Old 12-13-2016, 08:16 AM   #1079
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by AceHeader-MT View Post
The anaconda series is for true race only.
The 42.7mm makes no power or torque below 5,000.
The 48 is for crazy HP race only set-ups.
JMonty- you'll be very happy with the A-350
Any dyno charts with torque and power figures in comparison to stock or 'other/generic' EL header setups? Thanks
(In regards to the 42.7mm Anaconda)
stevo_12v is offline   Reply With Quote
Old 12-13-2016, 10:36 AM   #1080
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Anaconda 42.7 (w/Ace OP) with OE Frontpipe and OE muffler. Measured at the crank
This was done a few years back with no tune. Delicious Tuning has made significant improvements since this test.
The Anaconda series are designed for race/high rpm use, as anything below 3800rpm has very little torque
AceHeader-MT is offline   Reply With Quote
Old 12-19-2016, 01:50 AM   #1081
blindfold
Drives: brz
first track day with A-350, it was definitely a pleasant surprise and the header itself is quit nice both performance and quality. However I blew a gasket that seats between the header and the up-pipe, it is a two hole gasket that is made of a metal sandwich with asbestos like materials in the middle. I do not believe it is a common gasket so I am having trouble finding a better quality piece to replace it with. Is there a way to purchase a full metal gasket? I foresee this happening again if the same material gasket is replaced.
blindfold is offline   Reply With Quote
Old 12-19-2016, 10:36 AM   #1082
Doozer
Doozer's Avatar
Drives: gt86...among others
Sorry this happened to you. Has anyone else had this issue?
We will happily replace original owner gaskets for the life of the header.
Happy you're pleased with the performance.
Email us at Ace@bymer.com.tw
racing gods live deep in corners
Doozer is offline   Reply With Quote
Old 12-19-2016, 11:16 AM   #1083
Calum
That Guy
Drives: 2013 asphalt FRS MT
...Did you forget which account you were using?
Old 12-19-2016, 11:19 AM   #1084
AceHeader-MT
Drives: 2012 FR-S
..sshhh..it
Anyway, fact still remains.
For original owners, lifetime gaskets.
Old 01-07-2017, 12:55 AM   #1085
.RYAN
AWOLBRZ
Drives: 2017 BRZ
Is the ACE front pipe meant for the OEM up pipe/exhaust? Or what is the design theory behind the smaller inlets/outlets? Does this create a bottleneck when paired with the A350?
.RYAN is offline   Reply With Quote
Old 01-07-2017, 02:25 AM   #1086
AceHeader-MT
Drives: 2012 FR-S
The tapered ends create a small venturi and helps the gas evacuate quicker.
Exhaust gasses come in a pulse. By placing merges and pipe diameter changes in the correct place, you can create small vacuum areas. These vacuums help the gas be pulled through the pipes to form a smoother wave pattern and allow the engine to breathe better.
That's why Smooth is Fast
Old 02-12-2017, 02:17 AM   #1087
trigun286
trigun286's Avatar
Drives: '16 WRB Limited
I might have missed it in this thread or others but I am debating on which header to get and am torn between the A350 and the CS400. Are there dyno charts comparing the two?
trigun286 is offline   Reply With Quote
Old 02-12-2017, 03:20 AM   #1088
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
You'll get a hard time finding this information on the same dyno with same fuel and same high quality tune.
I would use 400 on a road or AutoX car.
On a track or road + track car, the 350.
With a Delicious tune.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 02-12-2017, 11:34 AM   #1089
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Fix for Header in Contact with Undertray
I installed my Ace Type A 350 header. Serial number 86–0020. Header coated with Cerakote glacier black ceramic coating inside and out. Header installed without difficulty. I raised the engine about 35mm after unbolting passenger side motor mount and backing nuts out on driver side mount. Rear header section slipped into the over-pipe location with generous clearances.
Header in hard contact with installed metal under tray using OEM hardware. I lowered the tray 8mm at the rear and 3mm at front using 18 each 1.5"" x 1/8" 5/16 black rubber washers and four each flange head M8x30-1.25mm bolts. Hard plastic washers are available and in thicknesses up to 3/8". I would use those instead of the rubber washers. Rear Fiber cover flexed downward to use OEM bolts to attach to tray. Visual inspection revealed approx. 5mm clearance between top of tray and header.
Header attached to OEM exhaust without drama. I used flange bolts and nuts in lieu of studs with nuts throughout. Pleased with sound levels. Specially after running a muffler delete pipe for 2016 season.
Delicious Tuning Flex Fuel kit and ACE header stg 2 tune will be installed soon.
A special shout out to @David and @Mike at Counterspace Garage and @Zack at Delicious Tuning for the help getting to this point in my build.
Brzzee is offline   Reply With Quote
Old 02-12-2017, 11:40 AM   #1090
Reamer
Drives: 2015 FRS
You will not be disappointed.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
Old 02-12-2017, 09:37 PM   #1091
BRZ FTW
Drives: 2017 Subaru BRZ
Will the current front pipe fit 2017 MT?
BRZ FTW is offline   Reply With Quote
Old 02-26-2017, 05:17 PM   #1092
xwd
Does anyone know off hand what the thread pitch is on the overpipe flange that connects to the header? I thought it was M6x1.25 but wanted to make sure.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
