Northern California NorCal
finch1750, go_a_way1, undefindedt
Old 09-07-2017, 08:48 PM   #11173
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Hmmm -1.4 deg doesn't sound so agressive (spec is -1.2 +/- 0.75). The two times I've had my toe go out of whack, they were uneven from side to side. Is the wear symetrical ie same on both sides?
My layman understanding of camber for performance driving is that it increases the contact patch during cornering. So my guess would be having more camber in the rear (relative to the front) would lead to more understeer, you want to limit it to improve rotation.
This matters more for the front than the rear. The front's gain positive camber on turn in, so more negative camber results in more of a front contact patch while cornering.
The rear camber doesn't change too much under load, so anywhere from 0.0 to -2.0 is ideal depending on personal preference.
I am sure there are some grip set ups that purposely run more negative camber in rear than that, but I can't recall any off the top of my head. Usually drifters and stance guys run a lot of it for the benefit of fitment and less contact patch so the wheels spin easier.
JeremyR is offline   Reply With Quote
The Following User Says Thank You to JeremyR For This Useful Post:
Clipdat (09-08-2017)
Old 09-08-2017, 12:28 AM   #11174
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Good news. Talked to the mailman and we figured out he delivered it to the wrong house. Got it from the other street and all is good
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
Kaotic Lazagna (09-08-2017), My Key (09-08-2017), sugoi (09-08-2017)
Old 09-08-2017, 12:46 AM   #11175
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
Got a popping sound coming from my rear right and cant figure out what it is .... I hear it only when I make turns but not when im driving straight
thecarfilmer is offline   Reply With Quote
Old 09-08-2017, 01:26 AM   #11176
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I get the same noise too. I hear popping every time I let off the gas or upshift..😉
But seriously, is it more likely to make the noise when you turn one way or the other? Going over bumps? Does it sound like it's coming from the inside of the car or out?
When did the off topic chat thread turn into cartalk?
The Following User Says Thank You to BigFatFlip For This Useful Post:
thecarfilmer (09-08-2017)
Old 09-08-2017, 03:23 AM   #11177
finch1750
finch1750's Avatar
Change your tune
Old 09-08-2017, 04:14 AM   #11178
Kaotic Lazagna
Drives: GR Corolla
Check for any loose bolts/nuts, specifically the sway bar end links.
Old 09-08-2017, 04:35 AM   #11179
strat61caster
strat61caster's Avatar
When the main board turns to shit and when the technical boards are too daunting if you haven't done every single suggested thing in a thread that's vaguely similar that's 3 years old.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
FirstWinter (09-08-2017), JeremyR (09-08-2017), spike021 (09-08-2017), sugoi (09-08-2017)
Old 09-08-2017, 01:13 PM   #11180
My Key
My Key's Avatar
Drives: 2017 Toyota 86 - Raven
I get this weird roaring sound whenever i put in the key and rotate it clockwise. It only ever happens when I rotate it clockwise.
My Key is offline   Reply With Quote
The Following User Says Thank You to My Key For This Useful Post:
finch1750 (09-08-2017)
Old 09-08-2017, 01:42 PM   #11181
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Install push button start.
Originally Posted by humfrz
I'm old and lazy
My Key (09-08-2017)
Old 09-08-2017, 02:17 PM   #11182
BigFatFlip
BigFatFlip's Avatar
Just updated my pixel to Android Oreo and really hating the over all "light" theme. I want my dark theme back...
Old 09-08-2017, 02:20 PM   #11183
Clipdat
Proud of BOXER
Clipdat's Avatar
I'm old and lazy
Old 09-08-2017, 02:23 PM   #11184
strat61caster
Screw Oreo, I'm keeping my blob emojis. I'd use 5.0 emoji if I could.
ineedyourdiddly
Old 09-08-2017, 02:39 PM   #11185
BigFatFlip
BigFatFlip's Avatar
I just noticed that...dammit I want my blob emojis back too
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
PandaBRZ (09-08-2017), strat61caster (09-08-2017)
Old 09-08-2017, 04:46 PM   #11186
Kaotic Lazagna
Drives: GR Corolla
My LG G3 (yes I know it's old) never updated Android systems even once, yet my bro's G3 had at least one OTA update, and we got our phones the same day from the same place.
Manually trying to update it doesn't work as it just says it's up to date.
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 01:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1398 02-08-2019 02:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 02:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-09-2013 12:07 AM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 01:38 AM
