#1051 |
Drives: 2015 BRZ CWP
I run the verus air oil separator with return and also venting to atmosphere. Have no issues and have run the 90,85 and 75 pulleys. Track only driving
#1052 |
Drives: Toyota 86 GT
#1053 |
Does anyone know if the Grams 72mm throttle body will fit the Harrop SC?
#1054 |
#1055 | |
Steve Bodalenko
Drives: Toyota 86 GTS
Not the 3” but the same as the one used in AU 86 Series. SME supplied the series. 2.5”. You don’t need a 3” system with a Harrop. I went from the Tomei UEL to the SME EL when I grew up and started to dislike rumble, and difference was immediate. Car ran better, AFR was far more stable, and exhaust note after 4K rpm is amazing and gets better to redline. Especially with the Harrop on the car. I have them hooked up to the SME header back twin system. It’s not perfect re drone but out of the three or four exhaust combos I’ve had it’s about the best, and at redline it’s by far the best |
#1056 | |
Steve Bodalenko
Same here, the Radium twin system and I’m on e85, and after 3000k’s I’ve got a small amount of milky oil crap sitting in mine and it does smell a little of e85. FAR better it sitting in a CC than going thru the SC in my opinion. In the scope of things a catch can is a small outlay.. |
#1057 |
Steve Bodalenko
#1058 | |
Drives: Q5 + BRZ + M796
Turbos don’t create more blowby gases than superchargers. It is just that turbochargers typically hit higher boost levels, so they are needed that much more often. This type of buildup on the heat exchangers and intake manifold would be normal. ![]()
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Bodalenko (01-10-2021) |
#1059 |
Drives: 2015 BRZ Crystal White Pearl
I no longer have the stock intake and have the Grimmspeed one. While thinking about the Harrop SC, one could get the TRD intake which is CARB legal and use that versus the BPM filter and clean side part of the airbox included with the Harrop ? Or even any other CARB legal intake that uses the factory airbox location ?
#1060 | |
#1061 |
Steve Bodalenko
What injectors are owners usiing with their Harrops and what are the characteristics of them?
I have the DW700cc and the stock fuel pump. My car has the 85mm pulley, making approx 10 psi, and I run e85 99.9% of the time. I feel like the cari hits a wall from a lack of fuel at the top end when it feels like it has a shit load left in it. I’m looking at going to the 80mm pulley, which makes approx 11.5 psi, and was thinking the 700cc might be a little light on with the extra boost so along with the necessary fuel pump upgrade I was considering installing the ID1050’s at the same time since the car will need a retune for the smaller pulley anyway. I’ve spoken to a very knowledgeable and well clued up owner running the 80mm pulley and he thinks the bigger ID1050 aren’t necessary and will make the car less drivable at low speed due to the spray pattern of the bigger injectors. Bigger as we all know is NOT always better. His reasoning sounds right and everyone posting here knows that mods have to be matched and balanced. Going to big in any area especially with boost v fuelling can have detrimental consequences. Just wondering what The opinions and experiences are with the 700cc v 1050CC injector with regard to drivability when DD as well as spirited driving. I think the 700cc is maxing out but that might be a tune issue and not the injectors. Last edited by Bodalenko; 01-22-2021 at 02:31 PM. |
#1062 | |
Master Collaborator
As I have the same modifications planned for my SC install, and have also read differences of opinions..... Watching. |
#1063 | |
https://www.ft86club.com/forums/show...postcount=1004 Can you post a datalog on Datazap or something?
#1064 |
These logs are from the 85mm pulley with the stock header. I need to transfer the logs from the 75mm pulley and upload them, but these show the oscillations.
For reference: The flat spot on the MAP is at 6272 rpms, which is where the port and direct oscillations perfectly overlap. The fuel oscillations start around 4850 then hit their high between 6000-6500 then back down until redline. Given an infinite redline, I don't know if they would smooth out again before returning to the pattern seen and repeat like that forever. The crossover point for the direct and port injectors is around 5260 for this tuner.
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 05:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 02:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 03:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
