Old 06-27-2016, 04:53 PM   #99
Originally Posted by tdotBRZ View Post
Does it fit with Greddy/aFe Takeda air intake? (someone above mentioned it does not)
If not, does Jackson Racing dedicated oil cooler (for NA) fit with Greddy intake or they have the exact same connection as this dual kit?
I really want it but worried about fitment with my Greddy intake
That I do not know. Post a few engine bay pics from multiple angles, and I'll give you a best guess.
Old 06-27-2016, 07:51 PM   #100
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
tdotBRZ is offline   Reply With Quote
Old 06-27-2016, 09:55 PM   #101
Based on these two pictures, I'm gonna say it will probably clear, but with very, very tight fitment.
tdotBRZ (06-27-2016)
Old 07-01-2016, 10:36 AM   #102
OkieSnuffBox
Drives: '23 BRZ Limited
@CSG Mike
Do you think the dual cooler will suffice for an Edlebrock/JRSC kit on track? Assume hood is also properly ducted.
Old 07-01-2016, 04:06 PM   #103
Originally Posted by OkieSnuffBox View Post
@CSG Mike
It depends entirely on the driver, but for most, yes.
Old 07-05-2016, 03:42 PM   #104
Colin86
Drives: 86
I'm in the process of installing this radiator but noticed it doesn't have a foam seal around the sides/bottom the way the stock unit does. Should I try to seal the bottom/sides with something or install without?
Also, I'm struggling to find a way to route the shorter line such that it doesn't kink, is there a reason a straight fitting couldn't be used? Seems like a straight AN fitting from both the rad/filter side would connect right up and the house wouldn't have to bend down just to bend right back up.
Colin86 is offline   Reply With Quote
Old 07-05-2016, 03:46 PM   #105
It's "bent down" to clear many intake options.
Re-use the stock foam.
Old 07-05-2016, 03:58 PM   #106
Colin86
Drives: 86
Stock foam is glued onto the stock radiator and not easily removed, nor are there channels in the new radiator to install it. Do you have any photos of stock foam being re glued to the new radiator?
Are you able to send me an appropriately sized AN line with straight fittings? I'll pay for it of course.
Thanks!
The Following User Says Thank You to Colin86 For This Useful Post:
funwheeldrive (07-22-2016)
Old 07-22-2016, 09:54 AM   #107
alchemis
Drives: JDM Toyota 86 GT limited
i'm not sure if this question is being asked before.
1. does it fit well with any super charger kit ? considering there are a series of piping going on from the intake to the intercooler then to the charger unit and charger unit to the throttle body. particularly HKS V3 charger.
2. any difference with JDM models ?
alchemis is offline   Reply With Quote
Old 07-25-2016, 10:45 AM   #108
Reamer
Drives: 2015 FRS
I'm curious about the first question as well, except does it fit the Kraftworks kit?
Sent from my HTC 10 using Tapatalk
Reamer is offline   Reply With Quote
Old 07-29-2016, 03:55 AM   #109
alchemis
no one answering
Old 07-29-2016, 09:07 PM   #110
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
no one answering
Probably too new and too few people have it. Get the dimensions from Jackson Racing and compare to other units and you'll have your answers...
Sleepless is offline   Reply With Quote
Old 07-29-2016, 09:42 PM   #111
no one answering
Get me CLEAR, detailed engine bay pics, and i'll give you an educated guess.
Old 07-30-2016, 02:19 AM   #112
alchemis
The Following User Says Thank You to alchemis For This Useful Post:
Reamer (07-30-2016)
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
