Old 08-21-2013, 01:57 PM   #1065
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by DeliciousTuning View Post
So this is an interesting question/problem (with a solution) and something I have looked into a little bit with a few customer vehicles. Interesting thing is that we only had one customer out of about twenty forced induction vehicles that experienced the issue. So from what we can tell it is not too common but it does exist but from what?
As far as we can tell it is tip in knock and we have not yet determined, what it is related too. Such items we are looking at for a cause include fuel pumps, exhaust restrictions, intakes etc..., as these seem to be the differences that could be causing the problem. In the mean time we have come up with some updates to our tunes to accommodate vehicles that do happen to stumble across this problem, such as the one above and are in the final steps testing.
We have been testing the update fix for some time now to make sure it does work and have found this to resolve the problem if you are having it. We are finalizing the update so that it can be applied to all our maps so that if you do or do not have this issue it will not affect the drivability of the vehicle for any of our tuned maps.
If you have any questions please ask.
Cheers,
William Knose
I assume for me being in Phoenix non intercooled and having 91oct fuel plays a factor here. I am in hopes we can get this dialed on the dyno this weekend. I will also be doing an e85 map as well. That should help with some of the issues I am seeing. The 115 degree temps out here are making my car and tune hate itself.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-21-2013, 03:11 PM   #1066
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Ethan View Post
I was concerned about that too, but the car was on the dyno yesterday and under full load the engine didn't move enough to touch the bar. Would the engine rock more on the street?
If I am not mistaken, the engine rocks around the most when taking off from a stop. It is that low rpm (<1k rpms) stumble that rocks the engine.
I think my mounts are going bad guys. My OP used to rattle a little on the subframe in the <1k rpm range.... it has gotten progressively worse and worse over the past month. I don't know what to do about this damn OP except replace the mounts I guess.
Old 08-21-2013, 03:32 PM   #1067
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by brillo View Post
Can someone provide a brief explanation of the causes and issues associated with tip in knock? I've tried to search the topic on the general internet but I'm not sure I have a handle on the issue. I gather that it is detonation issues during the transition from light load to heavy load, but I'm not sure if its a function of the ECU not being able to respond fast enough to throttle inputs or due to tuning. In addition, I also can't tell how dangerous it is or what drivability issues it causes.
Being the ECU / vehicle are designed around a normally aspirated vehicle between quick shifts and quick blips of the throttle will be fine with no additional forced induction. So the timing curves and fuel curves will be for the most part sufficient for proper tunes. So blipping the throttle should not be an issue for the most part on normally aspirated vehicles as it is seeing no real load.
When forced induction is added the vehicles experience load/pressure on the cylinders and in turn the fueling and timing calculations need to be adjusted accordingly. With superchargers especially, boost/load can be created at the blip of a throttle (3-4 PSI of boost) and that is why some people are hearing noises in these scenarios. As we have seen with quite a few of our customers it does not happen with everyone and does seem to also relate to additional parts on the vehicle beyond the supercharger. Hard to really say exactly what is causing the scenario.
So instead of determining what exactly is creating the instances, partially the supercharger, and partially additional back pressure on the system (non stock exhaust systems) we have spent some time testing additional settings to make sure that all vehicles (with whatever parts are on the vehicle) do not experience these scenarios.
Hope that offers a slightly cleared response to my previous post.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
brillo (08-21-2013), Sportsguy83 (08-21-2013)
Old 08-21-2013, 05:00 PM   #1068
phloozy
phloozy's Avatar
Drives: Scion FR-S
Anyone see an issue with getting a used innovate kit? is there anything that can go wrong in the install or de-install? The seller says it has only been on his car for 800 miles and is removing it because he is trading in the car.
phloozy is offline   Reply With Quote
Old 08-21-2013, 05:15 PM   #1069
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by NickFRS View Post
Looks like i'm not the only one with a Perrin intake + Charger now. But I have the 3in :happy0180:
What header is that?
kiichiro is offline   Reply With Quote
Old 08-21-2013, 05:23 PM   #1070
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There's really not much that can go wrong other than the intake swallowing debri and pulling it into the charger. I'd say you will be fine.
Old 08-21-2013, 05:24 PM   #1071
phloozy
phloozy's Avatar
Drives: Scion FR-S
Great thanks for that, First time going NA -> FI so im nervous
Old 08-21-2013, 05:27 PM   #1072
xjohnx
Grip>Slip
xjohnx's Avatar
You could alsoask him for a test ride or video before he uninstalls it if you want to make sure everything is working properly.
Old 08-21-2013, 05:30 PM   #1073
phloozy
phloozy's Avatar
Drives: Scion FR-S
he will be shipping it and I am having moto mike install it
Old 08-21-2013, 06:14 PM   #1074
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
That is the Fa20club header.
MattF is offline   Reply With Quote
Old 08-21-2013, 08:14 PM   #1075
NickFRS
Drives: 2013 Asphalt FRS
that comes very close to the plastic intake!
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 08-21-2013, 08:16 PM   #1076
swift996
swift996's Avatar
It's just the angle of the photo there is a good 5-6in
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
NickFRS (08-21-2013)
Old 08-21-2013, 08:58 PM   #1077
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Originally Posted by moto-mike View Post
You open the throttle and the air enters the engine instantly. The ECU takes a fraction of a second to realize this when measuring via MAF (a bit less with MAP). In that fraction you're running timing and fueling for cruise and not high loads.
Who would have thought that a little turbo lag could be a good thing!
cmss2000 is offline   Reply With Quote
Old 08-21-2013, 09:45 PM   #1078
xxscaxx
Drives: 2013 SWP BRZ
I'm still getting this squeal noise when shifting above 4k, and if I decelerate it will squeal right at 3700 rpm every time.
I still haven't put my car in the air, but i'm fairly certain its not the exhaust. I shook the hell out of the motor and didn't hear my header hitting anything, and I also shook the catback and didn't hear any noise. Just stumped on wtf it is lol. It has to be something though with the exhaust - I started getting the noise once I installed my JDL header.
xxscaxx is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
