Old 08-20-2016, 04:55 PM   #99
inferno56kb
inferno56kb's Avatar
Drives: GT86 raven
Originally Posted by SLVRSRFR View Post
You actually don't need to put anything back together once the spring is removed. You literally just take everything off, and then just drive. You're done!
The clevis and other related parts are simply there to connect the helper spring assembly to the clutch pedal; that's it. They don't actually connect the clutch to the car or really do anything else. Once the spring is removed, these parts are completely unnecessary, which is why a lot of people (including myself) opt to just not re-install the parts without the spring.
Hope this helps!
Ah alright, thanks for the Info. I actually thought it connects the clutch to the car XD will take off everything tomorrow then
inferno56kb is offline   Reply With Quote
Old 08-20-2016, 05:21 PM   #100
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
My pleasure! Good luck and enjoy it!
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 08-23-2016, 03:31 PM   #101
funwheeldrive
I've thought about doing this for years, and I'm still on the fence. I wish it was easier to reverse this mod. I just need to find someone who will let me drive their car I guess.
Old 08-23-2016, 03:43 PM   #102
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Road Trip to Tampa! I'll let you try mine out
Old 08-24-2016, 12:19 AM   #103
Inkluminati
Drives: 2016 FRS
I did this last weekend. The clutch is still lighter than my VW GTI VR6. Who did they think would be driving these cars? Ten year old girls? It's has WAY more feel to it now. I also adjusted the engagement point of the clutch and it feels like a new car now. Thanks for all the great photos and how-to's in this thread!
Inkluminati is offline   Reply With Quote
Old 08-26-2016, 04:19 PM   #104
SLVRSRFR
I think you should just do it.
Based on having read every single post in this thread before finally doing it myself, I read nothing but glowing reviews, and maybe one or two that were "lukewarm" ie not bad but not glowing either.
I did it finally, and have not regretted it for a moment since, over 30k km later.
DOOOOO IT!!
@bpennerz
Old 08-27-2016, 03:29 AM   #105
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I really don't understand why I would want a heavier clutch
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 08-27-2016, 01:22 PM   #106
SLVRSRFR
I find it's not so much that it's heavier, but more-so that you can FEEL it now.
With the spring in, the grab point was vague. With it out, you can feel exactly where it is.
@bpennerz
Old 09-06-2016, 06:32 PM   #107
Valfred
Friendly Person
Valfred's Avatar
Drives: CWP Aozora
Hi friend. I'm a car newbie so I was wondering if you want to help me remove mine? I tried removing it a couple of days ago but I simply couldn't figure out how to remove the spring...then I gave up.
Valfred is offline   Reply With Quote
Old 09-07-2016, 02:04 PM   #108
SLVRSRFR
It's not that tough. Honestly the hardest part for me was prying the clevis off of the post that it was mounted to on the pedal. That took a LOT of force, and cost me some skin from my thumb.
Otherwise it should be pretty straight-forward. Remove the e-clip, push the pin through, then pry off the clevis and remove the spring.
I can try to help, as you're pretty close-by, but my schedule is packed for the next few days.
PM me if you want.
@bpennerz
Old 09-07-2016, 02:36 PM   #109
Valfred
Friendly Person
Valfred's Avatar
Drives: CWP Aozora
PM me if you want.
I'd appreciate that! Whenever you're available. I'll bring some brews.
Old 09-25-2016, 08:17 PM   #110
jplake
Drives: 2016 Subaru BRZ - Limited
Does removing the spring cause slack in the clutch pedal when not in use?
jplake is offline   Reply With Quote
Old 09-25-2016, 09:02 PM   #111
guybo
Huge E85 fan!
guybo's Avatar
No
Old 09-26-2016, 09:46 AM   #112
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
So I learned to drive manual on this car and I'm actually pretty smooth rowing the gears after putting 70k miles on the car. Would it be worth taking out the spring if I can already shift smoothly?
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-14-2017 11:44 PM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 10:14 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
