Old 04-30-2019, 07:24 PM   #99
kch
Senior Misanthrope
kch's Avatar
Originally Posted by Sleepless View Post
I will redo this comparison with a different set of Solos to confirm these results.
My main issue with the Solo 2 is the unreliability of the WiFi. I wish they left the USB port as an option. Also, they seem to have changed the data format so third party tools don’t show the data correctly so I’m forced to use the crappy Aim Analysis
Is that why I'm having problems getting data into racerender? It will export CSVs but one separate file for each parameter, which sucks.
Old 04-30-2019, 08:24 PM   #100
@Sleepless would you mind emailing me the data from both? I'd like to compare, as when I've used both units simultaneously with a clear view of the sky, my data has never varied +-0.03
Old 04-30-2019, 10:40 PM   #101
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I don’t have the data. This was done at Pacific Raceways which has trees around it so can be GPS-challenging.
After a redo the test I’ll send you the data. I will use different units to help rule out a “bad” Solo 1. Stay tuned...
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
CSG Mike (05-01-2019)
Old 05-01-2019, 03:09 AM   #102
showrun
Drives: 2015 FRS
You doing ORP this weekend? I'll be there, hopefully with my new Solo2, if you wanted to compare two Solo2.
showrun is offline   Reply With Quote
Old 05-01-2019, 02:45 PM   #103
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I'm looking forward to your next test. I have never had an issue with my Solo1 at PR ever, ditto for all the other racers I know that use it as well. Never an issue with GPS either. I suspect there's something else afoot.
SCCA T4 - FRS
Old 05-01-2019, 03:45 PM   #104
kch
Senior Misanthrope
kch's Avatar
I'll also be there with my solo2
edit: although it's my first time at ORP so my data will be pretty useless
The Following User Says Thank You to kch For This Useful Post:
Old 06-21-2019, 01:15 PM   #105
sfruski
Drives: Many
Can you hard-wire a Solo 2 DL, or must you use the obd2 connector?
If you can hard-wire it, which cable do you use, the obd2 one with the end cut off, or the other CAN cable?
sfruski is offline   Reply With Quote
The Following User Says Thank You to sfruski For This Useful Post:
ka-t_240 (06-21-2019)
Old 06-26-2019, 03:17 AM   #106
You can splice the OBD2 version, or use the flying lead version. Your choice!
Old 07-08-2019, 12:42 AM   #107
redlined600
redlined600's Avatar
Drives: Fr-s
Is there a way to download data but keep it on the AIM device in order to keep the fastest lap (in the case of best lap of day reference).
Old 07-10-2019, 08:23 PM   #108
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Had a chance to compare several GPS-based units simultaneously at Pacific Raceways and the Solo and Solo 2 showed very similar results. I also compared to a VBOX Sport.
This testing was done with different Solo/Solo2 units compared to the previous tests I posted. I spoke to the person that did the initial test and learned that the Solo2 came off the mount during a previous session so there is some chance it is not functioning perfectly.
Conclusion, there is not difference in GPS performance between Solo/Solo2 (and VBOX Sport).
CSG Mike (07-10-2019)
Old 07-10-2019, 09:13 PM   #109
Sure is.
Download, and uncheck the "delete after download" box.
If the on-board memory fills up, oldest data gets overwritten first.
redlined600 (07-10-2019)
Old 07-10-2019, 10:49 PM   #110
redlined600
Drives: Fr-s
Sure is.
Many thanks!
Fwiw, my solo 2 dl has worked well so far. Also, user profiles ftw
Old 07-30-2022, 08:15 AM   #111
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Does anyone know if the aim solo 2 DL can read auto trans temps ?
Thanks
autoracer86 is online now   Reply With Quote
Old 07-30-2022, 08:15 AM   #112
autoracer86
Drives: Toyota GT86
Thanks
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 12:34 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
First FR-S in Ottawa Solo2 Event Klinn CANADA 0 06-12-2012 12:13 PM
