#1079 | |
Drives: Neptune GR86
It adds pie controls to the screen edges that pop up when you have your finger on the edge and gestures to do various things. I suppose you can launch apps with it, but it's not a launcher in the traditional android sense. ![]() ![]()
#1080 | |
Drives: 2014 Scion FR-S
Rooting in itself does nothing to stability.... it's all the trouble you can get into after you have full access to software. I can't get Pandora to work without skipping songs nonstop for the life of me but I really doubt that's root related Sent from my SM-N900T using Tapatalk |
#1081 |
Drives: 2016 Cadillac CTS
That's strange. I don't think anyone else was hit by duties. And no, shipping fees don't cover that.
#1082 | |
Drives: 2013 WR Blue Limited Manual BRZ
Those having trouble with Viper, you'll know when it's working because you can actively change the eq settings while Pandora or Poweramp is playing (if Poweramp's eq settings and volume control are turned off), and you'll hear them change as you mess about with the EQ. I can't remember exactly what the app you have to remove is called but if you use a file browser like FX root browser than it'll show you the app icons. It literally is just a purple square with a white V. I'm pretty sure I backed it up so I'll check the name later. In the mean time, I played around with the EQ settings in Viper for only a few minutes while using a new app I put on my phone called FrequenSee (free) and playing some white noise audio files I grabbed from this site: http://www.audiocheck.net/testtones_whitenoise.php (You can also test your low frequency with this file and watch the FrequenSee app move left to right, and fix it so it doesn't move up and down while moving left to right. http://www.audiocheck.net/audiotests...cychecklow.php) Before ![]() After ![]() The first shot is with EQ off, and the second is after making a few adjustments in Viper, namely trying to flatten out the curve by raising up the dip in the curve between 150 and 200, as well as above 10k, and by lowering the mid range and <50. Now, I'm no Viper expert, and I was only using the beginner mode to start with, but just spending a few minutes tweaking improved the frequency response dramatically, and you can definitely tell when listening (this is with stock speakers, no dynamat, no sub). I can't wait to dial it in more and try more expert options once I learn how to work them :P |
The Following User Says Thank You to Deathalo For This Useful Post: | Pwolf (07-15-2014) |
#1083 | |
And ensure it is enabled from within the app. |
#1084 |
Drives: 2013 Toyota 86 High MT
Sup gents,
After trolling this thread the last two days or so I'm about to pull the trigger on this head unit. Its exactly what I have been looking for ever since I got my twin. Android 4.x! ![]() Its great to see that the Ca-Fi team are showing good customer support. I'm just curious on the reliability of the unit from the hardware perspective. Noticed some guys mentioned a few button issues and touch problems. Overall I see it hasn't plagued everyone. So in general, has this unit been reliable? I worry since its from China. For RHD drive guys that have it installed, is the microphone pick-up decent or is it better to have them wire the mic out of the HU? Can't wait to place my order then let tweaking begin, I see the audiophiles are starting the tuning... ![]() Cheers gents. Great thread and thanks to all that have put in the many hours. |
#1085 |
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
The only touch-input issue I've noticed is that the bezel overlaps the screen just a bit, making inputs that require touching near the edge or dragging something to the edge iffy sometimes. I've got a narrow-tip capacitive stylus that I use sometimes, pressed right up against the bezel, when I need to do that.
#1086 |
Drives: 2013 GBS BRZ Limited
Unit came in today and 3 hours later we're up and running. I didnt know what to do to get aux working correctly so I just skipped that for now (to be honest I dont really use it). I took a picture of the method I used to tap in the amp for the front speakers. Ill post that later.
Just wanted to say thanks to everyone here who has posted various info. It helped a lot.
#1087 |
HU installed:
![]() It's recessed a bit so I might have to bring forward a tad. Here's what I did for the amp wire... ![]() I went out and bought a wire harness to steal a pin from. Since the wire from the #9 pin is the one I need to tap into and that pin is missing from the unit's harness, I threw the stolen one (the grey wire... in hindsight, I should've used a blue wire) in there and then spliced the amp wire onto that. Taped it up for a "plug and play" solution without having to mess with the car's cables.
#1088 | |
Sent from my GT-N5110 using Tapatalk |
The Following User Says Thank You to DC2R For This Useful Post: | riyal (07-21-2014) |
#1090 |
Captain Cocoa
Drives: CBS BRZ MT
Anyone else having issues with using the antennae adapter linked earlier in the thread? I have it properly wired up and you can get a signal if you hold onto the antennae outside but it's pretty weak. What could be causing this? I tried using my brothers antennae which is a decent amount longer but still sounded like crap in the car.
#1091 | |
#1092 |
Captain Cocoa
Drives: CBS BRZ MT
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
