Old 05-16-2016, 03:05 PM   #99
ezion
Slowsauce
Drives: ‘20 S3, ‘13 FR-S
Originally Posted by guybo View Post
HP sells cars, torque wins races.
Signed,
Complete Bullshit
ezion is offline   Reply With Quote
The Following 2 Users Say Thank You to ezion For This Useful Post:
Blokatos (05-17-2016), Quentin (05-23-2016)
Old 05-16-2016, 03:27 PM   #100
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I'm pretty sure Enzo Ferrari knew more about engine power than either one of us. Enzo says torque is king then torque is in fact, king.
I'd rather the twins have 151 HP and 200 tq
Old 05-16-2016, 03:38 PM   #101
ezion
Slowsauce
If he really said that, context would be critically important.
Than either you don't know anything about engines, or you want your car to be slower.
A great case for this is the Golf TDI. It has nearly 100 more Tq than an 86, but 50 less HP. And even though the low torque feels great in the TDI, an 86 will obliterate it in a drag race because of its 50hp advantage.
Horsepower is only a function of torque and RPM. Look at diesel trucks to flesh this out. A ton of torque at low RPM is great if you want to pull a stump out of the ground, but while torque is twist, horsepower is the actual work being done. You have to spin the engine to some amount to create work. An engine that makes 300 torque at 2000rpm is making 114hp at 2000rpm. An engine that is making 300 torque at 7000rpm is making 399hp at 7000rpm.
Since HP and Tq are functions of one other through RPM, they're related. The fact is, being able to sustain torque through revs (horsepower) is what will make the engine propel the car faster, without fail.
Old 05-16-2016, 05:39 PM   #102
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
...torque is twist, horsepower is the actual work being done.
Horsepower = torqueXRPM/5252
billwot is offline   Reply With Quote
Old 05-16-2016, 05:59 PM   #103
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Funny .... when I think of Ferraris ... I don't think of torque monsters.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
Old 05-16-2016, 06:22 PM   #104
Ashikabi
Ashikabi's Avatar
Probably because they have crazy hp numbers too. I'm sure their torque is more than adequate
Old 05-17-2016, 10:20 AM   #105
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
That's actually a false statement. Both are forms of work one is rotational and the other is linear. In simple terms how I view torque vs power is:
Torque = Initial acceleration up until 5,252 rpm
HP = Top Speed/ acceleration after 5,252 rpm
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 05-17-2016, 10:51 AM   #106
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
This is actualy completely wrong. There is nothing special about the 5,252 number, nothing changes qualitatively about the engine operation at that RPM.
The fact that the curves "cross" at 5,252 means nothing, as each curve plots a different parameter using different units.
It's just a shorthand for calculation, resulting from using particular units for HP and Torque.
Power [in HP] = torque [in lb ft] X RPM/5252
If you used the civilized and scientific SI units, the factor is 9,549
Power [in kW] = torque [in Nm] x RPM /9549
If you expressed torque in lb in, again the factor would be different
Power [in HP] = torque [in lb in] X RPM/63024
mdm is offline   Reply With Quote
The Following User Says Thank You to mdm For This Useful Post:
Old 05-17-2016, 10:58 AM   #107
mdm
not a twin owner
mdm's Avatar
Even if you use lb ft and hp, it's perfectly correct to use different scale for hp and for torque - because these are different parameters. Andd in such case the curves won't cross at 5252 even if you use hp and ft lb, like in this example
Old 05-17-2016, 11:37 AM   #108
brandonblt2
I wouldn't say I was completely wrong I still stand by my thought process for torque and hp, one dealing with initial acceleration and the other top speed and acceleration afterwards. I agree as you indicated rpm cross over where torque and hp switch is a variable depending on the engine itself and not a constant that I thought it was.
Old 05-17-2016, 11:51 AM   #109
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I had a Golf TDI before the BRZ and I prefer the way things are now. The torque was nice but I always had to remember it wasn't as fast as it felt like it was going to be especially when merging onto crowded highways.
Scenic Driver is offline   Reply With Quote
The Following 2 Users Say Thank You to Scenic Driver For This Useful Post:
fang_gt86 (05-17-2016), Tcoat (05-17-2016)
Old 05-17-2016, 12:31 PM   #110
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
Tried to pass up a 92 accord to get to another lane yesterday... He took it personal and he stepped on it so i stepped on it and still didn't pass him. Ending up missing my exit. More horsepower wouldve been great.
VenomRush is offline   Reply With Quote
Old 05-17-2016, 12:37 PM   #111
Ashikabi
Ashikabi's Avatar
You got rekt by a stock Honda LOLOLOL
Old 05-17-2016, 12:38 PM   #112
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Well, that's when you're supposed to step on your brakes, slip in behind him, and exit.
shiumai is offline   Reply With Quote
The Following 4 Users Say Thank You to shiumai For This Useful Post:
fang_gt86 (05-17-2016), FX86 (05-26-2016), kritch (05-29-2016), Tcoat (05-17-2016)
Horsepower Chase1996 Engine, Exhaust, Transmission 32 03-08-2016 11:26 PM
Who says we need more horsepower? LeeMaster Scion FR-S / Toyota 86 GT86 General Forum 36 01-11-2013 12:05 PM
Bolt on 6 horsepower for about $50. MillersOilsUS Engine, Exhaust, Bolt-Ons 29 01-10-2013 09:53 PM
6 horsepower, 4 lb-ft from an oil change MillersOilsUS Mechanical Maintenance and Tools 1 01-03-2013 12:21 PM
ft86.com has some serious horsepower! MrBRZ Off-Topic Lounge [WARNING: NO POLITICS] 2 03-22-2012 08:45 PM
