Old 11-21-2014, 03:50 PM   #1037
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by toeout View Post
I have the UEL with a 2.5" Motiv overpipe. I've had the cold sound you're describing and IME it's just the sound they make. I've had on the aluminum sheet gaskets that came with the Motiv pipe, stock gaskets, Grimmspeed gaskets and finally Remflex gaskets. The sound remained with all of them.
If there is no condensation water sputtering or leaking out between the mating surfaces ( mine were till I used Remflex ) at the cold start, then there is no leak.
Interesting. I got a CEL when I went out for lunch, so I'll pull the code when I head home and if it's rear O2 related I'd say I have a leak. I did double check to make sure Shiv disabled the CEL for cat efficiency, so it's not due to the lack of cat.
I assume you've had the remflex gasket in for a while? I saw some old posts on Nasioc about them failing (but that was on turbo cars, so who knows)
Old 11-21-2014, 04:42 PM   #1038
rtyp3
rtyp3's Avatar
Dear JDL
Just want to leave feedback about my experience so far after placing an order
-3 weeks ago followed up to see status of headers. Told they would be finished that week, sent to coating, then shipped out the next week.
-2 weeks later follow up via email and receive no response.
-called today and find out the parts are still sitting in the shop waiting to go to coating. Person on phone apologizes that I had earlier been 'misinformed'. Still was not clear if they would even go to coating next week.
I would expect this from the government, but hope for a little more in this industry - I work in manufacturing myself. To require payment up front then just sitting on the parts doesn't feel right - perhaps you shouldn't charge until shipment (common in the industry), which provides internal financial motivation to ship.
I sure hope the parts are high quality and make it worth it! The photos look great...
rtyp3 is offline   Reply With Quote
Old 11-21-2014, 08:17 PM   #1039
toeout
I've had them for about 5 months / 8K miles. I also read those posts on Nasioc, but my experience has been completely positive. I use them at all the exhaust connections, including header to block.
This includes about 20 autocross events, so I feel they've held up well so far. Can't comment on why some people have bad luck with them. Maybe they bent and cracked them during installation?
toeout is offline   Reply With Quote
The Following User Says Thank You to toeout For This Useful Post:
DocWalt (11-21-2014)
Old 11-21-2014, 08:26 PM   #1040
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I still don't see any condensation or anything from my exhaust, and the CEL was unrelated (camshaft position sensors... time for the TSB) so I guess I'm fine. Definitely a wooshy/hissy noise from the engine bay area though. I dunno...
Old 11-22-2014, 05:14 PM   #1041
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Heres some pics. Photo credit VEX Performance in Calgary Alberta who are working on my car.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 11-23-2014, 03:48 PM   #1042
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'd recommend not using the OEM gasket on the overpipe connection... It's not big enough to crush completely due to the JDL flange being a 2.5" opening vs the factory 2".
The JDL provided gasket seals fine. Still a lot of wooshy noise thanks to the change in pipe diameter. Thanks to JDL for the pic from their development thread:
Old 11-23-2014, 04:37 PM   #1043
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Might the grimmspeed gasket work better for the overpipe connection? So there's no way to avoid the "wooshy" noise?
Phaedrus29 is offline   Reply With Quote
Old 11-23-2014, 05:22 PM   #1044
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'm sure the Grimmspeed gaskets are the best solution, but it was leaking and the Grimmspeed gaskets I ordered aren't going to ship for a bit since they're moving shops at the moment. JDL gasket seals fine.
It's a lot less wooshy now, but it's still wooshier than I expected. I really only notice if I'm driving next to something with the windows down, so it's not like it's obnoxious. JDL has made posts about headers sounding weird with the OEM overpipe, so I had plenty of warning. I'll eventually pick up a matching JDL overpipe, but I'm trying to keep my car quiet and not totally blow my budget right now, haha. I'd have jumped right on the JDL overpipe if I couldn't make the factory one seal.
The Following User Says Thank You to DocWalt For This Useful Post:
diodelphi (11-28-2014)
Old 11-23-2014, 05:48 PM   #1045
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
@JDL Could we get the weights of the various headers:
UEL - catted
UEL- uncatted
EL- catted
EL- uncatted
Thanks!!!
F1fletch is offline   Reply With Quote
Old 11-23-2014, 06:22 PM   #1046
Phaedrus29
Phaedrus29's Avatar
Ah OK, my bad, I didn't realize you were talking about the factory OVP. I'm going with the JDL UEL and OVP, so maybe I can avoid the WOOOOSH. Then I have a Perrin frontpipe, so hopefully those will meet up well.
Old 11-23-2014, 06:31 PM   #1047
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Should be fine
Old 11-24-2014, 07:10 PM   #1048
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I like how it sounds You can hear the bit of wooshiness. The header's powerband feels freaking fantastic. Essentially no more torque dip, and plenty more power everywhere else too. I love it! Thanks for the awesome product JDL, can't wait until I can justify the matching overpipe (and maybe front pipe too...)
[ame="http://www.youtube.com/watch?v=j8vDL8wUwR8"]BRZ JDL UEL Header - YouTube[/ame]
Old 11-25-2014, 12:01 PM   #1049
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Speed Academy's Targa FRS with our EL, Overpipe, and Frontpipe.
[ame]http://youtu.be/5YvuHbf0cIk[/ame]
JDLAutoDesign is offline   Reply With Quote
The Following 4 Users Say Thank You to JDLAutoDesign For This Useful Post:
akahenry (11-28-2014), HatchetBurial (11-25-2014), myEFispissed (11-25-2014), sergiomordo (11-28-2014)
Old 11-26-2014, 12:43 PM   #1050
JDLAutoDesign
Drives: 13 FRS
Last few days for the combo package pricing
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
