Old 08-08-2017, 11:33 AM   #99
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
[ame="https://www.youtube.com/watch?v=hjGkUEjyCck&t=223s"]Chin Track Days Summit Point Main - A. Lutfeali FRS first 2 sessions - YouTube[/ame]
The 20 min mark is a good start.... car was without aero and we were dialing in the shocks (first time out with the new setup). Lots of corner entry understeer (due to -2.7 front camber) and later was trying to dial out the corner exit oversteer (surprisingly stiffening both front bump and compression from soft, fixed it).
Cheers,
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 08-08-2017, 12:41 PM   #100
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
Originally Posted by lutfy View Post
Spent a good bit of time over the weekend dialing in the car.
Height 13.5 front and rear. Front camber -2.7, rear -2.2 0 toe. Lots of corner entry understeer (slow speeds), high speeds the car had corner entry understeer with corner exit oversteer under throttle. Toodled around a fair bit with the dampers and later on threw the rear wing. It MAKES a difference for sure (need front end grip desperately, be putting the front splitter this weekend).
Even with the skinny 215 street tires, was able to clock 1:29:4 which is a full second faster over stock suspension.
Tire temps clearly showed f and r outside tires almost 20 degrees higher!!
What are you all running for camber and height? Am thinking of dropping to 13 inch f and r (to maximize rear camber as I dont have the control arms) and dialing the front up to -3.2
Lastly whats the take on running E85? Any issues on track? Have read fuel starvation. Car needs power now. Min required hp is 180whp and I am at 164 currently.
First time event VIR in 2 weeks. Be running 255 R888R then.
Lutfy
PS: BIG THANKS to Edgar Morales of Group E Motorsport (TTC contender) for the build out/data/track support.
Velox just released this to be a cheap solution to combat fuel starvation, not sure how effective it is.
[ame="https://www.youtube.com/watch?v=WNybNi1IheE"]FRS, BRZ, GT86 and WRX Fuel Starvation Fix - YouTube[/ame]
http://www.ft86speedfactory.com/velo...l#.WYnZ8ITyuUk
Freddy@PTUNING is offline   Reply With Quote
The Following User Says Thank You to Freddy@PTUNING For This Useful Post:
lutfy (08-08-2017)
Old 08-08-2017, 05:47 PM   #101
lutfy
lutfy's Avatar
Cheers Freddy! Ordered it. Doubt I'll get it for VIR but will have it sorted out soon
Lutfy
2022 LR Defender
2023 BMW M2
Old 08-09-2017, 05:13 PM   #102
Freddy@PTUNING
Lutfy
Sweet man. Wish I was going to be at VIR with you all
lutfy (08-10-2017)
Old 08-10-2017, 11:26 AM   #103
lutfy
lutfy's Avatar
There are 4 cars in TTD so tire contingency is ON! Cant wait for the first competitive event with this car. Need to dial out the understeer (splitter/camber).
Lutfy
2022 LR Defender
2023 BMW M2
Old 08-11-2017, 10:42 AM   #104
Freddy@PTUNING
Lutfy
Nice! TTC is looking pretty weak that weekend. Good luck man! I will be following on Race Hero.
Old 08-20-2017, 07:43 AM   #105
lutfy
lutfy's Avatar
Very pleased with the way the car turned out. Opted for chassis vs power/Hoosier.
2915lbs / 164whp.
2022 LR Defender
2023 BMW M2
Old 08-20-2017, 11:10 PM   #106
lutfy
lutfy's Avatar
Got down to low 2:14s. Not doing anyting more to the car till rules change.
Much pleased with the chassis. Thanks to Edgar for all the hard work building this...
[ame="https://www.youtube.com/watch?v=TBOJLtnw6-c"]NASA TTD 2:14 Ahmad Lutfeali Toyota 86/FRS - YouTube[/ame]
2022 LR Defender
2023 BMW M2
The Following User Says Thank You to lutfy For This Useful Post:
endless_pain (08-31-2017)
Old 08-22-2017, 05:14 PM   #107
Freddy@PTUNING
That's flying dude, good work!
NASA TT - how do you do it celica73 Tracking / Autocross / HPDE / Drifting 3 09-11-2014 10:14 PM
Joining the NASA cjsporl1996 Tracking / Autocross / HPDE / Drifting 33 12-26-2013 05:51 PM
NASA made me do it robispec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 04-05-2013 12:48 AM
NASA-x at MIR with video about350 Tracking / Autocross / HPDE / Drifting 2 08-11-2012 11:42 AM
