if you change the wrong table or put in an incorrect value by accident, you can cause issues or possibly brick your ECU. So in this case you would want to double check your changes to prevent any issues. I am by no means an expert so if someone with a better understanding can elaborate further on this it would be appreciated!
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
#104 |
Drives: 2014 FR-S MT
Yeah, unless I start hearing reports of how awesome v4 is after the ECU fully relearns, I see no reason for me to switch from v2.076. My car and exhaust setup ran and sounded great to me for the past year on it. My initial impression of v4 was pretty underwhelming.
| The Following User Says Thank You to H1C For This Useful Post: | Teseo (03-21-2018) |
#105 | |
#106 | |
#107 | |
Drives: UK GT86
Anyone who wants the def for the pre-MY17 cars you can get mine here: MT - A01G AT - A01I Just open up the xml file for A01G and then replace any instance of ZA1JA01G or ZA1JA01I with the CalID of the one for your car. Again, this is not for ZA1K00C/D.
.: Stealth 86 :.
#108 | |
#109 |
Drives: 2013 frs red
Kinda cool out right now on South Florida. God the car feels just right. Pulls so nice in low to midrange it's hard to believe it's just a 2 litre that breathes on its own.
| The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post: | Jasonb (03-21-2018), uppitypanda (03-22-2018) |
#110 |
Drives: 17 Series Yellow BRZ
#111 |
Drives: 2014 BRZ
Why switch codebase for earlier cars?
#112 | |
Saves havjng to have 50 different roms and defs for all the different years and countries badicly all roms and defs will be same except for calid changes, saves a lot of work and hassle |
| The Following User Says Thank You to steve99 For This Useful Post: | Baron_T (03-22-2018) |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 08:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 05:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 03:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 07:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 04:35 PM |
