03-22-2016, 12:18 AM | #1051 |
Boost Creep
Drives: 2016 HyperBlue BRZ
And I never will be, regardless of if I'm living in CA again or not. The issue was miscommunication on both sides, mostly my own fault.
We're up and running now. Stalling if I let the revs drop too fast, but other than that not bad. |
The Following User Says Thank You to Luftwaffel For This Useful Post: | BigFatFlip (03-22-2016) |
03-22-2016, 11:44 AM | #1052 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Same here, currently trying to weigh the pros and cons of going with an e-tune like delicious or having a local shop do some dyno tuning. Very curious to see what you think of Moto-Easts tune once it gets all dialed in. If I remember correctly, HI only gets 91 oct just like here in CA correct?
03-22-2016, 11:58 AM | #1053 | |
Boost Creep
The Following 2 Users Say Thank You to Luftwaffel For This Useful Post: | BigFatFlip (03-23-2016), CSG Mike (03-22-2016) |
03-23-2016, 06:52 PM | #1054 |
Drives: 2014 Porsche Cayman S
So, now that I have the Edelbrock running on the CARB Tune and completely stock otherwise, the next steps in my education are to:
Know how to take it back to stock should I need to (ECU only, not hardware); I am assuming that the original tune is on the USB stick. How do I log information using the ECUTEK cable and software for troubleshooting and general information? Do I have to use a Windows device or can I use an Android tablet, for example? Finally, can I use the ECUTEK to feed information to a Torque App and have gauges for Boost etc... Obviously, a Noob here...any help appreciated. Cheers.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
03-23-2016, 07:03 PM | #1055 | |
Drives: FRS, Supra, Colorado D, GLC63
The Following 2 Users Say Thank You to The Racers Line For This Useful Post: | paiceyfan (03-23-2016) |
03-23-2016, 07:15 PM | #1056 | ||
I'll take a stab...
http://blog.perrinperformance.com/ho...cuteks-proecu/ Its preferable to use a windows device (as opposed to an apple), don't think you can use Android (you might be confusing it with the Torque app). Don't think so. If you want to use Toque app to display data, you will be better off getting a blue tooth OBD2 sensor. Pretty cheap on Amazon. |
The Following 5 Users Say Thank You to BigFatFlip For This Useful Post: | CSG Mike (03-24-2016), Luftwaffel (03-24-2016), Nitro22 (03-24-2016), paiceyfan (03-23-2016), The Racers Line (03-23-2016) |
03-23-2016, 11:13 PM | #1057 | |
03-23-2016, 11:14 PM | #1058 |
I will give you a call later this week...cheers!
The Following User Says Thank You to paiceyfan For This Useful Post: | The Racers Line (03-23-2016) |
03-24-2016, 12:11 PM | #1059 |
Drives: Scion FR-S (Hot Lava)
Also don't forget to allow the EcuTek software to do an update. The ProECURomFiles Folder will populate with OE calibrations typically after the first update. (At least that's how mine behaved)
The Following 2 Users Say Thank You to Nitro22 For This Useful Post: | BigFatFlip (03-24-2016), paiceyfan (03-24-2016) |
03-24-2016, 12:55 PM | #1060 |
Boost Creep
I actually had trouble getting boost pressure in Torque. All I could ever get is bar, and then math out the atmospheric pressure haha.
Finally hooked up my Innovate ECB-1. |
The Following User Says Thank You to Luftwaffel For This Useful Post: | paiceyfan (03-24-2016) |
03-24-2016, 01:05 PM | #1061 |
Side note to this: by default EcuTek will try to download ALL the roms for EVERY platform. Just check the Subaru BRZ box to save some time
03-24-2016, 01:06 PM | #1062 |
03-24-2016, 01:54 PM | #1063 |
Drives: UK GT86
There's only MX-5 and BRZ ones, it's not that long unless you live in the dark ages still
.: Stealth 86 :.
03-24-2016, 02:40 PM | #1064 |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
