#10753 |
Drives: brz
WTB Greddy Evo GT for 13-16.@@@
#10754 | |
Drives: '15 STX
#10755 |
Drives: 2017 BRZ PP , 2005 Saab 97X
#10756 |
IG: @nickwiththefrs
Drives: 2016 Scion FR-S Halo
fs: pbm rear lower control arms - $300.
bought them from a friend half a year ago and its been sitting in my room taking up space. located in alameda/sf/oakland. |
#10757 |
Drives: '15 STX
I might be able to get them down to the LA area sometime this weekend. Have some friends coming up to autocross and maybe can send them back. PM me.
#10758 |
Drives: 2013 Supercharged BRZ, E85, Ohlins
FS: 2013 Supercharged BRZ. Grown-up build.
Feeler:
FS: 2013 Supercharged BRZ Adult (40s) owned & modded BRZ built for canyons and light track use. This is a grown-up build, over-engineered for longevity. Not abused. Second owner. Purchased car stock in 2016. Garaged since i've owned it. Base car: - 2013 BRZ in World Ralley Blue - 6 speed MT with LSD - Stock interior - Stock stereo & Electronics - 49K trouble-free miles - This car does is not affected under the factory head recall. - 3M Ventureshield clear-bra on front bumper & headlights - Some minor dings/dimples ( i bought the car used) Engine: - 2.0L FA20, stock internals - Jackson Racing C38 Supercharger kit with 10.5lb pulley (California Smog legal with JR tune) - Jackson Racing Oil Cooler - JDL Catted high flow exhaust header, ceramic coated ( not CA smog legal) plus OEM header - Delicious e85 tune with piggyback ECU, inc 750cc fuel injectors, upgraded fuel pump - Car will run any mix of pump 91 to straight E85 - Intercooler Fan assembly (custom made) - AEM electronic gauge for Oil Temp/Press mounted in Driver's air vent Transmission: - OEM ratios - ALuminum driveshaft from driveshaftworks - Upgraded Exidy stage 2 clutch at ~42K mi - Perrin transmission support mount - All fluids done at ~28K Suspension: - Tien monosport single-adjustable (compression & height adjustable) coil-overs - Body braces front and rear, upper and lower - adjustable rear sway bar - ajustable rear links - currently -2.0 all around Brakes-Wheels-Tires: - Wilwood 6-pot front brakes and BP1 pads on slotted rotors - upgraded rear drilled/slotted rotors and EBC pads in OEM rear calipers - Porsche brake duct air dams installed - Enkei gold RPF1 wheels, 17x8 fronts, 17x9 rears. Additional Spare RPF1 wheels included in each size. - Michelin Pilot Super Sport tires in 225/45 and 245/45 respecectively, with two spare new rear tires Other: - Tinted rear tail light covers - Braille 15lb battery - Custom fabricated fender vents with 'supercharged' logos (spare stickers included) - OEM fog lights & housings swapped for evented models, Originals includeds - pinch weld adapters (jack pads) permanently installed - High-grip aftermarket pedals (four) - OEM owner's manual included - OEM spare tire & tools - All service records since purchase ( i am second owner) - Mod journal with printouts & procedures Please that a new BRZ will cost ~$29K with barely 200HP. Total cost of mods excluding labor is ~$10K. This car makes ~360 at the crank, and >300 at the wheels, depending on fuel used. - Asking $ 32,000 negotiable - Reason for sale: Cash needed for home purchase - Local pickup in SoCal only. - contact me -here- please, thanks ----------------------------------------------- ----------------------------------------------- ----------------------------------------------- ----------------------------------------------- - Additional pictures here: https://imgur.com/a/tiyC4 |
#10759 |
Drives: A Blue One
Parting out some parts from my 86:
Neon yellow (could use some repaint) Enkei RPF1 17x9+38 w/ 595rr 75% thread, has curb rash on the inside of 2 rims (not seen) overshooting an apex still drives straight and great as a track set - $750 Neon yellow Enkei RPF1 18x9.5+38 w pilot super sports 85% thread, rims in great condition - SOLD Muteki sr55 lug nuts (blue color has been stripped quite a bit but still very functional, these are stainless steel lugs) - $20 SPC rear LCA - SOLD Whiteline rear sway bar adjustable end links: $50 Stance front sway bar adjustable end links: $20 KWV3 with verus engineering front camber plate and swift spring upgrade, original springs also included: $1500 Toms red tail lights w/ LED relay: SOLD Tapturn strobe series custom led relay 13-16 models- $40 Greddy evo 3 catback exhaust, has a dent on the connection between axel back and midpipe but will bolt on and off completely fine (needs new gaskets) - $300 Schroth racing 4 point ASM harness - $300 Verus engineering front chasis splitter - SOLD 5-axis side skirt replica (good fitment) paint matched WRB - $200 Authentic bride lowmax REIMS bucket seats with low max rails in excellent condition (driver and passenger) - $1750 Perrin inlet tube black - $50 Bump Last edited by BPM; 08-22-2019 at 11:19 PM. |
#10760 |
Drives: Whiteout FRS
#10761 |
Decided it's time to sell my 2013 FRS - just bought a house and going back to school across the bay soon so life has gotten a little busy for it
Full disclosure - it has been in two accidents but it's still a clean title. I got break checked while working and my front end on the driver's side got hit, and I was rear ended during work as well. All body work done at Milani's Autocraft in Novato. Other work done at Racersline in Concord Currently has a some mods, but I also have the stock parts if you want to switch out. (Tomei header, MXP comp exhaust - will be selling my open flash 2 separately) Whiteline rear inserts Will come with Apex ARC-8s in bronze and the stock wheels. About 69k miles I'm the second owner, picked it up in SF in 2017. Getting some feelers, have it posted on cg for $15,500. I just got it back from the valve spring recall, had to in order to renew the reg this month Message me with any questions https://photos.app.goo.gl/HPFxX9dimAwLWgQC8 https://photos.app.goo.gl/poWFLLCePHyhjstZ6 Last edited by SprocketPower; 08-15-2019 at 09:59 PM. |
#10762 | |
Drives: FRS
#10763 |
Drives: Subaru BRZ
Selling my Wheel Spacer H & R that i only use for 40 miles. 20mm 12x1.25 56.1 for 90 dollars. Msg me thanks!
#10764 |
Drives: '18 STi
FS: Stock Front Pipe from a 2014 Subaru BRZ. The front pipe was taken off at approx 20k miles. Asking $75 obo.
#10765 |
Drives:
WTB SPEC D OR VLAND HEADLIGHTS
WTS STOCM TAIL LIGHTS & 4TH BRAKE LIGHT FOR $100 ![]() Sent from my iPhone using Tapatalk |
#10766 |
Drives: Q5 + BRZ + M796
I'm looking to buy a MY17+ black front bumper. Willing to trade for my 2013 front bumper.
| NW Marketplace v1.0 (CLOSED) | DarrenDriven | Northwest | 2872 | 08-14-2015 02:48 PM |
| Looking for another Local FRS/BRZ! | XR4OUTCAST | Mid-Atlantic | 18 | 11-09-2012 02:20 PM |
| MCM FR-S now in NorCal!!! | microcarmag | Southern California | 6 | 07-01-2012 06:01 PM |
| 2nd BRZ in NorCal? | Chauntalei | BRZ First-Gen (2012+) — General Topics | 15 | 05-29-2012 09:44 AM |
| Marketplace | GenkiElite | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 02-08-2012 03:26 PM |
