#1093 |
Drives: frs
In resume, the new version give you the chance to get progresive boost via analog switch, like conventional supercharger?
#1094 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
There are two activations: one linesr and one logarithmic. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
| The Following User Says Thank You to Sojhinn For This Useful Post: | Teseo (10-27-2016) |
#1095 |
Ultra Senior Member
Drives: 2014 BRZ Premium, WRB
So I opened my hood this evening to find that the three power cables connecting the compressor motor to the controller were completely twisted up. Upon further inspection I found that the DC motor and the plate to which it is attached are able to move with respect for the compressor housing. The large retaining ring is still in place; however it appears to be able to move independent of the plate too. I can turn the DC motor fairly easily with my hand in both directions.
EDIT: I have removed the compressor and reverted back to stock until I can get this sorted out. This is a video of me rotating the motor and plate. You can also see the retaining ring move. Last edited by vfrqqq; 11-25-2016 at 11:16 AM. Reason: Added pictures and video |
| The Following 2 Users Say Thank You to vfrqqq For This Useful Post: | GhostOp86 (11-26-2016), zc06_kisstherain (11-24-2016) |
#1096 | |
Drives: 2013 Asphalt 6spd
| The Following User Says Thank You to Target70 For This Useful Post: | vfrqqq (11-22-2016) |
#1097 | |
Contact Rob. That's your best bet. I haven't encountered this with anyone I have helped. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to Sojhinn For This Useful Post: | vfrqqq (11-23-2016) |
#1099 |
Ultra Senior Member
I contacted Rob and, outside of shipping the compressor back to him to have him install a thicker snap ring, he recommended removing the snap ring, separating the motor from the compressor housing, and applying some red RVT silicone sealant to fix the motor plate to the compressor housing mating surfaces. Personally, I have the tools and comfort level to disassemble the compressor unit myself and Rob was very helpful in describing how I should apply the liquid gasket. I'll be doing the fix this weekend and will post pics to show what I did, for anyone that is interested. It seems like this fix should take care of the problem and it seems like Rob has also done this with other units, but I will continue to monitor the compressor and motor to verify it is still holding firm.
Unfortunately, I don't know how long I was using the system since this happened as I just happened to be interested in looking under the hood for something else; however, I am fairly certain that it happened sometime after my last oil change, which was about three weeks ago, as I didn't notice anything untoward when I looked under the hood then. My main concern, which I expect is shared by others, is that, aside from directly observing the twisted cables, there was no indication of a problem and it makes me wonder how much longer I might have used the system and continued to strain the power cables before they eventually gave way. Since I'm not familiar with the variations in between different versions of compressors, I defer to Rob (and others) regarding whether others need to preemptively address this issue. |
| The Following 4 Users Say Thank You to vfrqqq For This Useful Post: |
#1100 |
Ultra Senior Member
These are the steps I took to disassemble my compressor unit and apply some liquid silicone sealant to keep the motor plate from twisting with respect to the compressor housing. I don’t know how other compressor units were assembled, but my compressor had the motor plate, to which the motor and compressor wheel are mounted, held in place by the friction of a black snap ring.
I used a bicycle spanner to remove the snap ring, which ended up doing the trick, but I needed vice-grip plyers to sufficiently compress the snap ring. http://www.ft86club.com/forums/attac...1&d=1480188921 The motor and compressor housing move freely with the snap ring removed and are easily separated; however, it is a tight fit so I proceeded slowly to keep the compressor wheel from hitting the inside of the compressor housing. http://www.ft86club.com/forums/attac...1&d=1480188921 http://www.ft86club.com/forums/attac...1&d=1480188921 With the motor separated, you can see the mating surface of the motor plate and compressor housing where the sealant will be applied. http://www.ft86club.com/forums/attac...1&d=1480188921 http://www.ft86club.com/forums/attac...1&d=1480188921 I cleaned the motor plate and compressor housing mating surfaces with rubbing alcohol (70% isopropyl alcohol solution). While I was at it, I also cleaned up the inside of the compressor housing as it had an oil film. Something I though was interesting was the fact that the interior of the compressor housing appears to have little pits all over the place (see previous pic). Assuming my air filter is doing its job, I’m not exactly sure what is causing this. Perhaps others can report whether they observe this too. With the mating surfaces clean, I applied a ~1/16” bead of JB Weld red RTV silicone sealant to the compressor housing mating surface. The sealant was a little difficult to apply evenly along the surface so I ended up wiping off the excess with my finger taking care not to get any on the interior of the compressor housing. Doing resulted in a fair amount of excess sealant getting pushed into the groove where the snap ring seats; however, I ended up cleaned out that groove after reinstalling the motor plate. With the sealant evenly applied to the compressor housing mating surface, I carefully reinstalled the motor plate and gently pressed it into the compressor housing with a slight twisting motion to spread out the sealant. After the motor plate was installed I let the sealant cure for a few hours and found that it was already held firmly in place. The following picture shows the end result. http://www.ft86club.com/forums/attac...1&d=1480188921 I reinstalled the snap ring and let the unit cure for 24 hours before reinstalling in the car. Last edited by vfrqqq; 11-26-2016 at 05:56 PM. Reason: edited pics |
#1101 |
Drives: White 2014 BRZ
Has anyone played around with higher AH batteries like 30AH? I want to be able to get full sessions in on track. I guess an AUX charger would help too
JDL Turbo kit - Ecutek, HRI tuned.
#1102 | |
I think aux charger would be best. Sent from my iPhone using Tapatalk
#1103 |
Drives: DGMBRZ
Does anyone have an updated link to the OF tune for the Phantom ESC? It seems its been moved on the website, and all the links I can find are dead.
Tks.
#1104 | |
Email Shiv directly. Sent from my iPhone using Tapatalk
#1105 |
Drives: DGMBRZ
Did. No answer yet, though admittedly just a day has passed.
#1106 |
Drives: Moped
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6035 | 11-08-2025 11:58 AM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 07:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 02:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 04:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 10:51 AM |
