Old 03-21-2014, 10:35 PM   #1079
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by solidONE View Post
Speaking of alignment. Anybody have some good idea for easy (relatively) do it yourself quick alignment checking devices or methods that they use or recommend?
Here's an idea I thought of that seems like it could get you close estimates of camber. Cut a straight piece of metal to the diameter of your wheel or slightly less. Park on what you believe is level ground. Use your phone's level (on iphone, it's built in as part of the compass) to find how far off from level the ground is right next to the wheel you want to check and in which direction it's off. Put the straight edge on the wheel, use the level to get at least close to vertical placement of the straight edge. Put the phone against the straight edge and see what the resulting angle is. Add or subtract the angle of the ground the wheel is sitting on.
So if you had the ground tilted 1 degree away from the car, and the wheel came out at 3 degrees in, subtract one to get roughly 2 degrees negative camber.
This seems like it would at least be ballpark. I haven't tried it yet and compared against the alignment numbers I have from recently.
Edit: I realized that the phone's level is accurate to within 1 degree. In order to be more accurate, for both the level-ness of the ground and the camber of the wheel, put the phone so it is at 0 degrees and then measure the distance to the ground or wheel as accurately as possible. Convert the distance into degrees using trig (I don't have the formula in my head, but it isn't hard.)
cycleboy is offline   Reply With Quote
Old 03-21-2014, 11:43 PM   #1080
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I actually tried using a level app on my phone (iMetal Box) and it seem to be at least within half a degree possibly less. It lets you zero the level. Although, half a degree is quite a bit when you're talking about camber not to mention 1 entire degree.
Old 03-23-2014, 11:22 PM   #1081
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
@Andy RaceComp,
Is it possible to make any roll center correction at the rear? When I say "possible" I mean in a relatively inexpensive/easy sort of way.
Old 03-25-2014, 01:36 PM   #1082
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
found this while digging through the internets...
seems like a cool concept..
Old 03-25-2014, 01:59 PM   #1083
Racecomp Engineering
@Andy RaceComp,
Cheap and easy...not really.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Captain Snooze (03-25-2014)
Old 03-25-2014, 02:05 PM   #1084
Originally Posted by No5ki View Post
I'm planning to gradually make this my track car 5-10 years down the road and it only sees monthly Autox currently (Also DD). Does it make sense to spend the money up front on a $2-3k coilover system, or stick with some decent springs $200-300 for small drop and a slightly more planted feel?
Also considering springs with Konis or Bilstiens, but that gets you into non adjustable coilover $ range(Bilstein B14). And at that point, why not spend the extra and get the fully adjustable.
I should mention i'm new to suspension tuning and auto mods in general but am eager to learn. My gut reaction is to go with adjustable when possible to allow for education and testing, but more important is what makes sense for now vs. down the road.
Edit: Forgot to ask; how are the Eibach Pro-kits's springs?
First try to remember that a coilover isn't automatically "better." They have certain advantages but to hit a low price point they often have to make sacrifices.
A strut + spring set-up is just a non-height adjustable coilover. In the case of Konis they are damping adjustable.
For a fun DD and monthly autox car, a set of quality springs and shocks + a good alignment is a good easy way to go. No muss, no fuss...good choice if you're new to suspension tuning.
It will hold up at the track just fine when you start doing that in the future and be easy to drive fast and learn on (with the right combination). But if you're running r-comp tires and really pushing for fast laptimes, a quality coilover is the way to go.
- Andy
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
fooddude (03-25-2014), GTHachiRoku (03-26-2014), No5ki (03-25-2014), Turkish (03-25-2014)
Old 03-25-2014, 11:12 PM   #1085
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@Racecomp Engineering
Im curious to know a suspension vendors opinion on these thingys...
http://www.cambertire.com/
and how it would effect any sort of alignment?
Old 03-26-2014, 12:06 AM   #1086
I get asked about those about once a year.
We had a sponsored driver that was also sponsored by them. At first he was in love, but it didn't take long for him to jump ship and move to a regular r-comp and pick up some speed.. I haven't touched them and I probably won't.
- Andy
wparsons (03-28-2014)
Old 03-26-2014, 12:18 AM   #1087
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
- Andy
Any particular reason why they aren't the bee's knee's?
Old 03-26-2014, 07:12 AM   #1088
Captain Snooze
Drives: Red Herring
Mike@CSG and Andy@RaceComp
This is just for curiosities' sake.
From all the trawling I have done about Tein SRCs it would seem they are not pressurised. Does this mean that gassed dampers are a bit of marketing fluff? I like the theory that pressurised dampers are less prone to cavitation but does this actually make a difference in reality? Is it a case of diminishing returns for added cost and complexity?
Thanks.
Old 03-26-2014, 08:54 AM   #1089
FR-S Matt
So I have a newbie question since I got my KW V3's on this past weekend. I stole Myles suggestion on settings for street:
Full stiff settings then:
Front compression 7 clicks back
Front rebound 10 clicks back
Rear compression 8 clicks back
Rear rebound 7 clicks back
My silly question is can you adjust this while the car is on the ground pre-loaded or do these adjustments need to be made while it is in the air? I just don't want to damage anything. Thanks guys!
Old 03-26-2014, 09:13 AM   #1090
dp1
driving smoother faster
Drives: Sold
Either is fine
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
FR-S Matt (03-26-2014)
Old 03-26-2014, 09:51 AM   #1091
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
where can i find some literature on the effects of wheel and tire sizes on performance and the necessary considerations.
Ie, what IS the benefit of going to 18's with 35-40 aspect ratio tires and what modifications would be necessary to extract an improvement.
with such a stiff tire, does it become absolutelty necessary to control dynamic alignment, so more anti-roll, caster, etc.
i keep finding bits and peices of random forum discussion but no papers or articles (other than the crap you find in tuner mags)
Old 03-26-2014, 09:54 AM   #1092
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
I'll be receiving my suspension tomorrow / Friday depending on how late my apartment office decides to stay open or if brown Santa leaves my presents at my door. My question is if I swap my shocks by myself (the most likely scenario), what is the safest way to remove the old and mount the new? I will try to get some help, but it is unlikely any would be available when I plan to swap. Thanks in advance!
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
