Old 03-20-2018, 08:47 AM   #1093
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
Looking good man keep up the good work. You have some determination to do all that bodywork, should yield a clean finish.
malubawla is offline   Reply With Quote
The Following User Says Thank You to malubawla For This Useful Post:
zeal86 (03-20-2018)
Old 03-20-2018, 11:11 AM   #1094
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I think element tuning said they run 305s on their rocket Bunny 86
325 Slicks square FWIW. on 18x11 square. It's my dream set-up. Requires a lot of triple checking and body modification.
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
zeal86 (03-20-2018)
Old 03-20-2018, 11:13 AM   #1095
Ashikabi
Ashikabi's Avatar
That's a lot of meat
The Following User Says Thank You to Ashikabi For This Useful Post:
DustinS (03-20-2018)
Old 03-20-2018, 05:02 PM   #1096
zeal86
zeal86's Avatar
Drives:
This is meat! Looks so good!
lian_nast
18x12 0 F 285/35/18
18x13 0 R 335/30/18
https://www.instagram.com/lian_nast/
__________________________________________
Instagram @zeal.eightsix
zeal.eightsix Facebook
zeal86 is offline   Reply With Quote
Old 03-20-2018, 05:37 PM   #1097
Ashikabi
Ashikabi's Avatar
lian_nast
18x12 0 F 285/35/18
18x13 0 R 335/30/18
Interesting front bumper. Not a fan of the wheels though
Old 03-20-2018, 05:41 PM   #1098
zeal86
zeal86's Avatar
Drives:
Not a fan of the wheels either but I love how his 86 sits and the meaty tires!
I not huge on the front bumper (MP Speed) but it is unique. I do like the rear bumper though... I actually tried to get one... hard to track down... I'm happy with going custom on the rear though.
Old 03-20-2018, 05:52 PM   #1099
Ashikabi
Ashikabi's Avatar
You could probably replicate that rear bumper pretty easy with some body work skills
Old 03-20-2018, 06:00 PM   #1100
zeal86
zeal86's Avatar
Drives:
I thought about creating similar openings on my rear bumper... even did the research... as of right now I don't think I'll do it though... we'll see... my process is fluid.
Old 03-20-2018, 06:02 PM   #1101
Ashikabi
Ashikabi's Avatar
What did you end up deciding on the antenna?
Old 03-20-2018, 06:03 PM   #1102
zeal86
zeal86's Avatar
Drives:
Leaving it as is...
Old 03-20-2018, 06:31 PM   #1103
Ashikabi
Ashikabi's Avatar
Leaving it as is...
Old 03-20-2018, 07:01 PM   #1104
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Shave it!
Originally Posted by humfrz
I'm old and lazy
Ashikabi (03-20-2018)
Old 03-26-2018, 10:15 PM   #1105
zeal86
zeal86's Avatar
Drives:
Update:
So I went backwards a bit because I didn't realize I had the rear corner of the passenger overfender a tad misaligned. All my sanding to that point had been done to fit it in the position I had it. After proper fitment, I added some more fiberglass in places that didn't coincide previously and sanded some spots that needed to be brought down or shaped. I now have it properly aligned through out.
I'm thinking I'll finally be tinkering with the latching mechanism Wednesday. Once that is done, I'll prep the fender for paint.
I can't wait to have the whole kit fitted so I can start molding!
The Following User Says Thank You to zeal86 For This Useful Post:
DustinS (03-27-2018)
Old 03-27-2018, 09:42 PM   #1106
zeal86
zeal86's Avatar
Drives:
So I recently came up with the idea to do this modification... I love the look of the Varis wide body fenders so I wanted to implement a similar design with my fenders and garnishes.
I'm really looking to make my wide body install stand out from others like it... whether replica or authentic. This mod is just another way of accomplishing that goal.
Anyway, I used a semi hard foam to sculpt the portion that finishes off the shape. I used 3M tape to protect my part and the foam. I'm ordering the required materials to make an initial mold. I will then perfect the initial mold and remake my mold. If they turn out... I may make more...
By the way, the plan is to mold these to the fenders....
I may cut the opening on the inside out so that the fender is the cutoff point for the opening of the garnish...
DustinS (03-28-2018)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
