#99 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
I'm really happy that my thoughts on the fork potentially causing TOB failure isn't too far-fetched and makes sense to others. Maybe I'm not so crazy after all .Pivot points and clutch forks just shipped out to FT-86 SpeedFactory so they should be in stock there shortly. We still have some on the shelf as well. Thanks, Eric |
#100 |
Drives: Scion FR-S (Hot Lava)
Received the pivot the other day. Looks great.
However, the pivot looks to be raw (no plating). Am I correct in this observation? Would you agree the part would benefit from a zinc plating or similar coating? I might throw it in our next batch of clear zinc that goes out at work when the opportunity arises. Just wanted to confirm. |
#101 | |
#102 | |
#103 |
#104 |
Swiss Alps Driver
Drives: Toyota gt86
I ordered mine!
Clutch and pivot, to go together with a new OS GIKEN grand touring dual disk clutch (ordered to replace a failed throwout bearing - as I need to open the gearbox, I decided to replace everything that could be replaced inside...)
| The Following User Says Thank You to vgarcin For This Useful Post: | VerusEric (07-29-2016) |
#105 |
Drives: 2013 FRS
Just wanted to provide some additional feedback now that the car is back together. I had quite a few drivability issues since getting my fx400 clutch and flywheel combo a couple of years ago. I'm very happy to report all these issues have now vanished with the install of the new clutch fork. The disengagement is smooth as can be now, there is no binding sensation on clutch in like there was before. Gears no longer lock out, and everything feels buttery smooth. Eric I can't thank you guys enough this fixed my car and made it drive like it used to on the oem clutch.
Mike |
| The Following 3 Users Say Thank You to mhiscott For This Useful Post: |
#106 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I got my South Bend Stage 2 daily clutch (with stock flywheel) and Velox clutch fork installed. Although I have no idea if the fork makes a difference in drive feel, I will say, it's a great reassurance for one less weak link in our glass transmissions! Also I didn't want to get it installed since it was just so pretty....
| The Following User Says Thank You to weederr33 For This Useful Post: | VerusEric (07-29-2016) |
#107 |
This is really neat to hear that our product is making this car "fun" and "driveable" again!
My experiences with the ACT Heavy Duty has been nothing but stellar. I've heard from other owners that theirs would chatter, have high RPM lock out (similar to @mhiscott experience), etc; but I've been extremely happy with its operation for the 2k miles so far. The clutch pedal is very linear and the clutch drives near OEM, just a tad bit heavier pedal. Thanks, Eric |
| The Following User Says Thank You to VerusEric For This Useful Post: | Drakiv (07-29-2016) |
#108 |
Long Distance Driver
Have not gotten the car rolling yet but pedal feel already while sitting is amazing! A lot more precise it feels. I will update later down the road
Running an OS Giken single GT clutch with their heavy, well built throw out bearing.
| The Following User Says Thank You to Sargy For This Useful Post: | VerusEric (08-15-2016) |
#109 |
Drives: frs
Installed.mfeels good, much more positive clutch response now, I have the slickest gear changes ever now.i believe as a result of this fork working without flex
| The Following User Says Thank You to twag4 For This Useful Post: | VerusEric (08-15-2016) |
#110 |
Currently using ACT street extreme clutch with regular(non lightened) flywheel(lighter then stock) and about 5k miles into using the clutch it is starting to lock me out of first gear(really annoying at street lights) any chance the fork might be the culprit? anyone else run into engagement issues and used this fork to fix? thinking of just ordering the damn thing and getting a new act or oem throw out bearing plus springs(retaining springs for the bearing/fork.
Also- i have adjusted the pedal multiple times to see if it would help and bringing the pedal way up helped for about 20miles then it started doing same thing so i adjusted the pedal again to where its about half an inch higher then the brake pedal. seems to be heat related as when its cold i have smooth engagements, once ive driven for some time and the car is hot it starts locking me out. |
#111 | |
#112 |
Drives: 2015 CWP Limited BRZ
How weak is the oem pivot ball? I just installed the fork and didn't even realize that velox even made a ball pivot until I had already installed the transmission.
addictedcollectibles.r/My IG
'86 E30 (Project) 'VARIS Widebody http://www.ft86club.com/forums/showthread.php?t=103676 |
| Verus Engineering Brake Cooling Kit | VerusEric | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 100 | 07-15-2023 11:18 PM |
| Modular Hood Louver Kit - Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 276 | 07-08-2023 05:03 PM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 10:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 02:44 PM |
| ▀▄▀▄ Vivid Racing | Cusco 86/BRZ Clutch Release Fork and Pivot Set | vividracing | Transmission and Driveline | 0 | 07-12-2016 02:32 PM |
