Old 09-25-2018, 12:15 PM   #1093
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Does anyone run an EL JDL V2 setup? Curious to know what the differences are in the power delivery.
mistople is offline   Reply With Quote
Old 09-28-2018, 03:29 PM   #1094
mrloko
Drives: 2017 Subaru BRZ
I'm getting the same 3' dezod by mid october, it's already ordered! you should post a video to hear it. I will too!
Originally Posted by mistople View Post
On stock tires! Skiiiiiiiiiirt.
Really interested in your thoughts on the kit once you've owned it for a while. I want to track my car with this kit, but have only seen a few owners use it long term under super stressful conditions. Are you planning to wring it out regularly?
This kit is excellent @mitople i've had it for 1000 miles and everything is great. I recommend the ceramic coating because it really helps keep temperatures down. i don't see a need for exhaust wrap if you get ceramic coating
mrloko is offline   Reply With Quote
Old 10-22-2018, 12:42 AM   #1095
OzzyGT86
OzzyGT86's Avatar
Drives: Ultramarine GT86
I am running an EL V2 kit sir!
OzzyGT86 is offline   Reply With Quote
Old 10-22-2018, 01:39 AM   #1096
CHMBRZ
Drives: 2016 Subaru BRZ Limited
How’s it sound and run with the EL manifold
CHMBRZ is offline   Reply With Quote
Old 10-29-2018, 08:08 AM   #1097
dkstylezz
dkstylezz's Avatar
Drives: 2013 Subaru BRZ
Installed kit and having boost creep.
Had a EBC but took it off to figure out why its creeping.
Currently the bottom port of the turbosmart wastegate is directly connected to the turbo housing port.
Spools up real fast and goes past 7 psi and i see up to 12 psi around 4.5 to 5k rpm also seems like it would keep going up if i kept my foot on the pedal but dont want to risk anything further so i would let go.
Double triple checked the routing for wastegate to turbo and its hard to mess that up as its one hose from the gate to turbo. and i made sure its the bottom port.
Spoke to jdl and agreed to take out the waste gate spring to keep the gate open and it was building boost up to 8psi at past 6k rpm with the wastegate fully opened.
Wastegate had a brown and purple spring witch should be a 7psi spring.
Used an air pump with a regulator and tested the waste gate bottom port to see when it starts to crack open the gate and its around 7psi ish and has to hit up to 20 psi to fully open the gate. Should i be making boost with fully open wastegate? or is that not normal.
Set aside the waste gate pressure test. As i mentioned above took out the WG spring completely to keep the gate open and it was still building boost.
Engine is fully built by Blue moon performance. forged internals with 1mm larger valves. Intake and exhaust port matched for better flow. which i don't know if that would contribute to overboosting or creeping.
No cats in the exhaust with tomei op HKS dual resonated fp and ark dts exhaust.
Any input or suggestions on why i might be having such extreme boost creep?
Last resort from JDL would be getting bigger wastegate installed but they also mentioned it seems quite strange that I'm having such boost creep with my setup.
dkstylezz is offline   Reply With Quote
Old 11-21-2018, 03:57 AM   #1098
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Drives: 2014 Crystal Black Silica GT86
Hi Guys
Im have and UEL V2 turbo kit with GTX 2867R gen2 turbo ,my engine is stock,i have AEM EBC
My tuner gave me 4 maps on 7psi,9psi,12psi,14psi
I have boost problem and i dont have boost at all,on map1 or map3 same thing
Do you guys know how should i check for the problem?or where could the problem be?and how should i check if the EBC is working or not working?
Follow Me on Instagram: @Stock_GT86
Admin & Founder of @GT86PersianClub
Nur Spec Body-Rays Gramlights 57Xtreme-Rays Dura Nut L42 Straight type Lug nuts-EBC Brake Rotors-K&N Filters-D2 Racing RS Coilvers-GReddy EVOlution GT Catback-HKS Dual Resonated Front Pipe-JDL Catted UEL Header-Valenti FT86SF tail light & 4th Brake light
Mehrshad is offline   Reply With Quote
Old 11-23-2018, 10:06 AM   #1099
Sriracha
Red Ranger
Sriracha's Avatar
Drives: 2013 Scion FRS - Sriracha
TUUUURRRBOOOO
Its finally happened, I caved and bought the JDL kit a little earlier than planned and man am I excited!
Ended up going with:
GT2860RS
UEL
OMNI 3 bar map
JDL bumper bar
JDL oil pan
Standard charge pipe routing
And the recirculated waste gate.
Cherokee black intercooler upgrade
Thermal ceramic black hot side
Ceramic red cold side
JDL resonated catted over pipe front pipe combo
Planning on getting her tuned by PTUNING Manassas ( I live close and have heard good things ). Looking to hit 300Whp so here we go!
Also I should add I'm also l also have on order before the kit gets here a P3 vent gauge ( to monitor my babys vitals ) and a full blown catch can setup to keep any of those nasty crank case pressure problems away.
And yes I have done supporting mods,
Clutch is an ACT HD
I have a slotted drilled rotor kit with nice pads
And of course some nice sized shoes for her to keep her on the road
Cant wait!
There's a reason no one asks me if I love them more than my car ...
Sriracha is offline   Reply With Quote
Old 11-23-2018, 10:30 AM   #1100
Trust86
Drives: 2016 Halo FRS
Cant wait!
Highly suggest delicious or HRI tuning.
Trust86 is offline   Reply With Quote
Old 11-23-2018, 11:22 AM   #1101
Sriracha
Red Ranger
Sriracha's Avatar
I've never been one for E tunes, especially with switching from NA to FI. Is there any particular reason you recommend them? I've seen many people use them on the forums but eh maybe I'm just old school.
Old 12-03-2018, 08:07 AM   #1102
Trueweltall
Trueweltall's Avatar
HRI has tuned hundreds if not over a thousand of these cars, his experience with tuning this engine of all different combinations is probably unmatched. Delicious calls HRI when they run into a problem.
Trueweltall is offline   Reply With Quote
Old 12-05-2018, 02:32 PM   #1103
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
well this is an interesting statement. I'm glad it's not tuning wars though and they help each other out though.
pgranberg11 is offline   Reply With Quote
Old 12-05-2018, 02:51 PM   #1104
djezlee
Drives: 2017 BRZ Limited
Is anyone using the JR Dual Oil Cooler/Radiator? If so, which slim fan set-up do you reccomend? I was looking at the Mishimoto Plug & Play but I am not sure it would provide clearance for the JDL GT2860RS installation.
djezlee is offline   Reply With Quote
Old 12-05-2018, 04:46 PM   #1105
Trueweltall
^ Whoa, are you me? I was just looking into this.
Old 12-05-2018, 04:59 PM   #1106
djezlee
I’m being told that the jdl slim shroud with 1320 fans are the way to go!
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
