Old 06-29-2015, 02:46 PM   #1065
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
As a small announcement, we're offering 10% off of our Stage 1 & 2 NA tunes as well as Flash & Go tunes through July 4th. PM or email me at sales@delicioustuning.com.com for details!
Sincerely,
Old 06-29-2015, 05:13 PM   #1066
brillo
Drives: 2013 Firestorm FR-S
Zack,
Just curious, did you do any 0-60 testing to see how much faster your base NA tune was then stock?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 06-29-2015, 06:05 PM   #1067
DeliciousTuning
Originally Posted by brillo View Post
Zack,
We haven't. We have proven power gains on all of our tunes, but 0-60, 1/8th, 1/4 mile, etc times are going to vary wildly based on driver, suspension, wheel/tire setup, even temperature and humidity. I can say that one of our customers in Texas is running a standard Stage 2 NA tune from us and is the record holder for fastest NA FR-S/BRZ in the 1/4 mile with a full interior.
Sincerely,
Old 07-01-2015, 10:54 AM   #1068
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by DeliciousTuning View Post
Who would like CLFC (Closed Loop Fuel Correction) under WOT for naturally aspirated stage tunes? We have been testing it out on our Innovate tunes and it is already implemented in our Flash & Go tunes. So far it has offered great improvements in consistent and repeatable power.
So the only thing left is to add it to the NA tunes we offer. This is great option to hit exact AFR targets all the time. For those looking to our perform at the track, this offers precise and exact AFR for all conditions, including altitude, heat and heavy loads in higher gears.
We are going to be further refining these tunes on our sponsored vehicles running Pirelli World Challenge and SCCA sanctioned events. So let us know your thoughts on a unique option only offered by Delicious Tuning - Closed Loop Fuel Correction (CLFC).
Cheers,
William Knose
Do you have an ETA on when this might be available?
This + Flex Fuel kit + Stage 2 tune is seriously exactly what I'm looking for. And I wouldn't have to keep reflashing between E85 and 91 tunes.
Old 07-01-2015, 01:11 PM   #1069
DeliciousTuning
We are testing it on stage 1 right now and then onto Stage 2 after that. We do not have an ETA but it is currently being tested and driven daily.
Cheers,
William Knose
Old 07-01-2015, 02:01 PM   #1070
OkieSnuffBox
Cheers,
William Knose
Thanks, was just curious cause I would have liked to take advantage of the 10% off this week!
Old 07-08-2015, 11:24 PM   #1071
DeliciousTuning
Hi All,
We have been testing our Closed Loop Fuel Correction (under WOT) and it has been working well. To boot we have implemented our Stage 1 NA tune on a pure Speed Density tune so that you can switch between ANY intake whenever you want. Now you will not need a specific tune for a specific intake as AFR, timing and cams will always be correct. More to come...
Cheers,
William Knose
Old 07-09-2015, 11:02 AM   #1072
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Hi All,
Cheers,
William Knose
This is really exciting news, great options. Is the speed density or hybrid mode good to go?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 07-10-2015, 09:36 AM   #1073
FT&6
FT&6's Avatar
Drives: FRS Raven 6AT
MT Turbos for AT with tune?
Ok so I'm having a hard time trying to understand this as I know nothing about turbos or superchargers let alone drive a manual trans. I have an AT FRS and if I wish to go FI in the future, do these tunes make a system that is designed for manual transmissions compatible with an auto? For example, the turbo kit from PTuning is only for manual cars as I've come to find out. But with the tune that's being offered, does it make it possible to use this kit on an auto? Thank you in advance for insight.
FT&6 is offline   Reply With Quote
Old 07-10-2015, 10:07 AM   #1074
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The Ptuning kit doesn't fit with automatics due to physical part fittings; not tune related.
Old 07-10-2015, 10:18 AM   #1075
FT&6
FT&6's Avatar
Okay thank you.
Old 07-13-2015, 10:29 PM   #1076
erok81
Drives: 2015 BRZ
For those of your with turbos running this tune and am EBCS. How do you have it hooked up? I emailed them to ask (I'm having trouble with boost levels) but figure while I wait I'll ask here too.
It's hooked up exactly like they recommend and plugged into the purge valve harness. The only difference is I'm not running port 1 to the intake. It's just vta. My last car was like that, so I figured why not. I don't have a port on my intake anyway. Or is that needed to be hooked up? I've read it's okay both ways. But maybe not. If I bypass the controller I get wastegate pressure.
erok81 is offline   Reply With Quote
Old 07-14-2015, 01:38 PM   #1077
DeliciousTuning
Sounds like you're okay, Port 1 can be VTA or plumbed to intake pre turbo.
Sincerely,
Old 07-14-2015, 02:22 PM   #1078
erok81
Drives: 2015 BRZ
Okay sounds good. It's something else then. I tried both ways and neither works. So I'll wait to hear back from you.
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
