Old 12-12-2013, 12:12 PM   #1051
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
Thanks for the post.
Our calibration is built without the AEM module as it becomes redundant with the Unichip installed.
Cheers
Unichip Jack is offline   Reply With Quote
Old 12-14-2013, 11:14 PM   #1052
benlaz88
Drives: 2013 Asphalt FRS
Thank You Jack for everything. You answer all my questions and reply fast. Very excellent custumer service!!
benlaz88 is offline   Reply With Quote
Old 12-26-2013, 02:22 PM   #1053
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Were the FA20club CAI tunes removed due to a license issue?
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 12-30-2013, 02:41 PM   #1054
Unichip Jack
FA20 Club Maps
BuBlake...
When we log in, we see the maps... which one(s) are you specifically looking for?
Cheers
Old 12-30-2013, 07:39 PM   #1055
irvin1958
irvin1958's Avatar
Drives: '14 FR-S, Auto,Uni,Greddy,Perrin
2014 FR-S, CEL
Have been driving with Unichip on position 1 for one tank full of gas and was pleased. Refueled, selected position 0 and at about 1/2 tank down got a CEL and stability light on constant. Turned off vehicle and selected position 1. CEL remained on Stability light off. Codes were P0172, P1170 ,P117B.
Anybody got an idea about this?
irvin1958 is offline   Reply With Quote
Old 12-30-2013, 07:41 PM   #1056
xcelir8brz
Drives: 2013 BRZ Limited
Hi.
What mods have you made to your car? What type of gas are you running and from where did you purchase it?
What tunes are you also running?
I believe I can provide you the answer. Been running Unichip strong for quite some time time and probably the most experienced person with a BRZ/FR-S in the Mid-West. If I can't help, I'm sure Jack can.
xcelir8brz is offline   Reply With Quote
Old 12-30-2013, 07:45 PM   #1057
irvin1958
irvin1958's Avatar
Greddy CAI, Motive Hi-Flow Cat, Perrin Resonated exhaust- all this was provided for the pre-installed maps.
Shell 91 Octane, 10% ethanol
Running maps shipped with the Unichip- no changes as yet- still testing.
Old 12-30-2013, 07:48 PM   #1058
irvin1958
irvin1958's Avatar
Originally Posted by xcelir8brz View Post
Hi.
Old 12-30-2013, 07:49 PM   #1059
xcelir8brz
So which maps were installed from UNICHIP? In otherwords, which is in position 0 and which is in position 1?
I'm curious if you are running Greddy CAI with Fuel Standard and Timing Standard in 0.
And in 1, maybe Fuel Out and Timing In or Fuel In and Timing Out or Both Out or Both In?
Also, the gas you have - do you have Winter Gas or Fall Gas. Do you even know? And is it Shell brand or which brand?
All the above makes a HUGE difference.
I've run about 40 tunes with tons of different gas combinations here in Chicagoland.
You might want to plug your laptop in and flash Greddy CAI with Fuel Standard and Timing Standard in 0. And in position one, Stock+ Fuel Standard, Timing Standard. This will help gauge the extremes of what is going on.
You might want to pick up a Flux2 as well to monitor your intake temperature, your RPMs as well as your Engine Temperature.
This also alows you to reset your CELS.
I'll try to help, but need more info - especially state and temperature the last few days.
Old 12-30-2013, 07:55 PM   #1060
irvin1958
irvin1958's Avatar
I have not gotten a cable to change the maps as yet. I live in Daytona Beach FL so there is no fuel grade switching that I am aware of- temp has been around 80F.
I guess my first step is to get a cable...
Old 12-30-2013, 07:59 PM   #1061
xcelir8brz
Okay. Being in Florida eliminates A LOT of the variables. Do this then. Get all your gas out of the tank. It sounds like it could be bad gas. It happens. Go to shell and get 91/93. Yeah, spend the extra money. It makes a HUGE difference IMO especially with the Unichip. Once you get new gas, clear the CELS - stop at autozone, they'll do it for free. Drive around, and see. Still have problems. Remap 0 and 1. It's really easy to do so, and will help. I didn't see what mods you've done either.
Old 12-30-2013, 09:14 PM   #1062
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
First installer here.
Does anybody have any trick as to how to remove that bloody CPS plug... It's jammed in the connector very tight. My fat hands are not winning this one...
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 12-30-2013, 09:17 PM   #1063
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
Yeah it's a slight hangup. I think I used a long screwdriver to press on the clip
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 12-30-2013, 10:42 PM   #1064
tbertran
tbertran's Avatar
Ugh... I was pushing the wrong end of the tab. No wonder that thing would not move!
Ok... so I plugged everything, tried to start the car and... it didn't. It's cranking up fine but the engine never kicks in.
Verified the connections, all seemed good.
I put it back to stock and it started fine but now I have a CEL with the following 2 codes:
P0103 (Mass or Volume Air Flow Sensor "A" Circuit High)
P0335 (Crankshaft Position Sensor "A" Circuit)
Any idea?
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
